Question about Magnum S9 Base CB Radio
My magnum S9 wanders off freqency an the incoming starts sounding very scratchy, is there a mod ?
Magnum s9 they seem to drift a bit on till they warm up my s9 dose the same on till it heats up then it comes ok
Posted on Dec 01, 2011
Can a magnum s9 work with a standard cb radio
yes. only if it has been modded to work on cb channels. factory boxed radio will be 28-29MHz only...
Feb 15, 2011 | Magnum S9 Base CB Radio
Just buying magnum s9 radio can it be used on 11 metre band or has it got to be modified for 26-27 cept channels as i think its just a 10 metre radio please advise many thanks.
Hey,
The magnum S9 is factory set for the 10 Meter band but can be "tweaked" to get up into the 11 meter band...
check out this neat and easy mod:
http://www.radiomods.co.nz/magnums9mod.html
Hope this helps!,ben
Jan 13, 2011 | Magnum S9 Base CB Radio
I got a used magnum S9 and i keep getting reports that it sounds overmodulated. I think the limiter is cut. Id like to find it and put it back in. What do i need to look for in the radio?
find the mods on the radio to find out the limiter number example tr32 or dr 112these are not actual mods for your radio it will be listed on the green part of the board in white most likley it will be removed so you would have to get a new resistor and soldier it back in adjust your mic gain down and keep your moulth away from the mic when speaking if you havent done that already .You could take it to a tech.
Nov 15, 2010 | Magnum S9 Base CB Radio
Magnum s980 stopped giving me sound from speaker.also transmit scratchy.audio scratchy.
Pour gasoline inside of it and set it on fire for 5 minutes. When done crank up every thing that can be adjusted inside for more modulation and power. Cheap radio. CB junk.
Sep 12, 2010 | Magnum S9 Base CB Radio
No power
Magnum s9 rf transistor replacement Hi i hope this link helps you out let me know how you get on with it cheers
Jul 20, 2010 | Magnum S9 Base CB Radio
Rk56 to magnum s9
pin 1=braided&red/ pin 2=white/ pin 3= blue/ pin 4 =black
Jul 13, 2009 | Magnum DeltaForce CB Radio
Wat power does this radio push
Generally All CB Radios will only push 4 watts. This is only if you have a SWR of 1:1
Jul 11, 2009 | Magnum S9 Base CB Radio
Magnum s 9 sideband fault
sounds like tuning, have you been through the alignment procedure? take a look at cbtricks.com for the info
Oct 03, 2008 | Magnum S9 Base CB Radio
Magnum S9 Base CB Radio Logo
178 people viewed this question
Top Magnum Radio Communications Experts
Jim Goldsmith
Jim Goldsmith
James Walker
James Walker
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
