Question about Dryers
We have a kenwood kvt1w tumble dryer all lights come on when dryer switched on the drum doe's not spin but the back of the dryer is red hot.
4 Suggested Answers
Jimster
  • 240 Answers
SOURCE: Manual for KVT1W
http://www.espares.co.uk/parts/tumble-dryers/kenwood/kvt1w-1123-547-15000/p/1088/435/0/631602
Try this site and see if they can help you out. I would imagine that you are overseas somewhere, can find anything washer or dryer type for Kenwood here in the states. Let me know if they cant help you, will do a little more looking for you. JIM
Posted on Nov 22, 2007
SOURCE: How do I fit a new drive belt for my Kenwood KVT1W Tumble Dryer
Remove the piece of angle iron from the top back of the LG DLE2514 and slide the top back. This exposes the screws holding the control panel on.
The control panel is held on by two screws, but they are at an ackward angle. The pannel has plastic tabs, when disengaged the panel pulls up.
There should be enough cable to set the pannel on top of the machine without disconecting anything.
Taking off the front pannel is easy at this point. Under the control pannel are four screws holding the front on. The Door has two screw holding it on and two alternates on the other side. The last two screws are at the bottom of the door opening.
Posted on Jan 24, 2009
wiringlunati
  • 576 Answers
SOURCE: where is the driver belt for kenwood tumble dryer
It is a long, narrow belt that runs from the motor underneath up and around the drum. You should be able to find an exploded view at www.appliancepartspros.com as long as you have the complete model number. Good luck.
Posted on Mar 10, 2010
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
Jan 25, 2016 | Dryers
How do I fix a drive belt to a kenwood KVT1W tumble dryer please
Hello Linda;
My name is Peter. I am a retired field service appliance technician.
Go into the following web link. It is not for a Kenwood but the base tasks are there. Whirlpool Kenmore Dryer Repair How to Remove and Replace Belt 341241
Jun 08, 2015 | Dryers
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
Where is the driver belt for kenwood tumble dryer model kvt1w, my machine wont rotate and im told this is why? but i dunno what part of the machine it would be in
Mar 09, 2010 | Dryers
Hot point wd64 dryer
U need to check the heater element and/or the stats on the top of the heater box located on the top of the drum for continuity, with a meter.
Disconnect from the supply, and remove wires from components to check for continuity.
Hope this helps u.
Plz rate this solution.
Thanks.
Dec 30, 2008 | Hotpoint Aquarius WD63 Front Load...
I am not familiar with this machine but most dryers have to have the front removed so that you can slip the belt over the drum. I would imagine they have the screws hidden pretty well. Perhaps their is a removable front panel. Some have a few screws on top then you raise the controlpanel exposing the front screws. Just a guess.
Dec 22, 2008 | LG DLE2514 Electric Dryer
Electric dryer not spinning
Well first of all you may check out the Door Switch if it's defective then your dryer is not able to spin, it may interfere with your dryer drum's ability to tumble. Test your dryer's door switch. If it is no longer functioning than you need to replace it. you need a multimeter to check it. Post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
Dec 04, 2008 | Dryers
Very hot at back, making humming noise, but drum isn't spinning.
the drive belt is likely broken
belt replacements for most models are simple and cheap
have no experience of bendix cannot give exact instructions
Nov 02, 2008 | Tricity Bendix TM310W Electric Dryer
Manual for KVT1W
Nov 21, 2007 | Dryers
Dryers Logo
52 people viewed this question
Top Dryers Experts
