We have a xerox document center 426dc copier with a fault code of u7-41--interface error and on the screen it says touch screen/control panel fault.
  • 1 more comment
  • shirleye1961 Aug 03, 2010
    We have a xerox document center 426c copier. We are getting a fault of touch screen/control panel fault which tells you to cut off the copier and then back on which after doing nothing changes. The last DYS SYS-IIT/IPS is U7-41. Other solutions seemed to not pertain to this computer, especially how to get the error codes.
  • shirleye1961 Aug 04, 2010
    we have a xerox document center 426dc copier with a fault of touch screen/control panel. The last MF-Sys fault is DC Sys-IIT/IPS U7-41. The fault tells you to turn off the copier then back on in which we have done and nothing changes. Please help.
  • shirleye1961 Aug 09, 2010
    We have a xerox document center 426dc. There is a touch screen/control panel fault which tells you to power off and back on. This has not worked. We have a U6-33 Panel NVM Ram Data Error code and a J7-1. The printer cartridge is the correct one because we have been using it. I have checked the connecting plugs and there is no paper jam. Please Help!!!!
    Genius:
  • 1,035 Answers
Hi. The error message is telling you what the exact problem is. There is a problem with your touch screen control panel. Fixing this issue will need replacement of the defective part and needs technical expertise. Try this one first switch off the machine and unplug the power cord for the wall. Press and hold the power button for 30 secs. Plugged in the power cord then turn on the machine. If you still get the same error message then you need to call the maufacturers tech and have the part replaced. This will require taking-apart the machine to replaced the defective part.
All the best!
Posted on Aug 09, 2010
  • Angelito Rabago
    Angelito Rabago Aug 09, 2010
    Hi. Try to reseat the print cartidges. Error message telling you that you ahve a problem with the cartridges. Please click here for documentation.
    Genius:
  • 1,456 Answers
Hi there
This is a problem with paper jam in the copier all you need to do is to troubleshoot.
Lift up the top control panel Pull out the paper from the output tray and check to see whether there are any visible paper jams.
Grip the edges of the jammed paper and pull it slowly toward you to remove it from the Xerox copier. Set the paper back into the tray and push the control panel down into place.
Posted on Aug 05, 2010
  • 3,083 Answers
The machine is detecting a problem with the touch screen or control panel. Either could have a problem, or a ribbon connector could be slightly ajar. If you're pretty mechanical, you might be able to take it apart enough to reset the ribbon connectors, however, that's probably about all you can check out without a service manual. You can try to run some diagnostics, if the machine is working well enough to let you, but most likely a repair person will have to address this problem, unless you get lucky.
Here's some info from partsdrop.com, concerning a Call for Service Report, which may help further identify the problem:
It’s also helpful to know that you can run a report known as the “Call for Service Report” from “Customer Tools” which will give you the Machine’s Serial Number, Current system software version, total images billing meter, and Last 20 Faults.
Good luck, and hope this helps.
Posted on Aug 03, 2010
    President:
  • 567 Answers
  • First, if the copier is still under warranty, do not attempt to trouble shoot it or they may not cover it under the warranty if you work on it without their technician doing it for you.
  • Step 2Second, do not laugh because if you do, you may one day feel VERY foolish. Turn the copier off, then re-start it. Too many times this is an automatic reset that people fail to try. It seems too easy and it is, so try it before you call a technician who will charge you just to come by your office to turn the copier on and then off.
  • Step 3Read the directions that accompanied the copier. Too many times we start using office supplies before we read the directions - if ever. Go to the index and look up the specific problem you are experiencing and try it. Look specifically for paper jams and a reset button inside the copier.
  • Posted on Jul 31, 2010
    • 2 more comments
    • Hilton Bristol Jul 31, 2010
      If all else fails, call the company's technician and watch what they do. you may have to perform the same task for the same problem again in the future and it will save you some time and money.
      If this solution don't work please feel free to let me know
      Hi you can also try this method:Whenever your Xerox brand copier experiences a problem, such as jammed paper or an incorrectly installed toner cartridge, the machine automatically generates a function or error code. Each of these numbered codes corresponds to a specific problem with the copier, such as a bad imaging unit. Knowing which error code corresponds to which problem makes it simple to troubleshoot the problem and get your Xerox copier back up and running.
    • Check the Xerox copier's front panel to see what function code is displayed. Check to see if the code is listed as error "01," "02," 03," "80," "81," "82," "83" or "84."
    • Step 2.Unplug the Xerox copier. Pull up the front plastic cover to reveal the toner cartridges. Pull out each of the toner cartridges, then slide them back into place. Replace the cover and plug in the copier.
    • Step 3.Hold the power button until the copier shuts off if the function code reads "05," "10," "11," "12," "13," "50," "51," "70," "71" or "72." Turn on the copier and attempt to copy a document again.
    • Step 4.Unplug the copier and open the front panel if the function code reads error "20," "21," "22," "30" or "32." Contact Xerox to purchase a new imaging unit for your specific copier model.
  • Turn the blue knob at the front of the plastic imaging unit counterclockwise. Pull the imaging unit toward you until it catches, then lift up the unit's handle and pull it out of the copier.
