Question about Whirlpool GB2SHKXL Bottom Freezer Refrigerator
Freezer goes on and then shuts off
Freezer goes on and then shuts of. It thaws out, then it refreezes. Whirlpool Gold bottom freezer
  • Whirlpool Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerfreezer goes on and then shuts off - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 31, 2010
Freezer freezes but at some point thaws and then cools again. So everything is melting then freezing again; ice cubes melt and drip then refreeze.
The auto defrost timer may be broken. The freezer is going for a too long time in the heat cycle. Also ice can be stuck behind the cooling circuit and the cold air is not circulating well. Check if water is going in the evaporating pan at the bottom of the fridge. It should have a little water everyday.
Oct 11, 2016 | Whirlpool Refrigerators
My freezer is icing over and thawing food somewhat then refreezing
If the self defrosting circuit is not working properly the freezer will ice up and internal temps will go up and thaw food. U indicate that it refreezes so whst could be the problem is the timer that controls the frequency and timing of the defrost cycle.
Jan 18, 2015 | Refrigerators
Freezer temp not steady
it is cycling different because the environment is much colder..
Jan 21, 2014 | Whirlpool Refrigerators
Water freezing in bottom of freezer. freezer is 10 years old.
The defrost drain outlet is stopped up and freezing over.
Remove the bottom basket.
Turn the freezer off.
Look in the center of the freezer just below the cooling coils in the bottom of the freezer.
You will see a water drain trough.
It will be full of ice.
Use a hair dryer to thaw the ice and remove it.
The drain will become exposed.
It must be thawed also,so that you can pour water through it and the water goes all the way to the drain pan underneath.
Sep 18, 2010 | Whirlpool Freezers
Freezer thaws and refreezes daily
The would be a problem with the defrost sticking and staying on too long...change the defrost timer/control board out....
the defrost cycle is making the freezer warm and then it goes off and the freezer refreezes...
most times it fails the other way and does not work at all but sometimes this happens...
Howto Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer thaws then refreezes
I was going to suggest that maybe it is a self defrost issue not shutting off when it should but sine you mentioned this knob, it suggests a thermostat out of calibration - I can rule out circuit problems since you can manually turn on compressor by turning the knob to a cooler position - you will need to have it serviced and change the thermostat which is not cycling whne it's supposed to.
ALSO - do not refreeze foods in your freezer that have thawed ! Throw them away !!! Normal freezer temps should not be warmer than 10F, the normal temps are 0F, and optimal recommended temp -10F (for hard ice cream) and to allow better recovery in case of power failures.
Refrigerator section no warmer tan 40F.....optimal recommended 34F.
Oct 02, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice-maker thawing-refreezing into block of ice
Your defrost system may be out on this unit.
Aug 13, 2009 | Refrigerators
Defrosts/refreezes
IF YOU TAKE THE BACK PANEL OFF INSIDE THE FREEZER YOU WILL FIND A PIECE OF METAL UNDER THE EVAPORATOR COILS IN MIDDLE OF THIS METAL PAN IS A HOLE THAT LEADS THE WATER TO THE BOTTOM OF THE REF FOR EVAPORATION THE HOLE IN THE PAN IS PROBABLY PLUGGED TAKE THE ICE OUT AND CLEAR THER HOLE
Aug 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water does not drain from the Freezer during the defrost cycle
hi thanks for the question the drain hose goes to the underneath by the compressor thaw out the freezer and clean the drain hose this will solve the problem thanks the appliance doc
Sep 12, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Whirlpool GB2SHKXL Bottom Freezer Refrigerator Logo
154 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
