Question about Singer Inspiration 4210 Mechanical Sewing Machine
Thread is a birds nest under fabric
Tension is messed up I'm sure. But I don't have the book to help fix it.
  • evamarcus Jan 10, 2013
    I HAD THE SAME PROBLEM MY SISTER GAVE ME A MACHINE AND IT DID THE SAME THING I HAD THE WRONG BOBBIN IN AFTER I PUT THE CORRECT ONE IN IT WORKS PERFACT
  • Singer Master
  • 7,365 Answers
You can download a free pdf manual at---diplodocs.com
on the first page look to the left for the alphebet letters & find S-- then look for the name singer click on the singer name & it will take you to the second page--on the left toward the middle there is a box that says
most common searches - you will find your model number there- i searched & found it--click on the model number- it will take you to the
third page---they ask you 3 questions about your sewing machine & then let you download the pdf manual
Posted on Aug 05, 2010
The stitches on the underside are looping I’ve retreaded both the needle and bobbin and neither makes a difference
You are getting a thread mess under the fabric? Frequently, this occurs because the top thread is not fully seated in the tension disk.
Install a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread the machine from the beginning.
If necessary, adjust the top tension so the top and bobbin threads meet in the middle of the fabric.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
TIP Avoid Thread Bird Nesting with these Four Tips Stitching Sewcial
Troubleshooting Thread Nesting Sew Toot
Jan 04, 2018 | Sewing Machines
Viking Topez 50
Jan 03, 2018 | Sewing Machines
HOW DO I OIL A VIKING DESIGNER SE EMBROIDERY MACHINE, TRYING TO FIX THE PROBLEM OF BIRD NESTING.
bird nesting is from needle thread tension being too loose
increase the tension up
May 02, 2017 | Sewing Machines
When I sew I have thread bunching up underneath the fabric, I've changed needle size, thread, bobbins and cleaned out around the bobbin holder. I'm frustrated and out of ideas.
Susan--
Easy peasy, once you know the problem and how to fix it. It's called "bird nesting" or "thread nesting" or what I refer to as thread "barfs."
Remove all the thread from the machine.
**ALWAYS RAISE** the presser foot and rethread the top thread.
Verify the top thread path is correct.
Install and thread the bobbin case, make sure it is correct.
Set the top tension to the midway point.
Now retest your machine. Birds nests gone? You may need to tweak the top tension because the factory standard changes due to age and use.
FWIW, problems appearing under the fabric are an issue of the top thread. Thread problems appearing on top of the fabric is a bobbin issue.
What causes Bird Nests Superior Threads
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Mar 25, 2017 | Sewing Machines
Have lots of thread on the under side of fabric
Thread nesting or bird nesting resulting usually from: mis-threading, upper thread not seated completely in the tension disk, upper thread tension too loose. HINT: ALWAYS raise the presser foot when threading the upper thread.
Jan 05, 2017 | Sewing Machines
Stiches at the bottom come out like a rats nest not sewing right?
Generally, thread issues that appear under the fabric are the result of an upper thread problem. What you describe sounds like bird nesting or thread nesting and are usually a result of: mis-threading, thread not being fully seated in the tension disk, and/or upper tension too loose.
Remove the upper thread. ALWAYS raise the presser foot. Rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point between high & low numbers (although this will probably need to be tweaked for your particular machine). Retest your machine. Adjust the upper tension until both threads meet in the middle of your fabric.
FWIW, mis-threading may not be your mistake. I have an older machine that the take-up lever is open at the top. Sometimes, usually when sewing fast, the thread will literally "jump" out of that take-up lever and...instant thread mess... So, if this sort of thing occurs frequently with your machine, try to narrow where the problem originates. With my machine, I "manufactured" a method of closing the opening in the take-up lever. Voila! No more jumping thread!
Dec 31, 2016 | Sewing Machines
Bobbin issues the bobbin thread is bunching up
Check whether it is bobbin thread or the top thread accumulating under the fabric. Generally, if thread problems exist "under" the fabric, it is a top thread issue. If the problems exist "above" the fabric, it is a bobbin issue.
Sounds like a thread nesting (bird nesting) problem where the top thread is globbing under the fabric. Usually, this is caused by misthreading (confirm the thread path), the thread not seated in the tension disk (ALWAYS RAISE the presser foot when threading!), or very loose top thread tension.
Remove the thread. Raise the presser foot and rethread from the beginning. Check that the thread path is correct. Set the upper tension at the midway point between high & low numbers (this is the beginning point for tension and will most likely need to be tweaked for your particular machine).
Dec 11, 2016 | Sewing Machines
I'm getting a 'bird's nest' of thread on the bottom of my stitching...Why
needle thread tension is too light
increase that tension setting
Nov 19, 2016 | Sewing Machines
Pfaff Creative 2 loops on underside of fabric
Although there could be several reasons, this is generally called bird nesting or thread nesting. It is usually a result of loose upper tension, mis-threading, or possibly a needle/thread/fabric incompatibility.
#1--when you thread, make sure you ALWAYS raise the presser foot so the thread seats in the tension disk. And, be sure to change the needle often...
https://lindeegembroidery.com/common-causes-of-birdnests
Nov 12, 2016 | PfaFF Sewing Machines
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
Singer Inspiration 4210 Mechanical Sewing Machine Logo
606 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
