Question about GE Heating & Cooling
Model number AEW10AMG1....I have a problem my air conditioner will continuously run and when we try to power it off it will not power off we have to unplug it. We also try to turn down the temperature and when we get through messing with the temperature it will go back up to the same temperature on its own. The filter is clean so we know it's not the filter...please help if you can..thanks
SOURCE: Air conditioner turns on then shuts itself off immediately
There's something wrong with your aircon. Usually the lights will start to blink. Depending on the brand and model, the number of times it blinks will give you an error code which tells you what's spoilt. You may like to check this out http://www.astiquer.com/blinking.html
Posted on Oct 07, 2008
ronaldo_ross
  • 1056 Answers
SOURCE: I have a Concord air conditioner, central heat and
You can try getting it serviced. Vacuuming the system and charging it up with new refrigerant, as well as replacing the reciever drier, will help tweak your AC system. This is no guarantee though. It might be able to bring the temp in your house down several more degrees. Also try cleaning the condenser outside. You can spray it with water to clean off dirt which block air from passing through. This hepls a bit and you can do it yourself.
Posted on Jun 28, 2009
oneqtpieiam
SOURCE: Haier Air conditioner problems - e1 message
try turning it off holding buttons each individually in for 3 secs then in an hour plug back in ... the rep from Haier gave me this advice ... just waiting my hour now ... i also hear that the remote works for sure ...
Posted on Aug 11, 2009
shastalaker7
  • 1515 Answers
SOURCE: my air conditioner coils continue to freeze up. i
If the indoor coil is icing up, you are either low on freon, or the indoor coil is very dirty. This will cause it to ice even though you have replaced the filter. See if the suction line/large copper line has ice on it on the outdoor unit. If so, its low on charge or the indoor coil has plugged up and not getting enough air flow across it. Please keep me posted.
Shastalaker7
Posted on Apr 17, 2010
SOURCE: Does the 76129 Kenmore Air Conditioner have a reset button
We have a Sears Kenmore 2537015600 that just quit working, will not power up at all. Is there a reset method on this unit or do we need to buy a new unit.
Posted on Aug 03, 2010
WHY DOES MY FRIGIDAIRE AIR CONDITIONER SLEEP BUTTON KEEPS BEEPING?
I appreciate your post, Tamara Brazile!
I see that your sleep button on your Frigidaire air conditioner continues to beep. Do you see any error codes on your air conditioner? Additionally, could you please provide me with your model number? You can locate the serial tag (which lists your model number) on the outside frame of your air conditioner or under the front panel. With that additional information I can further assist you. -Matt
Feb 22, 2015 | Frigidaire Heating & Cooling
My compressor continues to run even when I turn unit off. It runs in all settings as well. Is this a control board issue?
Hello David Forgey, thanks for your post!
Based off the information you have provided the compressor within your Frigidaire air conditioner continues to run when turned off and in different settings. It could be an issue within your control panel or a problem within the wiring harness. I would perform a reset on your air conditioner by unplugging the power cord for ten minutes. If that does not correct the issue you may want to consult with professional technician for proper repairs. Hope this helps. -Matt
Nov 03, 2014 | Frigidaire Heating & Cooling
Units runs but cool air will stop even thou blower continues to run after several minutes cool air starts again
Check the theremostat probe to see if it may be too close to the evaporator fins behind filter if touching fins it will feel evaporator being cold before room air and send model number too, Sea Breeze
May 21, 2010 | LG Electronic Window Air Conditioner
Furnace blower won't stop running
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Jan 04, 2010 | Amana Comfort Zone 12M32PBEH Air...
Haier AC Problem Troubleshoot.
Your compressor is faulty, you could test this with an ohm meter or a mega tester to confirm that you have continuity between windings and earth or that the insulation on one of the start or run windings has overheated and broken down. Before you give up though, you can try to change the compressor capacitor, with same rated microfarad capacitor.
Jan 16, 2009 | Haier hwr10xc6 Air Conditioner
The error code is saying E1
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
If you doubt the veracity of this information, or it does not work as
expected, you can get it directly from the source at:
1-800-237-4277
which is the Sharp customer service line. But, you'll need to call
between 7 AM and 7 PM US Central time, and have your model number and
serial number ready.
Jul 12, 2008 | Sharp Heating & Cooling
Central Air Conditioner
Turn the power to the indoor unit off. Remove the cover where the fan is. Feel the motor of the fan. If it is very hot the bearings have likely gone out. If the fan is cool to the touch I would call a service company because you likely have an electrical problem that will require some training to solve.
Jul 09, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
232 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