  • Step 6Check to see whether the white plastic sensors behind the imaging unit are dusty. Wipe off the sensors with a soft cloth or the brush tool that came with the new imaging unit. Slide the new imaging unit into the copier and turn the blue locking knob clockwise. Close the plastic cover.
  • Step 7Lift up the top control panel if the error code reads "33," "40," "41," "42," "43," "52," "53" or "62." Pull out the paper from the output tray and check to see whether there are any visible paper jams.
  • Step 8Grip the edges of the jammed paper and pull it slowly toward you to remove it from the Xerox copier. Set the paper back into the tray and push the control panel down into place.
  • Hilton Bristol Aug 03, 2010
    This link have some information might be useful to the problemhttp://www.xerox.com/downloads/usa/en/c/...
    Hi!Can you help me resolving error code 092-315 for xerox7225?
    Can you verify the error code? 092-315 does not appear in the error code site. See link below
    How To Search for a Fault Code WC7220 / WC7225 Fault Code Page
    To search on a fault code, enter one code at a time. The codes will be displayed on the Touch Screen.
    Fault code format: A 3-digit number, followed by a 3-digit number. For example, 010-352.
    Viewing Fault and Alert Messages on the Control Panel
    When a fault or alert condition occurs, a message will be displayed on the Control Panel to inform you of the problem. Alert messages inform you about printer conditions, such as low supplies or open doors, that require your attention. Fault messages warn you about printer conditions that prevent the printer from printing or degrade printing performance. If more than one condition occurs, only one displays on the Control Panel.
    To view a complete list of active fault and alert messages:
    1. Press the [Machine Status] button on the Control Panel.
    2. Select the [Active Messages] tab.
    3. Use the Down arrow and select [Faults], [Alerts], or [Faults & Alerts].
    4. To view details, select a fault or alert.
    Viewing the Fault History on the Control Panel
    When faults occur, they are logged in to a fault history file by date, time, and fault code. Use this list to identify trends and resolve problems.
    To view the fault history:
    3. Select [Fault History]. The screen displays the number, date, time, and image count for each fault code.
    The following table represents the system area as represented by the first 3-digits of the fault code:
    Chain Description 303 Communications Error 305 Duplex Automatic Document Feeder (DADF) 310 Fusing 312, 313 Finisher 371 - 375 Paper Tray Feed 377 Sensor / Interlock Fault 391 Drum Cartridge / Waste Toner
    http://www.support.xerox.com/support/workcentre-7220-7225/support/enus.html
    Mar 07, 2016 | Xerox Office Equipment & Supplies
    UI/NC CABLE FAILURE RESET THE MACHINE CODE IN WORKCENTRE 7675
    Your error is either a disconnected cable or a bad cable.
    Xerox refers to the Operator Panel as the "UI"or User Interface, and the "NC" as the Network Controller. The cable you probably need to check or replace is 117K37660, coming out of the Operator panel back to the copier.
    Sep 12, 2014 | Xerox WorkCentre 7665 Copier
    Xerox WorkCentre 7120 error code
    Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
    Aug 23, 2014 | Xerox Office Equipment & Supplies
    I am using xerox work center pro428 .now it is not working error message showing code U8-3
    Hi, I can't find that specific error code in the documentation on that model of machine, however, in general in Xerox machines U8-3 means that your exposure lamp is blown or has a problem
    Aug 19, 2011 | Xerox WorkCentre Pro 428 Copier
    Xerox work center 7335 code error : 005-285
    Solution : Power Off the Printer, Then Power On
    1. Power off the printer using the power switch located on the front, right side of the machine under the Control Panel.
    2. Wait until the Touch Screen becomes blank.
    3. Press the power switch again to power on the printer. The entire power on process (to power on and complete a self test) takes less than 45 seconds. Certain functions of the printer, such as copying, will be available before other functions.
    If this fails to solve your issue contact service.
    Hope it helps!
    Feb 26, 2011 | Xerox WorkCentre Pro 123 Copier
    I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
    • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
    • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
    • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
    • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
    • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
    • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
    PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
    Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
    I need a list of erro codes and definations for xerox workcentre 7232 serie. and I want the solution to my xerox workcentre 7232 copier. when switched on it shows erro 093-311
    When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
    002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
    003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
    003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
    003-754
    003-755 An error occurred in the document scanner. Reset the document, and scan again.
    003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
    003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
    003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
    003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
    003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
    smaller segments.
    003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
    003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
    005-210
    005-275
    005-280
    005-283
    005-284
    005-285
    005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
    Jan 16, 2011 | Xerox Office Equipment & Supplies
    FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
    Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
    Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
    Xerox phaser 7760 sends fault error code 007-274. Won't go further. -john
    This error means there is an open circuit in the Paper size sensor, in Tray 1/MPT.
    It could be a broken wire in the tray assembly, or a fault on the Engine control interface board.
    The voltage at the sensor should be about 3 VDC. (Pin 1 of Plug J610)
    Dec 22, 2009 | Office Equipment & Supplies
    241 people viewed this question
    k24674
    jasbo
    jasbo
    Marvin
    Marvin
