Insignia 26LCDTV No sound, except thru noise reduction ear phones. Can only use remote for on/off, Buttons on side of TV only work for on/off and nothing else Closed captioned is stuck in the on position.
  • 1 more comment
  • Kodee Apr 30, 2008
    Are you speaking about the mother board?
    If so, any idea as to cost of new one.
    Thank you,
    Dee
    Sounds as if your feeling were hurt...Not my intention....
    Thank you.....
  • 2,336 Answers
It might be a sign that the power supply is going bad on your TV.
Normally a number of capacitors get dry and bulging causing those failures up to the point of not being able to power up.
Posted on Apr 25, 2008
  • Jaime Hernandez Apr 30, 2008
    Thank for the rating.
    I was just giving you the solution(s) and you did not even think it was helpful.
    I have no more to say.
    Good Luck.
    LOL not really, the thing is that when the experts in here give a solution(s) we really try to help the customers with their problems.
    Anyhow, i do not think there might be service parts available for your TV. The only way will be to get it fix to the component level.
    When I said the power supply, I did not mean the mother board but the one that provides power to your TV.
My Insignia LCD 42" only
It sounds like it has main board problem, leave it unplug for about an hour to let it reset itself to see if it will work again. It can also be unstable power supply problem.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 14, 2011 | Insignia 42" LCD Flat-Panel HDTV
Need to change tv setting for wii game option
I had the same problem. First, I got the comp cables and set resolution to 420p\16:9 aspect. Didn't fix it. then I went into the advanced menu and turned off noise reduction and DCM (digital clear motion).
Feb 16, 2010 | Insignia 42" Flat-Panel Plasma HDTV
Insignia NS-PDP50 Plasma TV - Remote Sensor failure
Change batteries.Reboot everythings.Tv unplug,replug couple mins later.Ur Directv box,push off/on for new update software.After that sould work.Rate me after u done this.
Jan 02, 2010 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
Lost remote want to get to input channels using side buttons on TV
Try using the manual buttons and keep pressing channel down until you see the lowest station you receive, then go slowly.
Maybe Insignia put the inputs into the channel search automatically.
Apr 27, 2009 | Insignia LCDTV26 26 in. Television
Display window stays on screen, buttons won't work
Sounds like one of the buttons on the monitor is stuck in. See if you can unstick them by pressing them infirmly, but not too hard, several times. Try each one in succession. Hope this helps!
Jan 02, 2009 | Insignia IS-LCDTV32 32 in. Television
RECEIVER WORKS FINE WITH THE RADIO NOT THE TV.
correctly connected to output on tv ? ie red and white left and white and not yellow (video)??
Dec 08, 2008 | Yamaha HTR-5860 Receiver
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Sep 01, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
