Question about RCA Televison & Video
The screen looks like you need 3-d glasses to watch it. It also looks sort of concaved in the middle. I would like to know if it would be worth fixing it and what might be wrong with it? You can still see the picture though but there is a red, green, and blue hue around any object.
  • 115 Answers
Your alignment of the 3 lcds inside are off. You need service if you don't have a "convergence" or similar button on the unit or in the menu.
Posted on Jul 31, 2010
My Mits tv has sound no picture ! 3 concave lines,almost like a bowtie in middle of the screen red,green,blue. Please help ???
I would look for dry joints and poor plug socket connections around the line output section.
Mind your fingers!!!!!
Apr 17, 2011 | Televison & Video
Image on screen looks concave(middle of screen looks farther away than left or right side.)
Roseannmace,
Your TV is out of convergance. You'll probably noticed that there are red, green, and blue images. You'll need to determine if the problem is in the power supply or the convergance board. Usually, the convergance amps go bad and opens resistors. Do you know how to read a schematic and use a multimeter? You will also need to know how to remove the old parts and solder the new parts into the circuit board.
Ken.
May 27, 2010 | Toshiba 43HX70 43" Rear Projection...
My 57hx81 has a slight concave bow in the middle top to bottom
Sounds like a problem in the vertical sweep circuit. Check voltages to your convergence ICs. If they are  not to spec then look for bad fuses and capacitors on the power board. These will throw off the DC voltage to the convergence chips causing the bow effect. I've had a single bad pico fuse ($1) cause this symptom.
Dec 06, 2009 | Toshiba 57HX81 57" Rear Projection...
Display looks like you need 3D glasses to view.
Sounds like a convergence problem. Especially since you said that the screen(picture)wasn`t linear anymore.
If the magic/touch focus function doesn`t clear the problem then your convergence modules may be faulty. They are used to align the three tubes (red/green/blue) deflection. If you feel handy with a soldering iron i could assist you in replacing them, otherwise you might need the help of a local repair tech. Hope this help. Good luck
Dec 01, 2009 | Televison & Video
Concave picture
sounds like the bulb is on its way out, they can be replaced for about 100 bucks.
Jul 25, 2009 | Philips 51PW9303 51" Rear Projection...
My RCA is concaving the picture in the middle and red green and blue are showing up seperately on the screen I also have A charter communication HD MOXI box connected to it but when I disconnect it the...
When you go to Menu then setup does it have convergences listed if not FL231 is bad Fuse 400ma.There is 3 only they do not look like Fuses they are small brown rectigular caps you can pull top off of them with Needle nose plyers it will be middle fuse ,look on right side of FBT there is 3 in aroll.
HAPPY NEW YEAR!
Jan 01, 2009 | RCA HD52W59 HDTV Projection Television
Green on screen
try to do it inside the board.
there are some adjustments except brightness and focusing..
try if you can ...
regards,
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
37 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
