Question about Dishwashers
Fphd2491 frigidaire dishwasher had power loss, and now all cycles are lit up when you try to select one,,,,any ideas
SOURCE: Frigidaire dishwasher no power
I SUGGEST checking door switch fisrt
Posted on Feb 07, 2008
rroath49
  • 35 Answers
SOURCE: Frigidaire stalled dishwasher
do you here any relays or the motor run? if not perhaps the fuse or circuit breaker has opened.
Posted on Jul 30, 2008
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Posted on Feb 11, 2009
vickygomar
  • 460 Answers
SOURCE: Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
Posted on May 15, 2009
SOURCE: I have a Blanco Dishwasher
Try unplugging it from the wall socket and leaving off for about 1 min then plug in and turn back on
Posted on Aug 14, 2009
Stuck on washing cycle
Thank you for your post, Patrick Chow!
From my understanding your Frigidaire dishwasher is getting stuck in the washing cycle. Sounds like you may have a possible issue with a sensor or control panel. I would suggest performing a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for approximately ten minutes. If you continue to experience problems with you dishwasher not cycling I would recommend reaching out to a technician for a diagnosis to be completed. The technician would be able to pinpoint the cause of the failure and complete repairs. Hope this is helpful. -Matt
Nov 17, 2014 | Frigidaire Washing Machines
Frigidaire FPHD2491 electronic buttons not working. Only China/Crystal cycle will light up and can be selected. All others do nothing. I checked the control lock and it does nothing. seems like the...
Hello bamspry - From what you are describing if only the China/Crystal icon is working, then the dishwasher could possibly be experiencing a communication problem coming from the main control panel or wiring failure. If I was in your position, I personally will recommend consulting a professional to move forward accurately and to assist with the repair(s).
Feb 24, 2013 | Frigidaire FPHD2491K Builtin Dishwasher
Frigidaire dishwasher shuts off mid cycle
Hello - From what you are describing it appears that the unit is attempting to run the cycle, but the wash motor is not coming on. Either the wash motor has failed or there isn't any or isn't enough power supplied to the wash motor. I personally recommend contacting a service provider to accurately diagnosis the dishwasher and to assist with the repairs.
Feb 22, 2013 | Frigidaire Gallery FGHD2433KW Fully...
Frigidaire dishwasher model pldb998ac1
If you use salt, maybe that needs refilling. Can't think what else would be low
Nov 08, 2017 | Dishwashers
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Won't start, can't change wash selections
hi there,
can you tell me if you can hear the motor running? if not
did you trip the house breaker? if not
can you open the door? if not
it's the door latch; if yes
is there water on the bottom of the dishwasher? if yes
you are not draining and the dishwasher lost power; if not
the timer is not advancing to the next cycle
let me know.
Sep 28, 2008 | Frigidaire 24 in. FDB679GF Built-in...
Frigidaire 24 in Stainless dishwasher wont start
Next is to check the door switch for power.You should have 120Volts ,if you do ,then you may have blown the small fuse that attaches to your control board,its attached by a clip and runs to the your door switch.NOTE :Only follow the above if you have at least 1 led that is lit up on your panel.If you don't then you are going to have to check your power supply once more.
Aug 11, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Mar 28, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Feb 05, 2008 | Dishwashers
Dishwashers Logo
209 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
