Question about Samsung Eternity Cell Phone
My samsung eternity loses calibration and doesnt properly pick taps. Calibration only moves twice then nothing u can tap it forever. plz help
  • 268 Answers
When was last time did u do a software update? Pls hook it up to ur PC suit and check if it needs any software update. download the update and see.
If no updates available then try soft reset.
Posted on Jul 31, 2010
Nextbook 8 SE touch screen not as sensitive, have to tap items twice
It might need calibration. There is usually a setting in the display to calibrate the screen. Follow the instructions and see if it helps.
Jan 30, 2014 | Nextbook Premium 8 Se Android
No cursor on calibration screen?
how silly are you.
why dont you do what he tells you. TAP THE CENTER OF THE CROSS.
F......I....
Apr 19, 2017 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
How to fix screen calibration on the phone?
Go to Menu>Settings>Phone>Calibration
Note: it doesn't always calibrate on the first touch on each point. It might take you many tries to get it to move to the next point.
It is best to do this operation with a Q-tip, which resembles a finger to the Eternity's software more than a sharp point, but is also more accurate than a finger.
To test the calibration, dial *#0*# and press "9"
If this did not fix your problem, or you think you have a hardware issue
Feb 28, 2011 | Samsung Eternity Cell Phone
The calibration on my samsung impression was way off so i used the unlck code *2767*3855# the phone shut down and restarted and at the calibration screen tapped the center of cross many many times cross...
OK..your touch screen was jammed or not working and you did reset via code *2767*3855# then the phone restarted with the calibration cross....you tapped the cross but nothing is happening.......what to do? first shutdown the phone remove the battery for 30 sec also remove the simcard put the battery again start the phone when the calibration screen pops up tap on the cross here you must feel the tapping is working by feeling a light vibration of the phone.....then tap on the lower bar of the screen which has color (light gray) different than the calibration screen the cross will move to another corner......repeat this for all four corners then you should see and OK on the bar to save and exit to the normal screen........done
Jan 03, 2011 | Samsung SGH-A877 Impression Cell Phone
The screen on the Eternity does not properly pick up where a tap has occured on the screen.
You may need to recalibrate the touch screen. If you are able to get into the Menu screen, select:
1.)Settings
2.)Phone
3.)Calibration
Follow the steps from here and you should be set.
Hope this helps!
Jun 13, 2010 | Samsung Eternity Cell Phone
My touch screen doesnt respond properly. What could be the probable issue?
tap start>setting>system>screen>align screen, the calibration starts tap on center of +
May 20, 2010 | HTC Touch P3450 Smartphone
I can't dial up , and the keys are skiping
try to calibrate the phone's touch screen:
go to :
menu
settings
display and light
calibration.
just tap on the target
and if it will not work call samsung tech support
Mar 18, 2010 | Samsung Eternity Cell Phone
I found message ' tap the centre of the target repeat as the target moves ' in samsung d980 how can i solve this problem thanks
Hello!
Dont worry about it , it's just the calibration wizard.Tap the centre of the target (the cross) with the touch pen (you'll have to do it more than once befor finishing the calibration)
Oct 21, 2009 | Samsung SGH-D980 Cell Phone
I have a samsung instinct, and i am not aware of any water damage. But my phone turns on, but when i touch it, it doesnt work! i have to touch it about 100 times for it to actually press 1 button. What...
It also might need calibration.
Tap Settings (100 times), General (100 times), then Calibration (three times).
Then just follow the onscreen instructions.
Dec 03, 2008 | Samsung Cell Phones
Calibration of my MobilePro off
We've put together some useful tips on calibrating your MobilePro * When calibrating your touch screen be sure to use the same amount of pressure that you apply during normal use. In general, the lighter the better. This allows the screen to recognize taps consistently. * When calibrating your touch screen hold the stylus over the calibration point until it moves to the next point. Holding it for this period will lead to greater accuracy than just tapping the spot quickly. * When calibrating your touch screen support the screen from the back with your other hand. Try not to grasp the screen from the side with your thumb on the front. * When calibrating your touch screen do not let anything other that the stylus accidentally touch the screen. For example, don't rest part of your hand on the screen to help steady the stylus. * Once you've completed the stylus calibration, be sure to perform the double tap calibration as well. This will ensure greater accuracy.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Samsung Eternity  Cell Phone Logo
586 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
