Question about Dometic Rooftop RV Air Conditioner
Duo therm model 600315.321 i compressor runs but fan does not come on so i ordered fan motor kit 3108706.924 & 3310522.002 unit came with a capacitor? does this replace the original capacitir or is this in addition to the compressor capacator the instruction does not say anything except connect white lead to unit capacitor common brown lead fan terminal on unit capacitor? no mounting for capacator. Nick
  • remsx Aug 01, 2010
    the duo therm motor kit came with a capacator when i opened the box on top of the rv there are 2 capacators installed the instructions do not say to remove one of the capacator or what ever what do i do
    Nick
    is there a real tec for dometic RV Roof ACs that understands my question. I purchased a replacement motor kit 3108706.924 & 3310522.002 the kit came with a capactor 2 terminals 4 lugs each it does not replace the original capacator which has 3 terminals 4 lugs each can a qualified tec answer the wireing question.
    Brigadier General:
  • 4,090 Answers
Nick, I believe this is to replace the already mounted capacitor as in most cases this is what gives out in majority of the cases and takes out the fan with it. Check the values on both and i think you will find they are the same or so close it will not matter.
Thanks for using FIXYA
Posted on Aug 01, 2010
  • 10,865 Answers
Hi Nick, yes use this new one to replace the original. The capacitor is sized for the fan motor so it is essential that they match. J.
  • 2,359 Answers
The function of the capacitor is to suppress the NOISE that generator onto the 12V lines.
There are two type being use on fan motor. Your should look like the one on the right (lower) /larger.
I would leave the capacitor on.
If your radio and TV tuner is picking up addition noise/interference then you should remove it.
Just fire up the TV + Radio and listen. Make you have your engine on a rev. the engine in 2-3000 rpm.
Some motor interference does not show up in low rpm and A/C setting is set to low.
I hope you get your A/C up and running soon.
Posted on Jul 31, 2010
  • Vincent_G
    Vincent_G Aug 01, 2010
    Capacitors value can be added together.
    Can you post the micro f value and voltage of these capacitors?
    Cap #1: _________________uf ________________ voltage
    Cap #2: _________________uf ________________ voltage
    Motor __________________12V? ______________ amp draw or approximate wattage_____________
    Model #__________________
I have a Ruud condenser on which I just replaced the capacitor and contactor. When I power up, the fan motor spins very slowly and a buzzing occurs about every 15 seconds. The buzzing sounds like it's...
Hello Zing77,
I understand that you are having a problem with your Rudd condensor. The fan is turning slowly and the compressor is making a buzzing noise which has a Diversitech hard start conected to the capcitor.
You have already replaced the run capcitory on the unit and have attached the compressor wire to therm and c and the fan to therm and fan. The hard start kit shoudl be attached to the therm and c with your compressor wires attached to the same place. The hard start kit is to give the compressor the extra push (electrical charge) to start.
You need to check your connections and make sure that you purchased the proper run capcitor. If you have purchased the proper compacitor and the connections are right then you have a bad fan and the compressor as gone out on the unit.
Thank you for choosing FixYa.com
Justin
Mar 27, 2011 | Heating & Cooling
Replacement Fan Motor
Try Johnstonesupply.com. Use the information you provided above.
May 06, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm Fan Blows, No cool air. Worked yesterday, not today?
most likely compressor running could be capacitor, breaker,relay,or compressor it self start by checking power to unit
Aug 22, 2009 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
675 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
