Thermostat keeps resetting to 82 degrees when it's set on cool. it will do this after the power has been out, but now it's doing it about three times a day now without the power being out.
2 Suggested Answers
SOURCE: room temperature has not changed since hooking up new portable a/c
I bought mine last summer. Used it once or twice. Hooked up it today and it is a piece of ****. Been at 34celsius for the last 4 hours and still not even close to being cool .. and its in my bedroom
DON'T BUY DANBY portable a/c -----------
Posted on Jun 07, 2008
For the past couple of weeks, the freezer will loose its cool enough to thaw or partially thaw what is in it, but two or three hours later it will be frozen again. Keeps going back and forth. Ideas?
possible problem thermostat or freezer setting to close to one setting
reset to a bigger number as the numbers work opposite to the fridge settings ( 1 is close to 0 degrees and 20 is -20 degrees ) where as in a fridge 1 is close to 0 degrees and 5 is + 5 degrees above 0
Sep 10, 2016 | Refrigerators
One year old Amana ASZ 16 (replaced inside and outside units last year) - works fune until the last two weeks, now home at 5pm, reset the thermostat from 82 degrees to 76 or 77 to cool off house (which...
Sounds like the system is either over charged with freon or under sized. Call the same people back out ask for a supervisor to come out and check out the system any other company will charge you.
Jun 10, 2011 | Amana Heating & Cooling
My nonprogrammable Honeywell thermostat th5110D is no matching temperature settings (desired and actual). There is about 4 degrees difference. I have looked at the manual and reset the system and changed...
Your thermostat is reading the temperature where it is located.
If it is located next to a heat source maybe it is picking up that added heat .
Try relocated your thermostat
May 30, 2017 | Heating & Cooling
My white-rogers 1F81-261 model thermostat keeps rgoing back to a 62 degree setting after the furnace kicks on at a setting of 72 degrees. I have reset the program, but that doesen't seem to help. What can...
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set to
HEAT or COOL, momentarily press HOLD button. HOLD
will be displayed. Use UP or DOWN to adjust the temperature.
The thermostat will hold the room temperature at the
selected setting until you press RUN button to return to
program operation.
This is on page 6 of the manual
Link: Installation Instruction
Feb 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Cooling limit on th320u
the cooling setting will not go below the heating setting. lower the heating setting so you can lower the cooling
Jan 16, 2018 | Honeywell Electronic Programmable...
Our TH8000 Series Programmable Thermostat keeps flashing "change filter" even after we changed it. The guide book does not show how to re-set so the flashing stops.
try holding the filter button in for three seconds, if that doesn't reset the timer try the filter button and the temp. up button at the same time for three seconds.
Mar 30, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
178 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
