Question about Sony KV-32FV15 32" TV
Will my Sony 32FV15 receive/display HGTV programing/channels if I hook up a Cablevision HDTV box? I live in NJ but I am not looking for high definition quality picture as with my other TV's
  • 115 Answers
Yes, it will work. You can plug any source into it and it will work.
Posted on Jul 31, 2010
With Sony KP-46WT520 46 in. Rear Projection HDTV-Ready Television, does it receive digital signal over air? Do I need the separate digital converter box? What do I hook up where to get channels? and how do...
Hi Gwen,
This TV set doesn't have a digital tuner and you will need a digital converter box to receive over the air channels.
You still an antenna to receive the signal and then to connect it to your digital converter box. The programming should be easy.
The converter box should come with the user's guide on how to hook it up and program it.
Jan 13, 2018 | Sony KP-46WT520 46" Rear Projection...
I have a Sharp Aquos 52" LC-52LE810UN. I turned the tv on and assuming that my cablevision box is working, what do I do in settings or other aspect of the tv to make the 1080i work. I have another box...
Actually the cablevision box determines the 1080i. Once it is set on that box the television simply displays it. The cablevision box will have to be connected to the television with component cables or one hdmi cable in order for you to be able to choose 1080i on it. Usually there are resolution numbers on the side of the cable box that tell you if it's on 480, 720, or 1080. There is a red light next to the one the cable box is displaying. If this is not the right kind of cable box for that then you will need to get another one from Cablevision or just eliminate the box entirely and run the cable straight to the television. Yes you can do that and use the television's digital tuner for a beautiful, crisp picture. After removing the cable box and screwing the coax cable onto the back of the television you will have to press the input button and scroll up to TV and press enter (use a Sharp remote). Then press menu and scoll over to setup and down to CH setup. Then scroll to CH search and begin searching for the available channels. You will now use a Sharp remote to change channels.
Jul 06, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
The receiver is hooked up via HDMI and after about
user cable box hdmi direct access to tv hdmi input if ok ...receiver need replaced...if sam proble need replaced cable box...
Mar 21, 2010 | Sony STR-DG1000 7.1 Channels Receiver
I have a Philips TV, model HD2717 C101. All channels do not display--Why? It skips quite a few channels on scan, the only to get them is to actually select the channel individually.
Hi are you running it off of an antenna or cable?
Assuming you have a digital tuner and are selecting the proper type of channel search Ie: cable or air it could be that the tv needs a firmware update to the tuner.
I have experienced similar issues with several TV's I had an Olevia 37" HDTV that required a firmware update to get the tuner to properly decode channels.
I also have seen lots of cases were people have cable hooked up without a cable box and receive "mixed" channels.
I currently have Comcast and have 6 TV's hooked up 3 with cable boxes and 3 directly off the line. According to Comcast I should not be getting anything besides "basic" channels without a box but using the digital tuner in the TV's does pickup most of the channels and even some HD channels that are not there using their boxes.
Interestingly enough none of the TV's tuners decode the channels into the same "channel." As an example HGTV on 1 TV shows up as 84.4 but then 86.1 on the second and something like 84.11 on the third.
My recommendation run the auto program again then go through channel by channel and see if anything needs to be manually entered or deleted. I know this is a pain in the **** and takes about 20 minutes per TV but hopefully that will tell you if your TV tuner is relocating the channels to another channel.
Lastly if your tuner is not digital or if the tuner can't be updated you may have to use a secondary tuner such as one in a VCR to get the channels you desire.
This whole Digital Conversion that we have undergone has brought to light for me at least that our government and corporations don't care about the real world impact on the ordinary person.
Sure they made money on reallocating bandwidth and sure tons of new HDTV's and digital products (including digital cable) have been sold but I haven't come across anyone who feels they have benefited from the conversion forced upon us.
Hope this helps sorry about my rant.
Dec 28, 2009 | Philips Televison & Video
The HD video input channel has a slanted, dual picture.
check for the settings or the inputs doesnt match with the unit.
Jul 24, 2009 | Sony KV-32FV15 32" TV
Hitachi 51SWX20B is this TV HD ready?
In answer to your question, you have an HD TV Monitor, which means that your television is capable of viewing high definition, but does not have an HD tuner. You will need a separate tuner or in the case of cable, a HD cable box. These are the only options that you have for viewing high definition channels.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs UP) If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
May 24, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Dish Network Channels Work but Local Television Channels Do Not
Do you have an antenna hooked up? You'll need one hooked to your converter box because the digital signal is so much more difficult to tune in to. This may help:
www.antennaweb.org
If you live closer than 15 miles, rabbit ears
If you live closer than 20 miles, omnidirectional
If you live closer than 50 miles, midrange outdoor (oldschool arial w/ rotator)
Further than 80 miles, you'll need a long range with rotator, perhaps even an amplifier to go with it. Print off what your results were on antenna web and bring it to a RadioShack or a local antenna store and they should be able to point you to the right antenna for your particular location.
Apr 21, 2009 | Sony KDL46S3000 46 in. LCD HDTV
Why is there a long delay changing channels on my new Sanyo HDTV?
Are you connected to a cable box from your cable TV service Provider and use this device to select the channel you want to view? I have an HDTV which has the QAM tuning feature. Changing channels was instant until I accepted an offer from Cablevision for a 1 year rent free box and remote combo. The tuning box is a digital & analog Scientific Atlanta Explorer 4200 HD with a card slot for your subscription specs. This bypasses the tuner in your TV and the TV functions as a monitor.
If this is similar to what you have and you don't care about the channel/current program on screen display that appears for several seconds before the channel selection completes, perhaps the cable co. can adjust your box to supress this display if it will speed up the channel selection.
There is another annoying problem with this box. If you have a fraction of a second ac power interruption which might not even cause your computer to reboot, the cable box goes into a reinitialization that could take 5 minutes or longer. In my opinion, it is not worth the $6.50 per month charge we will receive when the year is up.
Aug 05, 2008 | Televison & Video
New Insignia 19 inch when hooked up to Optimum Cablevision does NOT get any cable channels..JUST basic channels...OLDER TVS all get the Cablevision full spectrum of chanels. Does it require a BOX to work...
yes, the premium channels are in a band width only reachable with a cable box. The standard or what would be over the airwave channels are available without a "box" in the basic cable tier.
Mar 16, 2008 | Televison & Video
Sony KV-32FV15 32" TV Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
