Question about Coleman Mach 15 Air Conditioner
Hello, I've recently purchased an old camper (84) with a coleman mach series roof unit. My question is I need a replacement shell (hard cover plastic body) for on top of the roof. It was damaged from a branch falling on it. The rest of the unit looks fine but rain water seems to have gotten in. I have it covered now with a tarp. Please write if you need more info, Thank You for your time.... Larry Santos,
  • Coleman Master
  • 6,674 Answers
You can purchase one from any RV dealer usually, and they may even have some used ones cheap in their spare parts dept. Make sure if it's used, that it's not to brittle from the sun, otherwise you'll be replacing again.
Posted on Aug 02, 2010
Coleman Mach 48000 series roof top A/C in my camper & recently it's been dripping heavily inside the camper. We looked at the top & inside for a clogged line & can't find anything, suggestions?
I had the same problem but it wasn't a clogged drain line, it was the gasket between the roof of the camper and the AC unit. The gasket had shrunk and pulled apart allowing rain water in. To make sure you don't have a clogged drain line when using the AC do you notice water dripping off the camper anywhere besides inside? You should have some drips somewhere on the outside.
Jul 18, 2017 | RVs
Why is campers inn saying I need to replace my Coleman Mach 3 with a Coleman Mach 8?
we would have no idea . perhaps if you contact Coleman they can tell you .
Feb 15, 2017 | Coleman Heating & Cooling
How do I fix the drain lines from my rv roof?
have to remove cover to access drain lines to clear
Jun 10, 2014 | Coleman Mach III Air Conditioner
Btu of coleman 7830-901
That should be a 30,000 Btu unit. Its been a while since I worked on them. The 78 is the series or model, the 30 is the capacity or btu's and the 901 indicates it is a Copeland compressor.
Jun 09, 2014 | Coleman Air Conditioner Shroud Rv Roof Top...
Coleman mach rv roof ac, the fan comes on but the compressor doesn't, i've replaced all capacitors and stll is not comming on, how do i check voltage to the compressor to maske sure i have pow
At the compressor connectors you have a live and a neutral phase. The live usually goes to a ptc relay starting mechanism which you can test with a meter. If you can disconnect the relay and check the windings of the compressor from one pin to the other two it will tell you if the compressor is open circuit. It is more often than not an overload fault.
Apr 23, 2012 | Coleman Heating & Cooling
Contensation leaking into camper
Check on roof, look under at base of AC unit for 2 knob like things sticking down, they are drains. use a piece of wire or small stick & try to poke inside there. You might have to look hard to find hole. Pay attention to run off on roof, if not as much as usual, that's a good indication they are plugging up. If too hard to get to, remove 4 screws & pop cover off, but watch for wasps or yellow jackets before you do.
Aug 06, 2009 | Coleman Heating & Cooling
COLEMAN MACH 3 MOUNTING ON INSIDE OF CAMPER NOT ALIGNING WITH MY
Did you purchase a new Ducted Ceiling Unit with the Upper Unit air conditioner? If you are replacing an older mach 3, the ducted ceiling packs are not compatible and you will need to purchase the ceiling pack as well. The ducted ceiling pack part number for the 8333 series Mach III AC is below.
1. Heat/Cool Air Distribution Box - 8330B735
2. Cool only ADB - 8330A733
3. Wall Thermostat (if needed) - 7330G3351
Hope this helps.
Jul 01, 2009 | Coleman Heating & Cooling
Delaminated TOP on Coleman Camper
If you have to fix it yourself out of warranty i suggest this ,
REGLUE ALL THE BITS THAT ARE COMING AWAY , THEN FIND A GLUE THAT IS SPREADABLE LIKE A THIN PAINT AND COAT THE ENTIRE ROOF MAKING SURE THAT IT GETS INTO ALL THE CRACKS , LET IT DRY .
THEN PAINT THE ROOF WITH A THERMAL MEMBRANE COATING . This will insulate the camper from the sun and keep heat in during colder times , the thermal paints are not cheap but they do work . Hope this will help you
May 05, 2009 | Tools & Hardware - Others
ROOF TOP AC UNIT ON COLEMAN POP-UP LEAKS
Does water drip out of unit on the roof while running ? If you look under the unit on the roof, you should see one or two little drains sticking down., that may be plugged up. Piece of wire or something and poke in the holes on the sides of those drains to make sure they're clear. Usually there is a plastic/nylon pan on roof unit to catch that moisture, and drain it off. Could be overflow because of the plugged drains, or I have seen the odd one crack but not too much recently, mostly back 5 yrs ago or so they had a run of them.
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Coleman Mach III 13,500 btu ducted roof air conditioner
Did you plug upper unit (on roof) into lower control unit (inside). Not to insult you, because i've done it myself, in a rush situation. Breaker on? Sure you didn't mix up any wiring?
Jun 29, 2008 | Coleman Mach III Air Conditioner
Coleman Mach 15 Air Conditioner Logo
259 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
