Question about Kenmore Refrigerators
Why does the drain hole at the bottom of the freezer clog, and how do I clear or prevent this from happening again ?
  • Kenmore Master
  • 1,606 Answers
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on Jul 31, 2010
  • 4,793 Answers
Its a moss,(look at the bathroom window frame)easy to clear,syringe it with clorine bleach,(the smell will dissipate within an hour)
Jthe water from the defrost cycle doesn't drain into the pan underneath. It freezes up and runs into the bottm of freezer until it must be defrosted on the bottom only.
The defrost drain which is behind the evaporator wall becomes frozen over or blocked by debris. You must remove the back wall to get at the drain and thaw it or snake it with wire to free the clog. After its clear, wrap some copper wire around the defrost heater and drop a length of it into the drain hole. This will prevent it from freezing over again.
Jul 28, 2014 | Whirlpool Refrigerators
Ice in the bottom of the freezer compartment
there should be a drain hole at the bottom of the freezer that goes to a evaporation pan underneath. check to see if the drain is clogged. in areas with high temps and or humidity there will be excessive moisture build up,the more the door is opened the more moisture (condensation). Clear the drain, it may just be blocked by ice, MAKE SURE THE UNIT IS LEVEL! This will let the moisture drain properly and prevent ice build up.
Apr 11, 2014 | Freezers
I have a two door 600 liter fridge the freezer side has a water drain hose which I don't know where the water drains to.I have cleared the frozen water from the drain hose,a couple of times but I know the...
The hole in the bottom of the freezer section all the way in the back is clogged. Use a metal coat hanger or something similar to stick in the hole and try to clear out the clog. The water drains to a pan underneath the fridge, and the heat produced by the compressor should evaporate the water.
Dec 10, 2010 | Maytag Refrigerators
Ice continually forming on bottom of upright freezer
you nead to clear the drain.when you clear the ice you nead to make sure that the drain is clear.a spider can build a nest in your drain line.if you remove the ice,you nead to clear the drain line with a hose.you nead to blow though hose and clear line.
Nov 18, 2009 | Ovens
Ice collecting under bottom of Freezer drawer/ seal round door intact/ food staying frozen/ Ice is cleared periodically but then builds up again
Your defrost drain hole is clogged. Look for the drain hole in the bottom rear of the freezer section. Turn off the fridge. Heat the drain hole with a hair dryer and clear the ice. Pour a quarter cup of bleach into the hole.
Jul 04, 2009 | Hotpoint Freezers
Water pooling and freezing inside bottom freezer.
make sure you have cleared the drain all the way to the drip pan, and the fridge should be tilted slightly to the rear for good drainage........make sure there is a clear path for the water to make it to the drain hole
Jan 03, 2009 | LG LFC25760 French Door Refrigerator
Freezer leaking water
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Apr 09, 2008 | Freezers
Whirlpool refrigerator top freezer
Apr 07, 2008 | Refrigerators
Excessive Frost and Ice Build up in Freezer
Mar 20, 2008 | Refrigerators
Water under drawers, condensation on top of freezer
Water collecting on the top of a freezer, I have to wipe it every week, it is on the outside of the freezer, on top of the formica surface. Please Help.
Jan 12, 2007 | Kenmore 72202 / 72204 / 72209 Top Freezer...
Refrigerators Logo
47 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
