Question about Kenwood 1080VR Receiver
Buzzing sound with ac3 conneted - Kenwood 1080VR Receiver
Thomson DH1685P set top box
Many MKV videos has DTS audio which is propietary therefore unsupported by media players. The solution is to convert the DTS audio to AC3 using a free utility called MKVtoAC3 or any other DTS to AC3 programs. Note that I have the exact Thomson model you have
May 26, 2013 | Computers & Internet
Tip
How to convert MKV DTS to AC3 on Windows 7
Converting MKV DTS to AC3 can be troublesome. You extract the audio from MKV with an app, convert DTS to AC3 with another app, and add the new AC3 audio to the MKV files with a third one. Actually, Pavtube MKV Converter is all what you need for easy and fast conversion of MKV files. You can convert MKV DTS to AC3 or AAC audio; merge multiple MKV video clips into one file, cut off unwanted black edges; and convert MKV to versatile video formats for playback on portable players. This guide will show you how to convert MKV DTS to AC3 5.1 sound step by step. You may download demo version of Pavtube MKV Converter and try it out.
Step One. Load MKV DTS files to MKV Converter.
Once you run it, this intuitive interface will pops up, from here you click "Add" button to load MKV files to this program. Double-click on an MKV file if you’d like to preview it or take some pretty snapshots.
Step Two. Select output format and set save path
Now that MKV files are imported, the next you do is hitting the drop-down button of "Format" and select an optional format. There are customized formats for different devices and application. MKV is available in both Common Video and HD Video options. You may click the folder icon at the opposite side of "Output" and browse to a different location other than default destination folder.Moreover, if you would prefer to combine multiple MKV files as one file, you may tick the checkbox "Merge into one file" and check these files.
Step Three. Set advanced video and audio settings
Click on "Settings" button, and the following window will pop up, which enables you to adjust video and audio parameters including codec,aspect ratio, bit rate, frame rate, sample rate, etc. Here you set Audio codec as AC3, and adjust Audio sampling rate and Bit rate to fit your player. By the way, 5.1 sound is available in "Channels".
Step Four. Convert MKV DTS to AC3
So long as the former three steps are finished, you can click "Convert" button to start conversion. Once click this button, the ViewLog will present you all the info such as conversion progress, conversion state, elapsed and estimated conversion time, and generated and estimated conversion file size. There is also another option that is "Shut down computer after conversion",just check it before you go out for a walk or do something else.
on Feb 07, 2010 | Audio Players & Recorders
Tip
Easiest way to convert AAC 5.1 to AC3 5.1
Surfing online, often see people asking questions like this: "Does anyone know how to convert 5.1 AAC to AC3? If so, what software do I need and encoding/conversion settings. Thanks in advance for any help." As a matter of fact, this is a normal question, because some of our usually used multimedia devices can decode or read audio codec selectively only, we have to do format conversion to meet their requirements. For example, some theatre amplifier can only decode AC3 5.1 format, while Apple TV can only deal with AAC audio, or whatever. In this post, I’d like to document a easiest way to convert AAC 5.1 to AC3 5.1, in the near future, if I have enough spare time, I’d like to talk more about how to convert AC3 to AAC, that may be in my another post.
To convert AAC 5.1 to AC3 5.1, you just need Pavtube Video Converter only. This program is capable of reading a wide range of video and audio formats, including videos from DVs or camcorders (JVC, Panasonic, Cannon, Sony, etc.), TiVo (*.tivo), DVDs (*.vob), Blu-ray (*.m2ts,), YouTube (*.flv, *.f4v), and many other videos in common media formats, like mp4, avi, mkv, ts, tp, evo, aac,dts and so on. The detailed process is as below:
Step 1: Click "Add" button to load your video files
Step 2: Select output format and specify save path
Click the pull down menu of "Format" to select your needed format, here I choose "MKV HD Video (*.mkv) for instance. Click the folder icon at the end of "Output" to decide where to locate the output files.
Step 3: Click "Settings" icon to specify AC3 5.1.
Once click "Settings" button, a "Profile" window will pop up as above. Now you should select ac3 as audio codec, and select 5.1 as audio channel. By the way, you’d better adjust audio bit rate at 448K to match the effect of 5.1 channels to full extent. All needed settings are completely showing in the above interface, you just need follow them, and this will lead you to get an AC3 5.1 surround sound successfully.
Step 4: Click "Convert" button to start conversion
As long as conversion is finished, you can click "Open" button to find out the output files with the converted AC3 5.1 channels.
Well, hope this helps.
For more: http://www.pavtube.com/video_converter/
on Jan 28, 2010 | Computers & Internet
Hi, my Iomega ScreenPlay play MKV files but there is no sound when i connect to HDMI cable.
This mediaplayer can't read DTS sound, only AC3.What I do is that I use AudioConverter to change the .mkv files to AC3 sound before playind them. This should solve your problem.
Dec 16, 2011 | Iomega ScreenPlay
Dolby AC3 Audio (code "8192")
Without the full error code, I have to assume this error ends with "You may need to install a Directshow decoder for this audio format."
Look on this page in the left upper corner, you will see :
Moviecodec Forums/Downloads , when you put the cursor on this, another choise can be maken, then choose below in that choise : Audio Codecs, when this has been opened you have to take the first of the row ( AC3 Codec ( tag 2000/8192
Clic on this one, save it to a place ( new folder )in your "received files " and then open it( double clic )
Put it in your " program files " following the instructions.When this is done, your movie will have sound.
It works with my movie
Mar 04, 2011 | Apple Computers & Internet
It say's, "this file contains
look up dolby AC3 audio player on google there will probably be a free download
Feb 28, 2011 | Computers & Internet
My headset is conneted, but no sound in earphone
Put the headset in the cradle, press the button the base with the >< picture and hold till the blue light on the headset lights up then disappears.
Aug 11, 2009 | Jabra GN9330 Wireless Headset
Bose 321 is unable to read 6Channel AC3 Audio. Any way it can read the same?
This is true. The 321GSX will decode Dolby Digital 5.1, DTS 5.1 or PCM 2.0 digital signals from external sources (like most receivers) but will not decode any 6.1 content. AC3, mp3, mp4, wav, aiff all should work from a properly formated CD or DVD (must be -R or -RW format, or commercial), but not multi-channel AC3 content.
Jun 10, 2009 | Bose 3 2 1 GSX System
Canon HS10 camcorder and Imagemixer 3
To play the audio you need to download the AC3 filter pack here: http://www.free-codecs.com/AC3_Filter_download.htm. I have no idea why Canon didn't bundle this codac with all of the software they provide, but it worked for me. I use a Canon FS100, and had no sound in WMP (or any other Windows apps except VLC Media Player) until installing this.
Nov 09, 2008 | Computers & Internet
My PS3 wont start up. when i turn it on i get noting no sound or image .
Check your HDMI (looks like USB connetion) Connection or your Composite video connection (yellow, red, white connections.) Make sure they are correct and tight on both your TV and PS3.
Most common connection to use 1st is the Composite video connetions. Yellow is your Video display; Red and White are your Sound!
Good Luck.
Sep 26, 2008 | Video Game Consoles & Games
Kenwood 1080VR Receiver Logo
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
