Question about Maytag 15 cu. ft. / 425 liter Upright Freezer MQU1556A
I had some meat go bad in my freezer. I've cleaned and cleaned with hot water, dish soap, bleach, vanilla extract, oxyclean, and just now tried vinegar, next I will try squeezing lemon and/or placing charcoal. However, I've been told to make sure the drip pan also gets washed. I've pulled the front grill off, but what looks like a pan won't pull out. Is it meant to come out? How do I made sure it's clean?
  • jcamp738 Jul 30, 2010
    Sorry, forgot to mention the freezer is a Maytag upright Model# MQU1556AEW.
  • 4,793 Answers
Just spray it with 75/25 bleach/water it will kill any germs/smells....
also syringe the drain hole with bleach.(you only needed to wash out with clorine bleach and let it dry to totally clean the unit....)
Posted on Jul 31, 2010
Does a Danby 5 cu ft chest freezer have a drip pan? If not, how can I get rid of the rotten meat smell?
The drip pan on any freezer collects ice melts from the evaporator during the defrost cycle. Most of them are mounted on the compressor and use the compressor waste heat to evaporate the water.
If there is rotten meat smell in the drip pan it means there is also rotten meat smell in the evaporator coils and fins.
It's almost impossible to get "stuff" out of the evaporator fins unless you take the unit apart.
This means you will probably have to remove and replace the refrigerant plus evaporator and the entire process could take two 8 hour days or more.
Alternately,
after you completely wash it out you can try placing a pan of hot water in it and run it empty. The steam will condense on the evaporator and freeze. Then defrost it . Hopefully this will wash some of the funk away. You might have to do this several times.
If that doesn't work then cost wise the unit is junk.
Suggest in future wrap your meats in freezer bags or other
water/air tight containers in case power goes off.
Monitoring your freezer is a must to catch issues before smelly spoilage can set in.
Feb 04, 2018 | Danby Freezers
Putrid smell from fridge
add one bottle of vanilla extract (real not imitation) to a spray bottle of hot water remove all things from fridge and spray it down twice the hotter the water the better
Feb 12, 2012 | Bosch Freezers
What are the instructions for defrosting my upright frigidaire freezer and restarting and replacing frozen foods?
well when i used to have to climb into super market freezers and defrost we used water from the tap it doesn't have to be hot so i would take freezer outside to do this as it might not be drained and if it does have a drain it would only take a minute amount of water which an element would heat up and burn off so empty freezer take outside wash out with water till all gone and to get rid of any smells was out with vanilla essence all fridgies i know and myself used this as it will clean out fridge smells, you then replace freezer back once all water has dried off especially electrical try not to get wet but if you can't help it, it won't matter just let dry or blow out with air compressor then replace freezer back to where come from run freezer for a while till temperature drops below zero then start to restock the more you put in it the longer it'll take to freeze, so just do little by little hopefully this has helped but its usually the only way to do this
Nov 22, 2010 | Frigidaire Freezer Refrigeration White...
How is the best way to get the odor of thawed meat out of a freezer?
CLORINE BLEACH...clorine is a gas and it will dissipate if you leave the door open until dry...(the stronger the better and WEAR
GLASSES.)please dont use "cheap bleach"........
Sep 28, 2010 | Amana 14.9 cu. ft. / 422 liter Chest...
Meat spoiled over three week period in standup deepfreeze. Odour Contaminated freezer and general area with meat and fruit spoilage. Have cleaned everything with bleaches disinfectants and commercial...
use a strong solution of clorine bleach(in a spray bottle) to get into every nook and cranny/drainholes/drip trays/door seals and wipe dry(clorine is a gas and will dissipate within an hour or so)then wipe over interior with a damp cloth and plenty of bicarb,leave to dry and leave any bicarb residual inside fridge as this will absorb any smells left.leave door open for about a day in a warm (ish) room, this is the only way of deoderising......
Aug 20, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer got unplugged, meat spoiled, freezer cleaned, smell remains. What can we do to get rid of smell?
I have found that the best cleaners for removing left over odors are citrus based cleaners. They help to neutralize odors and prevent re-occurrence. You could also use a diluted bleach as well to sanitize the inside. Make sure it is not too potent or the bleach odor will overcome the bad odor in annoyance.
Good luck!!
Jun 15, 2010 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Hotpoint FZA80 freezer: water leaking
There's a drain hole inside the freezer in the bottom of the back wall ;probably is clogh .Put hot water into it to melt the ice and then blow it with air pressure;keep it clean pouring bleach throught it every 2 or 3 months.
Jul 18, 2009 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Odor
i would take the machine outside and blast it with a hose. use hot water mixed with bleach and dish detergent to clean the inside  thoroughly.
Jul 14, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Maytag 15 cu. ft. / 425 liter Upright Freezer MQU1556A Logo
87 people viewed this question
Top Maytag Freezers Experts
John Tripp
John Tripp
christian nielsen
Ismael Rodriguez...
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
