Question about Harman Kardon AVR 340 Receiver
No display I am trying to power up my Harmon Kardon AVR 340 amplifier and the blue light will come on for about 10 seconds and it then goes to orange. I never get a display on the monitor.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to the site,
Almost always, the described symptoms of the HK AVR340 indicates that it has kicked into auto-protect mode. While this is a power supply action, it is triggered by the logic controller that has sensed a fault and halted the system to prevent further damage.
The only easy user doable try of a fix is to check the speakers and their wires. Ensure that the speakers are within specs, no stray strand touching its opposite, no frayed wires and are connected correctly to the rear of the HK. All others require that the AVR340 be opened up to effect repairs.
Options then are:
  • consider a DIY (do-it-yourself) repair if and only if comfortable working with electronic components & circuitry, use of a DVM/VOM, a soldering iron/station and safe practices with electrically powered devices. Access to a Service Manual or at the very least, a schematic diagram would be a necessity;
  • should you be uncomfortable with a DIY, perhaps your best bet would then be to consult with and/or seek the services of an authorized Service Center (specially if still under some form of extended warranty) or a qualified professional.
Are you considering a DIY?
Good luck and thank you for asking.
Posted on Jul 31, 2010
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
My Harmon Kardon AVR 2600 goes to protect mode when powered up. After many tries it will fire up but at times it's up to twenty times. I did load the software upgrade 6 months and it has been fine
Check all speaker wiring for shorts, if okay! there is a problem in the audio output stage of the unit or the protection circuit is not working properly. I would suggest a pro to evaluate.
Apr 02, 2012 | Harman Kardon AVR 2600
I'm having a harmon kardon avr85 amplifier few months back i have connected my amplifier to my computer it worked fine for an hour but after some time the main power went offof the house and for few months...
So the house breaker went off when it was on? If so the only thin you can do is open it up- four screws on the sides and one in the back if i remember. Look for the fuse near the electrical wire coming in the amp. If it's burrned replce it with same ifnot bing it in
May 20, 2010 | Harman Kardon AVR 85
Harmon Kardon AVR 5
Assuming that the system is properly installed and was working ok before, the problem is usually a blown output amplifier in one channel and the receiver disconnects the speakers to avoid damaging them. In this case, professional repair is required.
Nov 15, 2009 | Harman Kardon AVR 5 Receiver
My Harman/Kardon AVR 140 is stuck on stand by mode
I have the same problem on my AVR 1550 - its been bugging me for ages then it works again, then it doesn't ...
Aug 28, 2009 | Harman Kardon AVR 140 Receiver
Same Problem As Well
microcontroller needs to be changed
Jul 07, 2009 | Harman Kardon AVR 7300 Receiver
I PURCHASED FROM ABC WAREHOUSE HARMAN/KARDON AVR 340.ITS A FLOOR MODEL SOLD AS IS WITH OUT OWNERS MANUAL AND REMOTE.I REALLY NEEDA OWNERS MANUAL.CAN YOU HELP ME GET ONE?
Harmon Kardon AVR340 just has no sound and it doesn't pass the video through. Looks normal when on. ( Display shows everything is on)
Aug 26, 2008 | Harman Kardon Audio Players & Recorders
Cannot get dts from my Harmon Kardon AVR 300 via my Blue Ray
I'm not sure if this solution is still necessary however:
I own a H/K AVR300 and have a PS3 hooked up via HDMI to the TV and Optical TOSLink to the receiver. I have no troubles selecting between DD 5.1 and DTS 5.1. I can even select trueHD whatever format but I can't detect an audible difference, I think that mode might be downgraded back to regular DD5.1...
Hope this helps...
Mar 23, 2008 | Harman Kardon AVR 300 Receiver
Was using the harmon kardon avr 225 receiver and the front panel went out. .... screen display of the channel number, volume, or menu item does not work. ...
Try hooking up a yellow video wire from the back of the AVR 225 Monitor out. Should be at the end of the 7 or 8 yellow video ports on the back of the stereo. Next plug the other end into a yellow video in on a t.v. Get your remote, (Harmon/Kardon) and make sure the t.v. is on the correct video input and hit the OSD(on screen display) button on your harmon remote. There should be a setting in there that says VFD under ADVANCED menu option that allows for turning the front of your stereo lights on and off and dimming them half way also. OFF/HALF/FULL are the 3 options I believe.
If this doesnt solve it your display may have crapped out on you.
Jan 22, 2008 | Harman Kardon AVR 225 Receiver
Harman Kardon AVR 340 Receiver Logo
47 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
