Question about Peg Perego John Deere Gator HPX Ride on Toy
Gator wont go
12 volt battery is ok
both motors turn with a secondary power supply (forw and reverse)
power goes through gas pedal(white wire not blue)
fuse is okay
gas pedal pressed down all wires light up except reverse wire and groundwire
gas pedal pressed down and put in reverse gear the blue wire does not light up, no power
i'm thinking its the reverse switch.
    Sniper:
  • 70 Answers
No, just the shifter. Just to check you can exchange the red and blue wires under the pedal(just for a second or so, do not do this permanently) to see if you get power to the wheels, if so then yes it is Definitely only the shifter, but I am still pretty sure it is just the shifter. you can also call Peg Perego Tech support which is excellent and they can help you too 1800-728-2108 and parts can be priced and found at www.mypegperegoparts.com
Posted on Mar 02, 2011
Only 1 wheel turns in 2nd nothing in 1st or reverse
you have a bad motor, whichever side isn't turning you need to replace that motor
Jun 28, 2013 | Peg Perego John Deere Gator HPX Ride on...
Peg perego gator only goes in low speed
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter
Jul 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
I have power from battery to foot pedal but no power from foot pedal out.
check the red and white wires at the foot pedal and make sure that they are showing 12 volts, also check the shifter and make sure that the connectors on the back are connected, you can also try jumpering wires from the battery directly to the motors just to make sure that the motors are good
May 22, 2012 | Peg Perego John Deere Gator HPX Ride on...
Replaced shifter and gas pedal on gator and still wont run?
check the battery with a multimeter and make sure that its putting out at least 12 volts
Aug 15, 2011 | Peg Perego John Deere Gator HPX Ride on...
I want to test motors on pergo gator can i hook up reg 12 volt lawn battery to test that they spin or can i test charger
no don't hook it up to regualr 12 volt battery, first check the voltage of the peg perego battery and make sure that its putting out 12 volts, then you can use jumper wires and connect to the motors with the peg perego battery and verify that they work
Jun 25, 2011 | Peg Perego John Deere Gator HPX Ride on...
My sons gator lost reverse, but still had forward 2 gears, then stopped working all together. I fully charged battery and still nothing. It will honk the horn, but wont move forward
horn runs off of a seperate power supply, check the battery nad charger with a multimeter and make sure that its putting out at least 12 volts
Jun 01, 2011 | Peg Perego John Deere Gator HPX Ride on...
Have 2 batteries.with one battery, the gator goes very slow in first gear and reverse and on the second battery, it will not work at all.
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Jun 19, 2010 | Peg Perego John Deere Gator HPX Ride on...
Wont start,no sounds no power,completely dead
You will need a volt meter to figure this one out. Battery voltage? Should be above 12 volts, and while you are trying to "crank" the engine over, if it's still over 12, you need to see if that power is getting to the starter motor. If it goes below 9 or 10 volts, you either have a bad battery, or the starter motor is shorted, or bad.
To test the starter, you should have a large wire going to the starter that has 12 volts all of the time from the battery. A smaller wire will have 12 volts only when the key is turned to "start". If you have these and a good ground, the starter motor is bad.
May 30, 2010 | 1997 Toyota Corolla
My kid has a peg perego john deer gator, battery tests fine but still it wont go? i swapped out the pedal assembly with another one i have and still nothing.
Apr 05, 2010 | Peg Perego John Deere Gator HPX Ride on...
I have Ariens Model # 1336DLE snow blower aprox 5 yrs
A volt meter or test light will be needed. Also a 12 volt battery supply ( you can use an automobile battery or your automobile)
*Please Note: before testing, make sure all wires and connections are tight and not corroded, loose, or burnt. Many electrical problems are just loose, broken, or burnt wire connections.
Test the chute rotator motor: you will need to disconnect the motor from the wiring harness.
1) connect a wire to the 12 volt supply and one of the motor leads
connect the other wire to the remaining lead
*note: positive or negative does not matter, because the chute motor will rotate either direction, and by reversing leads, the motor direction will reverse.
2) If the motor is good, now check for voltage from the snowblower engine.
Locate the supply wire to the rotator switch, with the engine running, check the voltage reading on that supply wire.
3) If the supply is good, then the switch is bad
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 15, 2009 | Ariens Garden
Peg Perego John Deere Gator HPX Ride on Toy Logo
542 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Marvin
Marvin
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
