Question about Bissell 1400 Little Green Pro Canister Steam Vacuum
Pump motor on Bissell 1400 Little Green Machine
Need to know where the wires go on the pump motor
  • 4 Answers
When I reassembled mine, there was 3 wires connecting to the motor, Green, black and red. The Green one was connected to the lead on the side of the motor, the black one on the lead directly above the green one, on the same side. The red one was on the lead that was the only lead on that side of the motor. Hope that helps.
Posted on Aug 04, 2010
  • Jeff Day Jul 03, 2013
    How many volts does the motor need to run?
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    Bissell little green instruction manual
    Hi, it's Jeremy from Crucial Vacuum.
    Attached is a copy of the user's manual for your Bissell 1400 Little Green Pro Canister Steam Vacuum:
    http://www.bissell.com/assets/0/132/134/228/83bcc4e8-41c1-4b5f-8547-17c9af450a80.pdf
    You can purchase direct your Bissell replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
    http://www.crucialvacuum.com/bissell.html
    I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
    Jeremy Lerner
    Crucial Vacuum Customer Care
    Aug 04, 2014 | Bissell 1400 Little Green Pro Canister...
    I need the switch in the handel on the little green machine model 1400 J04336 When I put this in they say it can't be found
    If you go to this URL:
    http://www.vacpartswarehouse.com/Bissell-Little-Green-Models-1400-2-1400-5-1400-H-1400-U-s/591.htm
    you will see an exploded view of your unit and see the switch and associated part number.
    If you find this solution helpful, I would appreciate a Thumbs Up from you. Thank you! Paul
    Oct 07, 2010 | Bissell Vacuums
    My little green machine won't dispurse the water. what could be wrong?
    You can disassemble the unit and check to see if the pump motor has seized.
    the motor has a black, red and green wire attached, is encased in a plastic housing, and is right next to the vacuum assembly. Don't cut the line attached to the plastic housing, you don't need to and it can be a pain to reattach later. just slide the whole white housing up towards the black vacuum assembly, and undo the wire leads attached to the motor, they just pull off (make sure it's not plugged in) making sure to note which wire attaches to which lead... i marked each lead with a colored marker to be sure.
    Use a pair of pliers to turn the drive shaft if it has seized, and be sure not to lose the small rubber o-ring that sits around the shaft. Lubricate at the base where the drive shaft meets the motor with just a drop of 3-in-1 electric motor oil and then reassemble the housing, attach the leads, seat the motor back into the seating (make sure the bottom nozzle goes into the green water feed coupler!) and reassemble the case.
    worked well for me, if it still doesn't work you could buy a new pump and install it. they go for around $10 on ebay and amazon.com
    Jun 24, 2010 | Bissell 1400 Little Green Pro Canister...
    Need instructions on how to fill and operate a new machine. (Bissell Little Green)
    BISSELL User's Guides can be downloaded at www.bissell.com
    On the front page under Customer Service click on User's Guides and enter the model number of your unit.
    User Guide will be displayed as a PDF file.
    Mar 18, 2010 | Bissell 1400 Little Green Pro Canister...
    Clean solution leaking out the bottom
    open it up again and check the pump there is probably a hose leaking ,did you put the clamps back on the hoses
    Apr 14, 2009 | Bissell 1400 Little Green Pro Canister...
    Bissell 1400 Little Green Pro Canister Steam Vacuum Logo
    373 people viewed this question
    Top Bissell Vacuums Experts
    Jim Parker
    Jim Parker
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
