Question about Nintendo Wii Console
We can't set are wii to are router
Error code
51030
    Genius:
  • 1,234 Answers
Error Code: 51030The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
  • If you are getting this error after completing a system update, this is usually because the console resets to using the first connection slot after an update. There are two things you can do:
    • If you know which connection file you were using before, you can select that connection file, then select "Use this connection" to change that to the default. You will need to do this each time they download an update.
    • If you don't know which connection file you are using, or if you would prefer not to update the active connection file each time, try to clear, and then re-create your connection setting in slot one before doing the remaining troubleshooting.
  • Check to see if the router you are using is a known to be incompatible. Click here to view our list. If your router is known to be incompatible, we recommend using a different router if possible.
  • Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings. To verify:
    1. Login to your router's settings (click here and select your router, if available, for information).
    2. Look for the section for SSID (typically in the "wireless settings" area).
    3. After you find the SSID (network name), verify in the manual settings of the Wii console that the SSID appears exactly as listed in the consumer's router. This includes making sure capitalization, spaces, or special characters match exactly.
  • Look up your router, if available, in our list of wireless routers, and check for any special notes that may be necesary to get the connection to work properly.
  • The router may not be assigning an IP address to the Wii console, and a connection using the "Manual Settings" may be necessary. Click here for help.
  • Your router may require a firmware update to work properly with the Wii console. Firmware updates can usually be found on the router manufactruer's website; consult the manufacturer for more information.
Posted on Aug 27, 2010
My wii is giving me an error message of 51030
Error Code 51030, 51031, 51032 The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
Nov 14, 2017 | Video Game Consoles & Games
What is the error code 51030 and the SSID
Error code 51030 is : Unable to connect to your wireless network.
The SSID is the name of your wifi network. You will need a wireless router if you do not have have one. If you do you will have to set it up to broadcast your internet and set up security with a pass key or password. Here is a link for more info. Nintendo Customer Service Nintendo Wi Fi Connection Error Code Results
Mar 07, 2015 | Nintendo Wii Console
Wii error message 51030
How to fix: Power cycle your router; redo the connection settings on the Wii and try again.
Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected. We suggest following our guide to create a new connection file and start over.
visit the CBR Tech Solutions
Jan 12, 2014 | Netflix
What is error code 51030
Error Code: 51030
Likely cause: Your wireless router may need to be power cycled, or the connection settings have changed.
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
  • Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected. We suggest following our guide to create a new connection file and start over. If at the end you still need help, you'll find contact information to reach our specially-trained representatives.
Sep 21, 2013 | Nintendo Activision Guitar Hero World Tour...
I'm getting an Error code 51030 when I'm trying to make a wifi connection on my wii console
Error Code: 51030
Jun 05, 2011 | Nintendo Wii Console
Error code 51030 what is ssid where do i find it
Hi there!
Error code 51030 means you cannot connect to your wireless network.
SSID (Service Set IDentifier) is the "name" of your wireless network. You'll have to make sure that you are connecting to your own wireless connection and if you don't have one, then you'll need to setup a wireless network.
Hope this helps.
Apr 28, 2011 | Nintendo Wii Console
51030
Sorry to hear you are having problems with your wii. According to Nintendo, error code 51030 is:
"Error Code: 51030
Unable to connect to your wireless network"
Make sure your wireless network is set up correctly with the correct SSID and encryption key. You may also just need to power cycle your router.
For more information, here is the official support article from nintendo for this error:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=lang
Apr 27, 2011 | Nintendo Wii Console
Error code 51030
Wii error code 51030:
Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii online and test for proper response.
Step by step instructions to connect your wii to the internet can be found here
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
Good Luck,
Rodrick
Apr 23, 2011 | Nintendo Wii Console
Error cose 51030?
Error Code: 51030
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router by unplugging it from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the router to initialize, then plug in the router. Try to connect the Wii or Nintendo DS online and test for proper response.
Jan 02, 2011 | Nintendo Wii Console
Cant connect my wii get error 51030
This might be handy: http://www.nhotspot.net/wii-error-code-51030/ and http://www.wiierror.com/wii-error-51000.php
Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed.
Verify that the proper Connection File (1, 2, or 3) is selected in the Wii System Settings.
If you have multiple connection files setup, and you have recently received a system update, it is possible that the update has caused the Wii console to select a different Connection File. Click here for step-by-step instructions on viewing your connection settings.
Make sure that your network's name (SSID) matches exactly to what you have entered in the Wii console's settings.
Log in to your router using the default IP (consult the router's owner's manual for assistance).
After you find the SSID (network name), verify in the Internet Settings of your Wii console that the SSID is appearing exactly as listed in your router. This includes making sure capitalization, spaces, or special characters match exactly.
Oct 19, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
64 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
