Question about HP Computers & Internet
Power Failure Hp Laptop Computer nc6000 (Power Switch)
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 53 Answers
This can be your battery or Laptop charger's problem. Check your battery and its charger if it is connected properly. If problem is not solved ask it to your dealer.
Posted on Jul 31, 2010
What the solution of laptop hp compaq nc6000 when turn on won't start up
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/original-hp-compaq-nc6000-ac-adapter-65w-cord.html
http://www.chargerbuy.com/replacement-hp-compaq-nc6000-ac-adapter-18-5v-3-5a.html
Nov 13, 2012 | HP Compaq nc6000 Notebook
Why my hp compaq nc6000 laptop failing to boot from cd after selecting multbay
hi ,
go into your cmos or setup for the computer , find boot setup and change it to drive c:\ or hard drive 1 .........good luck Roy
Feb 18, 2012 | HP Compaq nc6000 Notebook
My hp nc6000 laptop wont boot up i need to reset it to factory setting
When you power on your laptop immediatly after powering on your laptop start pressing F8 key on your laptop keypad, after few seconds Advance boot options menu will appear in front of you in that menu select (repair my computer) option will take you to unother sub menu which will give you an option of load factory image.
Sep 02, 2011 | HEWLETT-PACKARD Hewlett Packard Compaq...
My laptop had virus, i then formated it and it function fine but one day when i boot the laptop(HP Compaq nc6000) vertical lines(combination of blue, yellow and green) displays on the monitor and since...
That is what I like to call hardware failure... Your monitor is broke...
If under warranty:800-474-6836
If not under warranty:
http://www.laptopscreen.com/English/model/HP-Compaq/HP~COMPAQ~NC6000/
Tutorial on how to repair it:
http://www.laptopscreen.com/index.php?section=products&brand=HP-Compaq&series=HP%20COMPAQ
May 09, 2011 | HP Compaq nc6000 Notebook
Starting problem
Starting problem Answer hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan... (More) hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan starting up with one glowing orange light next to a lightning bolt like symbol. IWhen I turn ON my laptop first time HP Compaq nc6000, sometimes the orange LED will just light up and nothing happens, sometimes when I get lucky I will be able to goto Windows. when start work properly.
Jan 31, 2010 | HP Compaq nc6000 Notebook
HP NC6000 boot failure.Fan starts but quits after 10 secs or so.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 22, 2009 | HP Compaq nc6000 Notebook
Hi,My HP Compaq nc6000 just developed a problem of not coming on. I have checked the battery and its okay. I have blown its internal parts and it remained off. It only indicates the orange light for some...
try taking the battery out completely and see if the laptop runs of the main power from the outlet, if so then the battery may have a bad cell in it and would need to be replaced.
Primary Batteries
6-cell Lithium-Ion (4.4Ah) – standard
8-cell Lithium-Ion (4.4Ah) – optional
Power SupplyExternal 65 watt AC adapter
from looks of it the battery has gone bad
http://www.laptopbatterystore.com/product/2151/compaq-business-notebook-nc6000-batteries?utm_source=GoogleProducts&utm_medium=CSE&utm_campaign=Compaq/HP&utm_term=HP18S6-Compaq-Business-Notebook-NC6000-Battery
Aug 20, 2009 | HP Compaq nc6000 Notebook
HP Compaq nc6000 powers up and then down automatically
check first the power connector.. and be sure that you power not auto shut off. then instal again the os.. even this vista or xp don'st matter...
as long as you powere is good condition..
Jun 13, 2009 | HP Compaq nc6000 Notebook
Hi, i have compaq nc6000 when i press the power button the laptop was on but desktop item does not show and any command does not work, pls give proper solution
when u power up the laptop press F8 key then enter in safe mode .
then go to start menu then type in run "chkdsk /r"
then press "y"
then restart it and it fix error on harddisk.
Also check in your computer that there are not 2 antivirus installed.if u found 2 remove 1 in safe mode.
Jun 12, 2009 | HP Compaq nc6000 Notebook
Screen will not power on
try pluggin an external monitor to the laptop. If you see the screen then your filament ribbon might need repair or replace.
May 06, 2008 | HP Compaq nc6000 Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
