Question about Fisher and Paykel GWL11 Top Load Washer
Top load washing maching does not complete the cycle
My top load washing machine does not complete a washing cycle or rather it has trouble getting past the first cycle.If I go straight to the spin dry cycle for instance, it starts but it just does not sound right and can's seem to complete or go through the process. Hope you can help me.
  • 70 Answers
Sounds like you have a pump issue, make sure it is not blocked or restricted :)
Posted on Jul 31, 2010
Last cycle completed, maching beeped and washing taken out. Machine light is on rinse cycle and beeps will not reset to start new load.
Hi just read your posting.From the information in your posting you mentioned that the rinse light is on when the machine is beeping.Starting from the left to right on the wash progress lights which lights are lit when the machine is beeping,Is it the 1st and 6th or the 3rd and 7th etc?Please reply with this additional information and i am sure i can help you rectify your machine.Looking forward to your reply.
May 17, 2011 | Fisher and Paykel GWL11 Top Load Washer
I pushed the button after the washing cycle had start for the purpose of stopping the cycle so that the clothing can soak before washing. When I returned about half an hour later, I pushed the button to...
I am taking this as a machine with a timer knob. If so, you may have to advance the timer manually to get it to go. You may have stumbled onto a slightly dead spot on the timer. I think I would just leave the lid up next time. That will stop everything and give you the soak time you so desire.
Jun 22, 2010 | GE EWA5600GWW Top Load Washer
Clothes too wet after spin cycle
could be the clutch slipping not releasing the brake allowing it to get upto full speed
Feb 28, 2010 | Kenmore Washing Machines
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
Whirlpool LXR9445JQ having trouble with spin cycles.
Check the motor and make sure that the RPMs are high enough, Also check the tension on the belt
Feb 12, 2009 | Whirlpool LXR9445JT Top Load Washer
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing maching will not change
the timer motor is most likly bad it is mounted on the back of the timer itself and advances the timer thru each cycle. you can check power to it (115vac) on the 2 black wire coming out of it
Aug 20, 2008 | Frigidaire GLWS1749A Top Load Washer
Spin cycle trouble
possibly a segment has raised on the motor armature or a faulty motor brush. pop off the belt and put it into a spin cycle to see if you still hear the noise- if so the fault is with the motor as the drum will be still. any scraping sounds in the drum may be a lost bra wire.
Jun 03, 2007 | Asko W640
Fisher and Paykel GWL11 Top Load Washer Logo
174 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
