The power lite goes on and off and screen wont lite up
  • 700 Answers
Telepathy do not work, you need to state what computer brand, what model, what monitor, meantime follow that procedure:
1. switch off computer and monitor
2. disconnect all cables on the back of the computer and monitor
3. re-connect all cables
4. re-power your monitor (is light on? any message on the screen?)
5. re-power your computer - is there any activity on the screen?
if there is no joy:
6. change monitor for known working one and check for display,
7. connect your monitor to known working computer,
is there a display on your monitor? is there a display on borrowed monitor?
if there is display on borrowed monitor, that mean that your monitor is at fault, especially if your monitor do not work on another machine.
if neither monitor work on your machine but both work on other, this will indicate video card at fault (most probable) or motherboard, or memory all of these need to be assessed before further proceedig can be advised.
before further help is sought, state clearly what computer, motherboard type and model (all in one?), video card model, monitor model
if you find this advice helpful, vote for me
Posted on Jul 31, 2010
My laptop will turn on but the screen wont lite up
The display fiber is lose or the leds brew, or a failed motherboard.
Oct 05, 2014 | eMachines E Machines E627 Laptop Computers
My screen wont turn on
have you been already clean the memory using with an eraser.
Jul 10, 2012 | Acer Computers & Internet
My ds lite power gooes off as soon as you turn it on
The bottom screen flashes an then the green light goes off new top screen is needed very common on ds lite i repair them for a living an can sort yours for about 18 quid
Simon
Dsdoc
Nov 26, 2011 | Nintendo DS Lite Console
NDS lite has the power(green lite flashes), but screens wont lit
When you switch the DS lite on you should notice that one of the screens flashes... if thats correct then the screen that doesn't flash is the one that will need replacing which, I would assume is the upper screen as judging by what you say has a damaged ribbon.
Regards,
SOD69
Feb 10, 2010 | Nintendo DS Lite Console
My ds lite wont power on how can i fix it?
One of you're screens is broken or the F2 fuse has blown.
Check youtube for a video on "how to check my DS lite F2 fuses" there are several available that give step by step guidance on how to do this.
Having checked these (and replaced blown ones) and you're screens are still not working then it is a screen that has blown.
If the bottom screen flashes for a split second when you turn it on then it is you're TOP screen that has blown and needs to be replaced. If it doen't flash then it is you're bottom screen that is broken and needs to be replaced.
Sep 10, 2009 | Nintendo DS Lite Console
DS Lite wont power up, just flickers and goes out
ur problem with top screen.the strip may be damaged change the top screen .
Aug 29, 2009 | Nintendo DS Lite Console
Ds lite battery wont charge i have charged it overnight but nothing the green light goes on but that is it
If the green light is turning on and the screens are staying blank it is a problem with he L2 fuse on the motherboard (located just below the power button).
This can be replaced if you are handy with a soldering iron. If not drop it to a local repair shop it can be fixed for about €20.
Aug 26, 2009 | Nintendo DS Lite Console
Wont turn on
I'll quote GBATemp here:
symptom:
the ds lite powers up for a brief instant, but then shuts off
potential solution:
disassemble the lower shell and check the connections of upper and lower displays (all three flexible cable connections).
You can view the full and detailed guide here:
http://gbatemp.net/index.php?showtopic=98240
GMAC
Jun 14, 2009 | Nintendo DS Lite Console
Ds lite comes on for a sec when charger plugged in then it goes of unit does not come on or charge
Hi three things come to mind, you dropped it but usually they wont admit it (dont go mad they usually all break when you do) if it rattles the capacitor under the power switch just fell off (common you have to solder it back on) if not that you replaced the bottom screen and forgot to insulate the metal of the back of the screen against the circuit board and blew either the f1 or f2 fuses (Replace them if you did) last thing i wont go into if you havent pulled it apart if you have reply and i will tell you Good Luck
May 20, 2009 | Nintendo DS Lite - Onyx
NINTENDO DS LITE WON'T CHARGE OR POWER ON
Each time you charge your battery, the charge capacity is decreased. After a large amount of charges, the capacity is decreased to an amount only enough to turn on a/the screen(s) for a second. Try getting a new battery.
Mar 02, 2009 | Nintendo DS Console
Computers & Internet Logo
77 people viewed this question
Alun Cox
David Payne
David Payne
