Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso error code
I'm getting the "Ld" (long drain) code on my Whirlpool Calypso washer. Is something broken?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 31, 2010
  • CalBill Jun 08, 2011
    I can't emphasize enough, remove all drain hoses and check for obstructions. The final black, long drain hose has a limiter inside of it! The limiter looks like a duck's bill. If it is clogged, use a coathanger to hook it and pull it out. Then, clean and replace.
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Get LD error/ fault when washing
This error code means long drain.
What this means is that the drain is either clogged or kinked. Please inspect your washers drain hose and than press stop/cancel to clear the code.
Jan 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Get alarm code ld
CI code comes on just seconds after I start the machine. The machine itself is leveled on all sides.
Dec 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirpool calypso
The fault code "LD" indicates "long drain" condition. It's not only if the water drained, but how fast it drained. Check the drain line for kinks or obstructions. Check the pump. Remove the hoses and use a flashlight to look into the suction port. Make sure nothing is clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller spins freely. If there are broken/missing blades or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or a jammed impeller. Sorry for your trouble and I hope this helped. Best wishes.
Sep 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
''LD'' error
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
for more information follow the below link --
http://fixitnow.com/wp/2009/03/11/whirlpool-calypso-washer-full-of-suds-wont-drain-and-throwing-an-ld-error-code/
Mar 20, 2009 | Whirlpool WTW6600SW Top Load
Washer won't empty water....
Ld Long drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display.
Mar 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer error code problem
LD is long drain associated with two problems the drain hose install and the pump. Debris in the pump and a drain hose inserted too far will cause most of these issues.
Sep 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
653 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
