Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Red led on power supply board comes on after I turn power on.
I had resoldered all my connections on the board (use to intermitte real bad) now it does not do that but I get the red led on after about 3 seconds. I need to know if I can disconnect other boards to find out if they are loading this down. I can not find a print to this tv anywhere and believe me I have called pioneer, sams,and checked every manual company on the net. the tv did turn on once after resoldering and would not shutdown. after I turned it off it would not turn on again. I checked all large caps and they check good. It could be the conversion board but with out a print Im stuck. any one know how to override the protection circiut? If I get too much rf I wont blame anyone but myself. thanks
    Problem Solver:
  • 6 Answers
I have the service manual for the set.
email me and we'll work something out.
las dot trampas at gmail dot com
Posted on Oct 07, 2008
My pioneer pro-710 hd 64 in. is starting to shut down (picture and sound goes away,but still is on
Your Pioneer 710HD has the classic cold solder joint problem endemic to all of this series of Elite CRT RPTV. The power supply - PS - board needs to be resoldered virtually completely. It's a time consuming, tedious job that if you get wrong, who knows what could happen when you turn it on again? So don't even think about resoldering it if you are an amateur at the soldering process.
I do this job every day then run it out in my test 610HD - same series - and then equip your board with a lifetime warranty on the resoldering work I have done. Please contact me directly, google Mr Bob and calibrations and Image Perfection. Unless you do resoldering every day as a professional assembler or are an experienced repair tech, I cannot in good conscience advise you to do this yourself. Far too much is riding on it.
However, if you are highly experienced at soldering, resolder everything but the heat sinks, the test points, and whatever has already been resoldered and is still glossy and gleaming, like fresh resoldering is. The solder used in the original assembly of that board was far too thin, which results in these cold solder joints.
And don't do it part way! Many joints that are not bad now will be soon, trust me, and if you have only resoldered just the ones that are bad now - the early ones to go out - and continue to use it, you make your board that much more susceptible to the far more dangerous ones that happen later on, which can damage boards downline from the power supply board.
I am the only repair person I know of offering a lifetime warranty. Even Pioneer does not do that. In fact I have permanently corrected many rebuilt Pioneer boards when they've gone out later. Pix are available at www.avsforum.com
In your case chances are you have not heeded the warning signs of cold solder joints: intermittent ops, blue flashes, fluctuations in the brightness of your pic and other instabilities.
In the case where one of these units turns on then turns off again - LED in front goes green, then immediately back to red before a picture has a chance to appear - it's "going into protection". Chances are something downline has now been damaged because of the instability of the PS board, which is responsible for powering up the entire unit.
What I would recommend if it's "gone too far" and the unit will not stay on anymore, is a troubleshooting session with me on the phone, which is something I require before allowing a PS board to be sent to me for resoldering if the set's not staying on. Luckily, these sets were designed with on board diagnostics that can be read by technicians from far away.
If it goes green then stays green but no pic appears - even graphics like the Menu - then one of the cold solder joints that powers up the section that powers up your picture has opened up and is now staying open. This has always been remedied 100% by the resoldering process.
If it powers up correctly upon turnon from dead cold, DON'T PUSH IT! If it still has intemittencies, it's in a very precarious, dangerous condition. Many sets have been run past their warning signs, and by the time I get notified and can lend a hand, they are considered totalled and are abandoned. Don't let that happen to you. RUN IT FOR NO MORE THAN 40 SECONDS, and power it down again and unplug it. DO NOT ALLOW IT UP TO NORMAL OPERATING TEMP AGAIN - EVEN ONCE - UNTIL FIXED PROPERLY.
If it turns on from dead cold and works properly even tho intermittencies have happened in the past, this is the best case scenario. It means it can be resoldered properly and you'll be home free. Or sent to me for resoldering if you are not a highly experienced repair tech or assembler, in which case you'll get my lifetime warranty on the resoldering work..
Mr Bob510-278-4247bob@imageperfection.com
Jan 23, 2012 | Pioneer PRO-710HD 64" Rear Projection...
I have a pioneer 710HD elite that is stuck in standby mode. The red power light is on, but it will not come out of standby to turn on with the green light on. Thoughts?
power supply board.
entire unit.
FIXED PROPERLY.
Dec 18, 2011 | Pioneer PRO-710HD 64" Rear Projection...
IT DOES NOT TURN ON, NOT EVEN THE RED LED LIGHT
On the power supply board is a thyresistor will be up on front of board resolder this should fix problem. Ive fix alot of them that have same problem Part acts as a heat conductor switch they were not solder in Good so after awhile solder is bad.
Nov 19, 2009 | Akai PT5250A Television
Sony 50 Wega LCD flashing red light
Hi
How many times is the red light flashing? The number of times the red led blinks means---
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
  • No blinks(Unit is dead) - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
No picture or sound
Remove the rear panel. With the TV on you should see a red LED near the center of the PCB. There should also be 5 green leds, 3 to the left a 2 behind. If there is no red leds, check the fuses. If there are no green leds or maybe 1 or 2, disconect PSD5. It's a connector on the left side of the power board that connects to the audio board. It's the 3rd on fro the back. It's labled. With that disconected, turn on the set and look for the green leds. If all 5 light, the power supply is OK and you have a problem beyond that. If they don't all light you have a bad power supply.
Jul 21, 2008 | Hitachi 50EX20B 50" Rear Projection...
Pro-710hd
This has been successfully answered, but here's some more information:
I am the only repair person I know of offering a lifetime warranty. Even Pioneer does not do that. In fact I have permanently corrected many rebuilt Pioneer boards when they've gone out later. Pix are available at www.avsforum.com.
Apr 28, 2008 | Pioneer PRO-710HD 64" Rear Projection...
Not turning on
Power supply board pull,then remove original solder on 5 volt
regulator pins then resolder + replace 4 amp fuse........T.
Oct 25, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
4a fuse blown
1)pull chassis.remove power PCB==the one with large heatsink w/convergence IC's on it 2)Observe four regulators also on same heatsink Remove solder from all reg. pins-clean PCB 3)Resolder 4)solder any/all bad connects 5)replace 4 amp fuse 6)reassemble & test
Oct 05, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Power Problem
Most often this problem is caused by convergence ic's. STK392-110. Sometimes cause is vert. i.c. Also, many times it is from bad solder connections on circuit board. In any case, short of unplugging unit to reset, there's not much you can do without help from repairman.By(1)removing rear cover,(2) unscrewing 2 screws holding chassis in and(3) undo all clips and wire ties holding wiring in place. Small board on (R) side is conv. Slide entire chassis towards you. Remove 3 screws from small conv. board.Remove and mark 5 plugs and 4 black jumper plugs to free board. Look at bottom of board for rings around solder joints at pins of main amps.(STK392-110). Resolder or replace amps and reinstall board. Reconnect 4 jumpers and 5 plugs in same order. Power up unit and hit magic focus. This is most common repair.
Mar 06, 2007 | Hitachi FDX Series 43FDX10B 43" Rear...
Television Not Powering Up Intermittently
Hi Check the standby power supplies, then the run supplies, then the h-driver circuit, then the H.O.T and flyback circuit. And in general look for bad transistors, diodes, capacitors, resistors, faulty solder connections and etc. BE ADVICE!!! if you don't have any repair experience and electronics knowledge leave it. Take it to an experienced tech or a service shop. Good luck
Mar 21, 2006 | Zenith D52WLCD 52" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
63 people viewed this question
Top Pioneer Televison & Video Experts
Electro Med Services...
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
