Do not try the towel trick, it is only temporery and you could fry your xbox, reset your firmware afterwards by pressing and holding the xbox button until it boots up
That means your xbox is overheating... You can call Microsoft and aske them about it or if you're out of warranty you can fix it yourself by replacing the xclamps
SOURCE: 2 red lights flash on left side
I suggest you to try DIY Guide that wil explain
solving the 2 flashing red lights along with some other common problems of Xbox
like Disc Read Error, No Video Problem and most famous RROD. Even a novice can
solve the problem with the help of step by step process given at the guide. I
think it's worth trying. If you try this method, you won't have to wait for 3-4
weeks and you can enjoy your gaming experience within 2 hours, once you try this
guide.......
SOURCE: 2 red lights start flashing
overheated. let it cool of, clean it and place it somewhere cooler.
Two red lights flashing on the Xbox 360 means that the system is encountering overheating issues. What you can do is to let your console cooldown for about half an hour and you are ready to go. Also, if you are connected to a Hi-definition output and running on 1080p, you might want to downscale it to 720p as the console generates less heat in lower resolution. Hope this helps..
