Question about Maytag Neptune MDG5500AW Gas Dryer
MaytaG MODEL # MDG4000BWW. Rumbles and sweels as
MaytaG MODEL # MDG4000BWW. Rumbles and sweels as drum turns. Vibration shakes dryer.
  • Maytag Master
  • 2,699 Answers
Check the rollers,the pulley and if it shakes as bad as it sounds the blower wheel is probably damaged
Posted on Aug 07, 2010
  • 7,365 Answers
Could be belt
could be loose pulley
Posted on Jul 31, 2010
4 Suggested Answers
  • 56 Answers
SOURCE: wont start, smells like something is burniing
if its electric burning smell,its either a overheating motor,capacitor or both or burnt connections,sounds like a motor problem,it will be very hot to touch if its failing,check capacitor though as it could be causing motor to overheat,rating of cap is on side
Posted on May 27, 2009
Illeagle
  • 525 Answers
SOURCE: Maytag MDG4000BWW gas dryer does not heat up
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
Firstly, ascertain that you have made a positive heat selection on the control panel temperature switch. The links below are listed in order of failure commonality.
1.Gas Valve Coils
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3479&PartID=3479
2. Ignitor
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3018&PartID=3018
3.Thermal Fuse
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di516650&PartID=516650
These are only the most common parts that tend to fail. There are numerous other components that could cause the same symptoms. If the above assistance does not resolve your issue, you may request assistance with an on-line technician, or you can order a service manual from www.repairclinic.com
Posted on Aug 30, 2009
marka19
  • 1430 Answers
SOURCE: how do i change the dryer drum belt on a maytag
Try this free video www.appliancehelponline.com/servicemanual.html
Posted on Feb 26, 2010
My 13 year old Maytag Dryer rumbles to a start when you turn it on and rumbles to a stop. Sounds like the belt is slipping to me. Should I contact a repairman to replace it?
I would check the drum rollers and glides first, the other cause may be the idler assembly which is next to the motor, it keeps tension on the belt. Since you will have it apart you can check the belt for cracks and wear, if it looks good then I would not replace it. eBay is a cheap place to find dryer parts, here is a website on the rollers/glide you can go to the virtual repairman and it will help. I think it is a good site to troubleshoot just about anything you may have problems with, Good Luck Tim.
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Dec 18, 2010 | Maytag PYE4557A Dryer
I have a maytag dryer and i need to know if it is electric or gas. model # (P)MDG4000BWW
Gdeli25 --
The Maytag Neptune MD[G]4000BWW is a front-loading [G]as dryer. Parts list and manual are available online from:
[http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47083]
If you are still having problems, write back. -- SWT
Aug 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Gas dryer dosn't heat properly
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jul 07, 2010 | Maytag MDG3600BW Gas Dryer
I have a maytag dryer, model # MDG4000BWW. It has...
check the high limit/cycling switch thermostat located on the heat housing ,you will need to remove the front panel to access this,then, bypass the high-limit with a jumper wire and see if the flame stays on longer,if this doesn't help, then check the radiant senser on the tube also they get dirty,you can clean the senser eye or bypass this also and see if its weak,if not then replace the 2 gas coil valves on the gas valve body as these will get weak and shut off the gas supply
May 20, 2010 | Dryers
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
1.Gas Valve Coils
2. Ignitor
3.Thermal Fuse
Aug 30, 2009 | Maytag MDG3600BW Gas Dryer
Grinding Noise
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Hope this helps.
God Bless.
Jul 08, 2009 | Maytag MED9700S Electric Dryer
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Neptune MDG5500AW Gas Dryer Logo
442 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
