Question about Internet Q See Ufo CCD Camera
Q-see qsd9004 worked for a while then "video loss" displayed. Reconnected/installed all wires - worked for a moment, then back to "video loss." What should I do?
Control Cluster doesn't work
The control cluster usually has a fuse and a ground wire. Check both.
Mar 19, 2014 | Motorcycles
Macbook pro a1260 display not working
your video cable may need to be reconnected, but it's likely that the lcd is bad.
ifixit has guides for repairing and replacing on macs.
Jan 02, 2014 | Apple MacBook Pro A1260 Laptop LCD Screen...
Screen not displaying anything. BUt the machine is on.
1.Diagnose the problem with your computer. Watch the screen from the moment you hit the power button through the time it should take to boot into the Operating System. Adjust the computer's contrast and brightness through their full ranges to make sure that the display settings have not been changed. Reset the computer's LCD-External Monitor display with the LCD/External Monitor key combination and reboot the computer. Continue to Step 2 if the screen is blank throughout the booting process.
2.Adjust the screen from its fully closed position to its fully opened position. Watch the monitor for any change from a blank screen to a display or vice-versa. If the screen flashes or cuts out, the LCD panel will need to be replaced. Skip to Step 5.
3.Skip this step if your computer does not have an external monitor output. Connect your computer's external monitor output to a known good monitor and change the display from LCD to External Monitor (the keystroke combination is different for all notebook brands). Reboot the comptuer, if necessary. If the computer does not display to the external monitor, the video card could be bad. Skip to Step 6.
4.Consult with a professional technician to determine the cost-effectiveness of replacing your computer's LCD if you are not knowledgeable in that area. Purchase a compatible replacement LCD and install it yourself, or pay a professional technician to do so if you do not feel comfortable performing the repair.
5.Verify that the monitor connection cables are not loose or disconnected before attempting to replace it. Replace the monitor yourself by removing the old monitor. Remove the hinge covers by gently prying them. Check if they are screwed to the computer before prying. Find the monitor cable's connection to the motherboard. Turn your computer over and remove any plates that may cover the point of connection. Note the orientation of the cables before disconnecting them. Unscrew the monitor from the hinges and gently detach it from your computer. Feed the new LCD panel's wires through the same path as the old wires, and reconnect them. Secure the new LCD's hinges and replace the hinge covers. Power up the computer and check that it works. If it does not, recheck the wire connections.
6.Consult with a professional technician to determine the cost-effectiveness of replacing your computer's motherboard or video card if you are not knowledgeable in that area. Purchase a compatible replacement motherboard or video card, and install yourself or pay a professional technician to do so if you do not feel comfortable performing the repair.
7.Replace the motherboard by disassembling the computer. Document every connection and be sure to retain all screws and small parts in order to reassemble the computer correctly. Reassemble the computer and power it up; check the keyboard to make sure that it has been reconnected properly. Replace the video card by removing any covers or plates that hide the card. Remove the old card and install the new card in its place. Power up the computer to test the display.
Sep 27, 2011 | Computers & Internet
My wii has no power at all. ive unplugged and reconnected all the wires put there is still no power, and every thing else in the outlet works
I just had the same problem moments ago, if you unplug the power cord from the wall and the unit and let it sit for a few minutes, then replug it back in, it should come back. Unplugging and plugging back in without waiting won't work, you have to wait 2-5 minutes.
Dec 16, 2009 | Nintendo Wii Console
Loss of one color in monitor
some of the vga conncetror pin is not working then that type of problem is presnet my sugestion is change the vga cable and install new one .....ok
Sep 22, 2009 | Computers & Internet
Dell Lattitude C840 Display NO WORK
If you are getting lines on an external display, then the video card needs to be reseated or it is bad. Since you just had it worked on, I'd take it back and tell them you aren't satisfied (most places will guarantee their work 30 days).
Mar 01, 2009 | Dell Latitude C840 Notebook
No display
Try swaping your memory with a known good stick of ram.
Are you sure your monitor is good? Video cables?
Try changing (if pci) slots when installing video card.
Other than these 3 things the only pretty sure thing is; sorry, mother board or cpu.
Jul 01, 2008 | E-Machines eMachines Desktop PC
Samsung B/W Observation System - Model# SSC-12
I have the same problem and I found out that a resistor went bad and then a capicator went bad.you must have them check and replcaced
Oct 26, 2007 | Samsung Weather Resistant Security Camera...
Internet Q See Ufo CCD Camera Logo
792 people viewed this question
Top Internet Home Security Experts
Lawrence Oravetz
richie46
U-Spy Store DBA Pro...
Level 1 Expert
Are you an Internet Home Security Expert? Answer questions, earn points and help others
