Question about Dymo LetraTag 2000 Printer
Printing is patchy and not readable - Dymo LetraTag 2000 Printer
How do I fix a grainy/ patchy jumping/skipping dvd.
Hello, Bloody_dark -
Often those who rent DVDs or borrow them from the local public library mishandle them and do not know how to handle them properly.
From your question, it seems the DVDs are either scratched or dirty (possibly with food residue.)
This website gives step-by-step instructions on how to clean the readable side of a DVD:
https://www.wikihow.com/Clean-a-DVD
If, after cleaning, the DVD still is grainy, patchy, skipping, etc., it is probably scratched.
What I do when I have a rented or public library DVD which is scratched, I return it with a "sticky note" attached to the DVD box stating it is scratched and that I properly cleaned residue from the readable side of the disc, so that the rental business or the library staff will know that the DVD is damaged and can choose to replace it.
There are ways to remove scratches from DVDs, but I do not recommend anyone try those steps if they do not own the DVDs themselves.
Note: I am a librarian by profession and have seen firsthand how people mishandle DVDs. I'm from the 45-rpm and 33-rpm vinyl record generation. We learned how to properly handle those vinyl records so as not to scratch them. Bottom line: We were taught to only handle the vinyl records (and subsequent CDs and DVDs) by their outer edges. For CDs and DVDs, they can be held between the thumb and forefinger, along the inside and outside edges.
Jan 10, 2018 | Polaroid Televison & Video
Epson nx125 black faint patchy
Most likely this could be because of Faulty Printhead/Cartridges in your printer.
If you have replaced Black and still find printing Quality issue, the Printheads need to be cleaned.
My suggestion is to click on the link below and the website is helpful in dealing with all type of Epson printer issues.
Click here -> Printer Issue Troubleshooting
Regards,
Suhail
May 20, 2012 | Epson NX125 AllInOne InkJet Printer
S605 ink printing patchy
A firmware update for your model addresses print quality issues. Please visit the Lexmark website to download and install the Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
Try to print again to verify that the print quality has improved.
Should the problem continue, it could be that the printhead itself is the problem. Please contact Lexmark Technical Support Center for assistance.
Feb 04, 2012 | Lexmark Interact S605 All-in-One Color...
When i am printing it is all too red and very very grainy and patchy which cartridge needs changin
You should be able to print a test page which will show which carts need changing. A print head clean could also solve the problem.
Without knowing what make/model of printer and OS cannot advise any more.
Jan 08, 2011 | Computers & Internet
Its printing patchy and ghosting
it will yes. I know with fusers and xerox you can usually reset the fuser. When servicing the machine the techy will do this for you:)
Nov 18, 2009 | Xerox Phaser 7400DN Laser Printer
I have just changed my black ink cartridge however still patchy
Typically you do not have to change the color cartridge when you replace the black cartridge.
As far as the spotty printing, it sounds like you have some clogged nozzles caused by the lower quality of ink in refilled or aftermarket cartridges. There cartridge inks may not be up to specification. This is especially true for the ultra fine printers.
To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity at least twice followed by the alignment utility. This should clear up the problem with the spotty and washed out printout.
Let me know if this solves your problem otherwise we can explore other solutiions. For the record, which printer do you have?
Please rate this solution. Thanks.
Oct 07, 2009 | Office Equipment & Supplies
Incomplete patchy printing
Please try to do a printer head cleaning. You can do it by getting a small earbud and soak it with a small amount of water. Or try to adjust it by doing an alignment. Usually, the printers have this functionality. Please refer to the user manual.
Aug 13, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
New ink installed but patchy faded printing
You have to recalibrate the print heads. The printer should have a utility to do this. Or do it from the properties pane on the printer's icon.
Dec 02, 2008 | Canon Office Equipment & Supplies
Patchy printing
Problem is with either with cards or with print head's mechanical alignment. Try with some different cards and for head get it tested by some authorised service person.
Nov 28, 2008 | Evolis Pebble 3 ID Card Printer Package...
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
