Question about Car Audio & Video
Need a remote control for VM9312, an automobile audio video radio.
    Champion:
  • 227 Answers
You need to let us know what brand or manufacture's is it?
Posted on Apr 24, 2008
On a audiovox vm9312 I lost remote and can't turn
The VM9312 has a volume knob on the unit's faceplate. Just rotate the knob on the left (a little below the optical disc D slot) clockwise to increase the volume. Turn it the opposite way to lower the volume. (If you have the knob set to the maximum volume and then lowered the volume with the remote, you may need to reset the unit; see below.) If you push in and release on this button, you press Enter or confirm a setting when you are in any audio settings menu.
If the volume control isn't working, check if the mute is on. Press once to toggle the Mute. The mute button is just below and near the right side of the optical drive slot.
If you still can't change the volume, check if you have the wiring correct and no shorted wires. Look for damage at the speakers (or evidence of mice chewing on the wires). Also check your audio balance. See the manual page 12 here: http://www.voxxintlcorp.com/docs/common/VM9312/VM9312_OM.pdf . You may also want to try a system reset. (Press and hold the reset button for a few seconds by using the tip of a ballpoint pen in the little opening at the lower right hand side of the faceplate.)
I hope this helps.
May 24, 2013 | Car Audio & Video
Hooking up an amp
you need rca cables, an amp kit from your local audio shop(or walmart). make sure you know which wire is the remote from your radio as it will need to connect to the remote on your amp. most radios have the wiring diagram on top of the radio. Ground(black)/Power(from battery) and remote(typically blue from stereo.
Apr 01, 2010 | Jensen's VM9312 Car DVD Player
Do you know the bypass for this radio vm9312
You can try the procedure for the VM9311TS model (the one I have) - I don't know if it'll work but it's worth trying. Put in a DVD, and let it start playing. Then hit STOP on the remote twice, and enter the code 1264. If you were able to see the actual movie at this point, you'd see a menu pop up. Push down twice, then ENTER. At this point the blue screen should clear and you should see the movie itself. You'll have other options on that menu, like a macrovision option to allow you to see burned DVDs. Set what you like, then on the remote, hit SYS SETUP twice to lock in your choices.
Nov 13, 2009 | Jensen's VM9312 Car DVD Player
Sound to radio but no sound to cds or dvds
I dont know what car you've got but,You need to hook up the blue amp remote wire for the antenna, when you switch to radio the antenna signal turns your car amplifier on and you get audio and when you switch to cd/dvd it switches it off because your car is wired that way, its a common issue with Mercedes etc.
May 10, 2009 | Jensen's VM9312 Car DVD Player
Just installed vm9312
go to the radio press setup on your remote then press 543210, a secret screen will pop up press the hammer and skrewdriver,u will see brake overide put it on the on position,thenpress the X at the bottom of the screen,then your all set.
Jul 08, 2008 | Jensen's VM9312 Car DVD Player
No sound except for receiver
disconect the blue wire from the wireing harness and conect it with the blue with white u will not need the all blue wire
Jun 05, 2008 | Jensen's VM9312 Car DVD Player
Jensen vm9312 car dvd player problem
you must press the menu button on the remote control
Mar 23, 2008 | Jensen's VM9312 Car DVD Player
JENSEN VM9312 CAR DVD PLAYER HOW
go to am/fm
then open the settings screen
next on your remote type 5,4,3,2,1,0 listening for each beep
a new screen should come up
after that look for brake override
Mar 19, 2008 | Jensen's VM9312 Car DVD Player
How do i do to bypass my jensen vm9312
go to www.ecoustics.com then click on forum at top click car audio then multimidea. and read Teir are bypass codes for several models here.just have to look for them.
Dec 18, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
48 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
