Question about Kenmore Elite HE4 Electric Dryer
Dryer air is not hot ... is there something i can do or check before calling for service?
    President:
  • 3,773 Answers
Check breaker and 220v at the wall it will run on 110 but not heat
Posted on Jul 30, 2010
  • Leo Ponder
    Leo Ponder Jul 30, 2010
    Check thermal switch at top of element case in back(2 wiresd)
Kenmore dryer overheating on airfluff
driers that over heat may have the lint filter blocked preventing free air flow
check / clean it regularly
Have an accredited electrician / service agent check ti out
Nov 04, 2015 | Kenmore Dryers
How do I clean the interior of a LG DLE3733W Dryer?
Hello Mary;
My name is Peter. I am a retired field service appliance technician.
Both LG & Samsung appliances are a service technicians nightmare. They have the highest service call rate, the most expensive parts and take the most time to access and repair parts. I will give Samsung a thumbs up on televisions and stereo's.
It would be nice if consumer reports would survey field service technicians rather than owners and get the real story.
Believe me you do not want to disassemble. You are going to end up calling a service company to put it back together and get a $250.00-$300.00 bill.
Ok, what can you do? Air flow blows 95% of the lint out the connection to the outside air discharge behind your dryer.
1.) Pull your dryer out to the point that you can get behind it.
2.) Unplug your dryer.
3.) Hot air distribution manifold - There are several screws holding this on. There are no hot electrical components to be concerned with. Remove this.
In the bottom rounded part is where you get plugged up. Clean this out.
4.) Hot air discharge at the wall - Usually, the connector vent hose is held on with band clamps. In this case you need a flat heat screw driver to loosen and remove the vent hose.
5.) With a vacuum cleaner hose, vacuum out the hole in the wall as far as you can reach. Then, vacuum out the air discharge as far as you can reach. The hot air blower wheel in in the front of your dryer.
6.) Before reinstalling the hot air distribution manifold and connecting the out side air duct. Plug your unit in and turn your dryer on and run for 5 minutes to blow out excess lint. The hot air distribution manifold and the outside air duct create a back pressure. This way your blower wheel will run full open.
May 21, 2015 | LG DLE3777 Electric Dryer
The heat on our tumble dryer does not appear to work but I am not sure how to detect if we are doing something wrong?
Hello Colin;
There are many different dryers with different electrical components.
You may have a hot air circulation problem. This is common where lint will block the air flow. You have a hot air distribution manifold, remove the manifold. At the smaller bottom is where the fan wheel discharges, this is where dryers usually plug up. The manifold is located where the hot air fan discharges air. Also, check the fan to make sure it is not plugged up and turns freely.
Needless to say unplug your unit first.
It could be a bad thermostat, and several other things.
If your unit is not plugged up with lint, please post again and provide a model number so I can see what you have
Nov 24, 2014 | Dryers
My ge adora dryer is not getting hot. What do I check for?
Are both circuits hot? (Power to both 110 volt lines)
Does dryer rotate?
Can you open the dryer, find and replace the heater coils?
If you answer no to any of the above, you need a professional repair person.
May 26, 2014 | Dryers
I very recently-9/28/13- purchased an LG clothes dryer-model #DLE487OW. A breaker was kicked and since the electrity was restored, I am getting a check filter message with cool air only blowing in dryer. ...
Call LG people before you call the service man.
Really, you have no heat. Check out the heating circuit...heater, t/stats; vent. etc. Something is sensing that the filter is blocked when it is not....check air flow.
I doubt the board is a problem at this point.
Oct 18, 2013 | LG Dryers
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
Why have my dryer stop getting hot to dry clothes?
call an electrician to test the element or if gas call a gas fitter to check the gas operation
May 16, 2017 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer will not get hot. Is there something simple that I can check before calling a repair man?
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Select a heat setting other than Air Fluff.
Make sure gas supply is on for gas dryer, Clean the lint filter and exhaust duct.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 21, 2010 | Kenmore 73952 Gas Dryer
Dryer trips breaker as soon as i try to start it.
Use or borrow a volt ohm meter and check for a grounded hot wire. You may also be exceeding the start up load on the 20 amp breaker. Test this theory (after you make sure that there are no ground faults) by starting the dryer in a "air fluff" mode without heat. If the dryer starts in the "no heat mode", switch the heat on - if you blow the breaker you know that the 20 amp breaker cannot handle it. Before you do any of the above - check your dryer manual for the service requirments. If you don't have the manual go to the mfg. web site and download it.
Feb 04, 2009 | GE DBXR463GB Gas Dryer
Cabrio Dryer keeps blowing Air Flow fuse?
Hello, yes it is possible that the thermal fuse has gone again. Before attempting any repair yourself please unplug the dryer. The thermal fuse is located in the rear of the dryer the service panel would have to be removed. it is on the hot air duct has 2 wires going to it white in colour about 1 1\2 ' s long and 1\4 " wide. Also locate wear the vent is outside and make sure you have good air flow. good luck
Dec 20, 2008 | Kenmore 62602 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
120 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
