Question about Koiiler 8686-C Car Audio Amplifier
Just like to know what size fuse i need
On a koiillrer xm8686 600w
What size fuse peavey XM-6
Fuse is 5 A for 120 VAC and 2.5 A for 220-230 VAC, usually 5 x 20 mm.
Oct 14, 2015 | Peavey Audio Players & Recorders
I need to know what size fuse goes in the fuse panel in the # 17 space
look in the owners manual.it will tell you the sizes for all the fuses.
Jul 10, 2009 | 2002 Ford Ranger Regular Cab
Location of fuse box
There is no way on earth to answer your question without knowing what year, make and model vehicle you are asking about. Also, You ask what size fuse. There are many size fuses. Are you asking about interior lights, signal lights, tail lights, stereo, a/c or what?
Nov 08, 2014 | Cars & Trucks
What does the fuse look like for 2004 mercury mountaineer
Sounds like you need more help than just knowing the shape. Go online and look up fuses at a autoparts store.
You need to know where the fuse is, and what size is proper. Replace with identical factory Rated size. Not bigger or smaller.
What you would do is inspect the part that does not work to find out why it broke the fuse. Only rarely would there not be a reason.
Jan 08, 2014 | 2004 Mercury Mountaineer
I need to know the size of the IT Belt reset fuse in an Oki c5500
Have you contacted OKI Data? Live customer support is available 24/7 (within the US and Canada) at 1-800-OKI-DATA.
Jan 14, 2013 | OKI C5500n Printer
I need to know what size fuses go where?
jsut put 15 amp everywhere,should be enough but to large to cause any problems.
Jan 05, 2012 | 1991 Dodge Dakota
I have a Schumacher WM-10000A speedcharger and need fuse size
The fuse is a 12.5 Amp 250 V Fuse. I have the same charger and I think mine is toast. Replaced the fuse and it blew.
Sep 19, 2009 | Schumacher & Fast Charge Starter Charger
Size of fuse for Ultimate PA2204
O SO U JUS NEED LIKE A FUSE THAT IS ABOUT 20-40 AMPS
Mar 20, 2009 | Car Audio & Video
Jensen LXA400 Fuse Size and RCA hook up for 2 channel mode?
take it to a stereo shop. there are variables you may not be aware of when hooking up speakers to an amplifier like ohms, very important!
Dec 08, 2008 | Jensen LXA400 Car Audio Amplifier
Fuse size
I have one of these for parts, fuses look ok, but doesn't power on..do you know where your fuse is on the board?jerrye@rock.com
Jan 03, 2008 | Audio Players & Recorders
Koiiler 8686-C Car Audio Amplifier Logo
Top Koiiler Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Koiiler Car Audio and Video Expert? Answer questions, earn points and help others
