Question about Whirlpool 21.7 cu. ft. Side-by-Side Refrigerator ED22PQXF
Whirlpool model ED22TEXHW00..fan works but no
Whirlpool model ED22TEXHW00..fan works but fridge no longer is cooling or freezing...there is a clicking noise. Help please
  • Whirlpool Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerwhirlpool model ED22TEXHW00..fan works but no - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 31, 2010
I have a whirlpool fridge cool keep freezing up causing fan to freeze up makes a lot noise
Sounds like the fridge thermometer is not working and needs to be replaced
Nov 20, 2017 | Whirlpool Refrigerators
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
Refrigerator and freezer not cool
Try unplugging the fridge for a day or two and then plug it back in and see if it starts working. If the refrigerator has froze inside and the defrost system is not working, letting it thaw out for a day or two may bring it back to life, until it freezes again. The fan inside the fridge must circulate air, it must be working or it will allways freeze up and not cool.
The fan and compressor must also be working underneath the fridge. When working properly, one of the lines from the compressor will feel hot and the other cool off. The radiator coil must not be clogged and air should flow freely thru it with the fan running.
Apr 01, 2014 | Whirlpool Refrigerators
Model WRT779REYMOO
Without more details as to how old it is and what kind of condition it is in, I would recommend you have it looked at by a refrigeration professional.
When a fridge is no longer cooling, the main culprits are clogs caused by frozen sections of the air circulation path, refrigerant leaks and faulty compressors. A professional technician can diagnose both. If the compressor is bad, refrigerant is not changing phases (which causes the cooling to occur). If there is a leak, there is not enough refrigerant to compress and the fridge will never cool.
Sometimes the fan is faulty, so the cold air will not circulate into the fridge.
Since your fridge has been sitting, you likely do not have any clogs caused by freezing. If your freezer side works but not the fridge, you either have dual compressors (and the fridge compressor is bad) or you have blockage in the air circulation path. There is also a very slim chance that the light inside your fridge is remaining on and generating heat.
Mar 02, 2014 | Whirlpool Refrigerators
Fridge not cooling whirlpool model gd5rhaxn000
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Aug 28, 2011 | Whirlpool S20DRSS33 Side by Side...
My whirlpool fridge makes a loud humming noise when the door is closed. It is not freezing items in the freexer and is not cooling items in the fridge section. The freezer is above the fridge section in...
The fan is hitting ice build up...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 11, 2010 | Whirlpool Refrigerators
NOT COOLING
HI, since the unit still has power, this will rule out any capacitor issues and failed evap/condenser assembly as well. The most likely issue here is that the compressor has failed.
There are many components that will cause this failure and, here is a run down.
COMPRESSOR PARTS
Starter device component
Compressor relay & overload component
PTC Relay
Compressor tank.
If this fridge is a bit up in its age, i would recommend purchasing a new thermostat and, i would also recommend purchasing a complete compressor replacement kit. this kit has every component and part you will need to restore the cooling abilities of your fridge. it will fix this issue.
The compressor kit will cost $262.00 and the thermostat will cost $55.95.
Please rate and god bless:)
Apr 15, 2009 | Refrigerators
FRIDGE NO COOL
We will need to unplug refrigerator and open the panel inside the freeze compartment examine the fan for binding and if the fan is defective it will need replaced. Let me know, Thanks, Sea Breeze
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirpool side by side refrigerator ,fridges is not cooling at all
HI.YOU MIGHT WANT TO CHECK IF THE FAN IS WORKING WELL OR IF THE UNIT IS NOT OVER FREEZING WHICH CAN E A CAUSE OF THE FRIDGE NOT COOLING PROPERLY.FEEL FREE TO REQUEST MORE ADVICE IF NEEDED
Nov 13, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
GE Fridge...no longer freezing or cooling food!!
Had to call in the experts...needed a defrost heater and 2 sensors.Hope this is helpful to anyone w/ a similar problem.
Jul 24, 2008 | Refrigerators
Refrigerators Logo
303 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
