Question about HP 12c Calculator
Decimals I have inadvertently reset my calculator to show only one decimal place out. How do I change back?
  • Anonymous Feb 05, 2009
    how do I change the comma "," function back to decimal point
This is an easy one and happens often. Simply depress the orange "f" key and then select how many decimal points you want on the numeric keys. For example, for two decimal places you would push "f" 2. I usually keep mine on 3, but you can take it from here.
Posted on Apr 25, 2008
HP 12 C display does not show entire numbers. How do I fix?
If you mean it is not showing everything after the decimal point, you can change that by pressing the [f] key followed by the number of decimal places to display. For example, to restrict it to 2 places, press [f][2]. If you want to see 4 places, press [f][4].
To show all possible decimal places, use the sequence [f][9].
From the manual (http://www.hp.com/ctg/Manual/c00363319.pdf):
"To display a different number of decimal places, press f followed by a digit key (0 through 9) specifying the number of decimal places. In the following examples, notice how the displayed form of the number inside the calculator - 14.87456320 - is rounded to the specified number of digits."
25096057-rvrejqbjq4zuw4cbinsyjvsy-5-0.png "Although nine decimal places were
specified after f, only eight are
displayed since the display can
show a total of only 10 digits. "
The standard display format, plus the specified number of decimal places, remain in effect until you change them; they are not reset each time the calculator is turned on. However, if Continuous Memory is reset, when the calculator is next turned on numbers will be displayed in the standard display format with two decimal places
shown.
If a calculated answer is either too small or too large to be displayed in the standard display format, the display format automatically switches to scientific notation. The display returns to the standard display format for all numbers that can be displayed in that format.
Sep 12, 2014 | HP 12c Calculator
How to get the ti89 to show more decimals
In the home screen press the MODE button. On the line display digits choose the number of decimals you want. Here is screen capture from a TI Voyage 200 PLT.
Jan 29, 2013 | Texas Instruments TI-89 Calculator
I inadvertantly changed the display. How do I get the decimal mode and set the number of places?
Hit the right blue arrow on the left of your calculator, and then press the number 6, it should take you back to Radian mode.
Feb 28, 2011 | HP 32sII Calculator
Only shows 1 decimal place!!
Press 2ndF TAB and then a digit specifying the number of digits you want after the decimal point.
May 23, 2010 | Sharp EL-501WBBL Calculator
Show two decimal places
Input the following and try:
  1. Press 2ndF and . the point button. This changes the screen to FIX DEG
  2. Press 2ndF +/- 2 Answer shown is to 2 dec. pl.
  3. If you want it to 5 decimal places, Press 2ndF +/- 5 answer shown is to 5 d.p. and so on
For normal, just take calculator out of FIX so just DEG shows.
Couldn't find you a YouTube video, so text will have to do.
crimsonnightt@hotmail.com
Apr 01, 2009 | Sharp EL-738 Scientific Calculator
I want to increase the number of decimal places
I found this solution on the HP website. Turn it on, and do what it says. Then turn it off and back on again, and the extra decimal places should show.
http://h10025.www1.hp.com/ewfrf/wc/document?dlc=en&lc=en&cc=us&docname=bpia5183 Introduction This document describes how to set the desired number of decimal places on the HP 12C Calculator in standard format and in scientific notation. Instructions for standard format
  1. Press and release the gold PREFIX key (f).
  2. Press the number key for the desired number of decimal places (0 through 9).
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected.
Mar 25, 2009 | HP 12c Calculator
EL-1197PIII Sharp Calculator
move switch for decimal places to "add",or to number "2" for 2 fixed decimal places
Feb 28, 2008 | Canon LS-100TS Calculator
Reset to factory settings
remove battery and return it back this make reset-decimal places can be adjust with decimal switch.
Dec 21, 2007 | Sharp EL-240SB Calculator
I want two decimal points to show
I called Canon customer support. There is a tiny reset button on the lower back area of the calculator. Simply stick a small object in there to reset the calculator and you should be as good as new! Worked for me!
Dec 02, 2007 | Canon LS-100TS Calculator
HP 12c Calculator Logo
734 people viewed this question
Seeker5211
Seeker5211
