Where is the CMOS battery located? - Computers & Internet
  • 700 Answers
Well... i am willing to help, problem is that you do not give what manufacturer and what model of the motherboard.
most of motherboards manufactured after year 2000 use button lithium battery, you will spot it as a silver disk about 1/2" to 3/4", where it is located exactly on the motherboard, it is your quest, you did not give model or manufacturer...
changing bios batery will erase all content of the bios and return it to the manufacturers settings. therefore if you make any changes to the bios, you should take note what and where so you can re-enter them.
procedure for removal:
1. switch off computer
2. remove power cable from power unit
3. wait at least 20sec
4. remove side of the computer case so you can see motherboard
5. locate battery as described above
6. push batery slightly towards the latch, battery should slide out easy, sometime bit lift on opposite side of latch is required
7. purchase new battery, exactly same type and replace in reverse to the removal procedure
8. connect power cord
9. switch on computer
if you made before changes to bios:
10. access bios and re-enter correct settings
11. reboot and use computer as before.
if you find these direction helpfull, give me your vote, if you need more clarification, please post what motherboard and model of it.
Posted on Jul 31, 2010
    President:
  • 2,600 Answers
On most desktops, it will be located on the motherboard, sitting in a slot socket. These batteries look like nickels and sit in the socket with their positive side up. They are usually held in place by a tension spring.
If you have a laptop, then the battery maybe accessible through an access door on the bottom of the case. These batteries can also be a disc type battery sitting in a slot or it can have a special covering with a small cable attached to it, this small plug attaches into a socket. In some cases, the laptop has to be disassembled in order to remove or observe the battery.
Where is the cmos battery located in a gateway m255-e laptop
open the top key board then under this key board you located the cmoslb_icon1.png battery and jumper settings..good luck
How to change Gateway M255 PC Notebook cmos battery Where is the mos...
May 14, 2014 | Gateway M255-E Notebook
Location of cmos battery
These are the most basic signs your CMOS battery is going dead and will be your ultimate test of the battery
http://www.bing.com/images/search?q=cmos+battery+images&qpvt=cmos+battery+images&FORM=IGRE Bios setting are saved in cmos batteries
make cmos battery has charge and is not loose
cmos battery images
How to replace the CMOS battery in your laptop http://www.youtube.com/watch?v=MTg8qhWKNpA
Feb 19, 2013 | Computers & Internet
Where is blinking amber light located on dell
Replace CMOS Battery.
1. Locate your CMOS battery
2. Obtain battery information
3. Removing the battery
4. Removing the battery
5. Enter CMOS values
This link will guide you. CMOS
Thank you for posting..
Jun 30, 2011 | Dell OptiPlex GX520 PC Desktop
Where is the cmos battery located on the samsung r60 plus
Glad to HELP YOU!
As a rule of thumb: for laptops/notebooks/netbooks the CMOS battery is located under the keyboard. So you have to remove the keyboard in order to reach the CMOS battery.
Here I've found for you a nice video that will show you everything in detail.
GOOD LUCK!
Mar 17, 2011 | Samsung R65 Notebook
Where is the cmos battery located?
cmos is located in the motherboard. You need to remove the battery, hard drive, optical drive, screws on your keyboard to see the motherboard. Then there is a CMOS battery which is a circle shaped with silver plating on it..
Oct 16, 2010 | Acer TravelMate 529ATX Notebook
How do I replace a dead cmos on acer 4520LCi travelmate laptop? The laptop no longer keeps track of system time when shut off completely. Can you tell me the exact location of the cmos so I can be able to...
what you replace is not the CMOS, but the CMOS battery.
On an ACER from those years the CMOS battery looks like a coin, or a coin wrapped in plastic and connected to the motherboard.
On most models from same series the battery is located on the lower side of the motherboard, like on picture below:
On some model the battery may be located underneath the keyboard.
Here disassembly instructions for a similar model.
Sep 11, 2009 | Acer TravelMate 2300 Notebook
Cmos battery location
open the top key board then under this key board you located the cmos battery and jumper settings..good luck
Jun 26, 2009 | Acer TravelMate 2300 Notebook
Urgent help needed to locate cmos battery laptopasus x51r series
The cmos battery is on the motherboard and unless you are competent at disassembling laptops then I suggest you take it to a repair shop for battery replacement.
Jun 09, 2009 | Acer Aspire 3690-2196 Notebook
CMOS
The cmos on the Pavilion is going to be in one of three places, and will be one of two styles of battery. The cmos style will be either a large watch type battery about the size of a nickle located in a slot on the mother board, or in a yellow or greenish pouch with two wires leading to a connector, located under a cover on the bottom of the machine, or under the keyboard.
Aug 28, 2008 | Computers & Internet
Computers & Internet Logo
106 people viewed this question
Alun Cox
David Payne
David Payne
