Question about Zodiac Baracuda G3 Automatic In Ground Pool Cleaner
Our cleaner works for 5-10 minutes and then does not work anymore..we replaced the diaphram, cleaned the filter, etc (G3)
  • 106 Answers
Since you've already replaced the diaphragm, it sounds like a filter problem. Try acid washing the filter and see if that solves your problem. A suction gauge is supplied with the cleaner and you can compare readings when working or not. If reading goes down, it's a filter problem If it stays the same it's a cleaner problem. Could be a crack someplace on cleaner housing.
Posted on Aug 03, 2010
Baracuda stopped working. it is not vibrating but not moving
it ended up being that the hose had a kink in it. It's working fine now.
Feb 05, 2013 | Pool & Spa
Choke seems to be on... runs very rough....
There are several ways to do it
a. Check carburetor if not clean pump it on the intake if that not solve try to clean it. with Lacquer thinner to dissolve the dirt.
b. Check spark plug if some are not working. In checking try to pull one by one the high tension wire and listen if the sound vary if the sound remain when pulling one wire mean you have problem with your spark plug. So replace all spark plug with the same spec.
c. or lost compression on cylinder.
d Check if you fuel filter if some dirt and replace it.
e. Clean your air filter with compressor or replace it
f. Check the clearance to the Contact Point it must have 1 mm or .8 mm spacing when not at firing mode ( just like the thin of the hacksaw blade the space of the gap of the contact point.)
Aug 12, 2011 | 1984 Jeep CJ7
My g3 is not working, took it to pool store and they replaced diaphram, but still not hopping or moving, suction is good but now movement.
There are a couple things to check with these pool cleaners when they stop moving. Use Pool Pulse to insure proper flow through the cleaner. Clean baskets and filter to ensure that you are not clogged. Check hose sections for leaks by lifting each section above water.
Apr 09, 2011 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac G2 Cleaner not moving around pool. Suction is adequate, filter has been backwashed. Cleaner pulled to pieces and reassembled. Has small crack in diaphram. Unit is 6 months old and has problems the...
any damage to that diaphram will cause the cleaner to not work. If it is only 6 months old then it is under warranty. any pool store should be able to get you a new diaphram at no cost. bring your paperwork with you to show proof of purchase.
Dec 29, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My Barracuda keeps stopping after a while. Did the suction test and it is reading 3. Is this too low to keep it running?
3 is perfect. The diaphram is most likely the problem. If the diaphram is more than say..9 months old it can get bloated and not function properly. The only other problem could be is if the cleaner is a few years old the foot pad could be worn out and the cleaner can **** itself to the pool and not move. Most likely the diaphram though.
Nov 22, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My baracuda G3 stop working is not pulsating and therefore not moving. I checked the suction and the hoses even the diaphram everything looks ok.
If you have suction at the bottom of the cleaner, there has to be a problem with the diaphragm. I would remove it and recheck.
Feb 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
The cleaner will run 1-2 minutes then stop. I can shake the hose & it will start again for another minute or 2. Everything looks to be in place and working. Any suggestions would be appreicated.
First, remove and check diaphragm for cuts or rips. If ok, check hoses for leaks. You can do this by holding hoses one at a time above water level while cleaner is running(or supposed to be running). If there is a leak you will hear it sucking in air. Make sure filter is ok. If a cartridge filter, remove cartridge and run without it in. If cleaner works ok without cartridge either acid wash or replace cartridge.
Jan 23, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Should there be a hole in the side of the G3 diaphram?
no, a common place for cracks is near the top next to the plastic ring that holds the diaphram to the tube. this is a common problem with the G3 and G4 diaphrams. other cracks and holes near the center are usually caused by objects that get picked up and stuck or old age.
too much suction and/or use will shorten the life of the diaphram. along with bad water chemistry
Jun 23, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
G3 is not moving, but has suction? Please advise.
I had the same problem. come to find out there was somehting stuck in the diaphram. (a piece of mulch). Once I removed it, everything worked fine. Take your Barracuda apart and check the diaphram for blockage.
Mar 21, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac Baracuda G3 Automatic In Ground Pool Cleaner Logo
207 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
