Question about Pioneer DEH-P6700MP CD Player
I have a Pioneer DEH-P670MP. Battery was disconnected (changed out heater core). Now that battery is reconnected, it gives a series of five beeps five times (twenty-five total beeps) EVERY time the ignition is turned on, and about every half hour of continuous driving thereafter. How do I re-set the unit to make this stop (other than with a three pound hammer) ?? Thanks !!
  • 2,359 Answers
The only warning tone this head unit can generate is a FACE IS STILL ON after the the ignition key is off.
Please check the back side of the face and the front side of the deck for damage.
The sensor switch can be damage or dirty.
You have to check this yourself carefully.
The sensor switch is very small.
If all else fail,try to turn the WARNING TONE OFF by disable this feature,
OPEN HERE and follow exact instruction on SECTION 9 PAGE 41 (middle / right)
The correct way is to fix the micro switch but disable the WARNING TONE will be the faster way to get the job done.
Posted on Jul 31, 2010
  • bearbvd Jul 31, 2010
    Warning on the head unit is off. The 'remove face plate' beep is NOT what I am getting.
    My bad--the beeping is coming out of a CD-IB100 I-Pod adapter which is connected to the DEH-P670MP head end unit.
    Disconnecting and reconnecting the I-Pod from its cord makes no difference.
    The repeated beeping DID start after the sequence of events originally described.
    Thanks !!
  • Vincent_G
    Vincent_G Jul 31, 2010
    IP-BUS cable is off or damaged.
    check IP-BUS ends for bad contact.
    Reprogram the head unit per instruction on SECTION 3 (3/4 into this instruction)
My Pioneer DEH-7500MP won't come on after having my truck battery disconnected for about a week changing the clutch any suggestions?
probably will need the anti theft code to reinstalled to get it going again after the battery was disconnected.
Apr 24, 2015 | Pioneer Car Audio & Video
Do you have to remove dashboard on a 1990 geo storm gsi to remove and reinstall the heater core. can you give me the step by step if the dashboard does not have to be removed.
log in to alldata.com and read that? its there?
anyone can,
  1. Disconnect the negative battery cable. Drain the cooling system.
  2. remove core hoses passing thru fire wall.
  3. Remove the three duct mounting screws.
  4. Disconnect the duct between the blower assembly and the heater unit.
  5. Remove the five screws attaching the mode control case to the heater core case.
  6. Remove the mode control case. Do not remove the link assembly.
  7. Remove the five screws to separate the two halves of the heater core case.
  8. remove the core.
Feb 24, 2015 | 1990 Geo Storm
How do you bypass the heater core on a 1998 Ford Bronco 2?
Disconnect both hoses from the core and one of them also from the engine. Hook the other one back to where you took one off, making a loop. The picture below is not a bronco, but gives you the idea.
By the way, your core is easy to replace. It almost pops right out from under the dash. I ahve included picture below.
Remove and replace heater core procedures:
  1. Disconnect the heater hoses from the heater core tubes and plug hoses.
  2. In the passenger compartment, remove the five screws attaching the heater core access cover to the plenum assembly and remove the access cover.
  3. Pull the heater core rearward and down, removing it from the plenum assembly.
To install:
  1. Position the heater core and seal in the plenum assembly.
  2. Install the heater core access cover to the plenum assembly and secure with five screws.
  3. Install the heater hoses to the heater core tubes at the dash panel in the engine compartment. Do not over-tighten hose clamps.
  4. Check the coolant level and add coolant as required. Connect the negative battery cable.
  5. Start the engine and check the system for coolant leaks.
Nov 09, 2010 | 1988 Ford Bronco
Find the wirings for a pioneer premier DEH-P780MP
sorry to tell u this but u going to has to buy this cable fron pioneer , cost about $20-$35 , or u can go to a tv shop or car stereo places and see if they have one for less
Apr 15, 2010 | Pioneer Premier DEH-P670MP CD Player
System problem (pioneer deh p670mp)
there is usually a small hole about the size of a pencil tip on the face or on the subpanel (behind the face) . it will be unmarked. you can also reset it by disconnecting the battery for a few minutes.
Apr 14, 2010 | Pioneer Premier DEH-P670MP CD Player
After reconnecting the car battery, the radio would not turn on
The pioneer has a small protection fuse in the back of the radio, alot of time when it catches a power spike, it will blow to protect the head unit. It should be plugged in the back of the radio under the main plug. Hope this helps.
Aug 20, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
How do you get the Pioneer DEH-P670MP car stereo cd player off of mute?
hi there
to fix this press and hold the source button till unit turns off the source button switches from CD - radio...................once your unit powers off........press and hold the function button down till the clock appears in display you should also hear a beep when this happens.........press the function button repeatedly until the telephone feature appears now switch by pressing the skip button to ATT (Attention) once this is done press the source button to power on the pioneer unit simply turn up the volume and problem should be solved......
hope i was able to help
Feb 21, 2009 | Pioneer Premier DEH-P670MP CD Player
Pioneer Premier DEH-P670MP Keeps shutting off
This is an Internal Fault and needs to be Sent in for Repair or Replacement
Jan 03, 2009 | Pioneer Premier DEH-P670MP CD Player
Pioneer Premier strikes again
On most pioneers you press source to turn the radio off (while the car is still in the run or ACC positin). Then press and hold FUNC to enter the menu. Then use the directional joystick to make the changes.
Dec 08, 2007 | Pioneer Premier DEH-P670MP CD Player
DEH-P670MP Display goes from regular to extra bright, then back
Your deck has "reverse mode" activated. To turn it off, just turn off the power by holding the source button. The press the preset "5" button. When you turn the deck back on, reverse mode should be disabled. (If this doesn't work, try the same procedure with button "6". One's for reverse mode, the other for demo mode, but I'm not sure I remember which is which).
Jul 01, 2007 | Pioneer Premier DEH-P670MP CD Player
Pioneer DEH-P6700MP CD Player Logo
70 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
