Question about Kenmore Washing Machines
Kenmore washer (110.92389200) drains, but will not agitate or spin; also, cannot turn the basket by hand. Where is the access for service?
  • Kenmore Master
  • 2,699 Answers
Check the motor coupling,take out the two screws that hold down the top console,flip up the console,unplug the lid switch harness in the middle or a little to the right from the middle and with a screw driver pop the two metal clips,tilt the frame to you and remove the whole frame of the washer.with a screw driver pop the two clips holding the pump on and slide the pump forward off the motor.take out the two screws and pop the motor clips and pull the motor forward,you'll see the motor coupling,there should be three arms coming off the coupling and three arms on the other part of coupling and a piece of rubber that they slide into,if it's cracked or worn in the middle replace the coupling and cut down on the size of the loads you put into washer.when putting the motor back on look at the four corners of the motor,if any of the rubber spacers are missing look where the motor goes and take the rubber spacers off the frame and stick them in the four corners of the motor and then line the motor up and install it,it's to hard to get the motor back if you don't do this.good luck and let me know what you find,if you need any more help let me know
Posted on Jul 31, 2010
  • Sal De Jul 31, 2010
    part number 285753A for coupling,it's around 23 bucks
I have a Kenmore model# 417 44142400 stackable washer and dryer the washer will not agitate or spin. The belt is fine; I can turn the belt and motor by hand. All it will do is fill, and then sit there with...
If it will not agitate or spin the Door switch has failed. Listen for a CLICK as you just open or just CLOSE the Door. No click is most likely bad Door switch PN 131763202. Shop around if you tdetermin the doo switch has failed... This part can cost $40 - $72.00 depending up on the source.
Thanks for choosing FixYa,
Kelly
Jun 30, 2011 | Kenmore Washing Machines
My Kenmore Elite HE 3 model #110 4822 201 will not spin. It runs through an entire cycle and fills and drains. The drum will turn a few turns clockwise when spun by hand but then will not move further...
Hello there:
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool and Kenmore have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Jan 15, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore washer model 110.23812100. basket not spinning during spin cycle.
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23812100
Also see the Whirlpool Service Manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If you can hear the motor and the washer drains during the spin cycle the Motor Coupler and Lid Switch (the usual problems with these washers) are not the problem.
These washers use a clutch which allows the "basket tube" to spin up to speed during the spin cycle.
If the clutch bands or springs are worn or damaged, the transmission cannot transmit power to the basket tube for spining.
See the following on how to remove the cabinet,agitators, basket, pump, transmission and basket tube. (It's not as difficult as it sounds.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Instead of using a special spanner wrench on the spanner nut, I've used a short 10" pipe wrench hooked onto one of the tabs on the nut and tapped the handle with a hammer to loosen the nut. I also put a short piece of wood under the Basket Drive Block and hit the wood instead of the drive block directly.
Check the clutch bands and springs and the tabs on top of the basket tube and the slots in the basket drive block.
Nov 03, 2009 | Kenmore Washing Machines
I have a Kenmore washer tube wont move to spin out
Hi, Do you know if the washer agitated at all? If the washer does not agitate or spin, the coupler is most likely the cause. If the washer agitates and does not spin, it could be spin basket drive or transmission.
Please let me know so I can assist you further.
Vic
Jun 27, 2009 | Washing Machines
Kenmore 24732 will fill and drain but will not agitate or spin
HI, Even tho it drains ok, does it spin? If it doesn't spin or agitate, it could be the coupler that attachec the transmission to the motor.The agitator is ok, it is designed to work that way. Please let me know if I can assist you further.
Thanks
Vic
May 17, 2009 | Kenmore 24732 Top Load Washer
Kenmore 70 Series Washer Spin Cycle Only issue.
It sounds like one of two things 1,A worn clutch .or 2.motor coupler is about gone,
May 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer model 110.92284800
Most common problem is the coupling. The basket drive would have tobe completly out not to spin without clothes in it. The gearcase could lock up and cause the couple to break but it's not very common.
Apr 23, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
116 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
