Question about Campbell Hausfeld 26 - Gallon Air Compressor
I have a CH 5.5hp, 26 gallon 150psi max air compressor that runs constantly even after passing desired psi with a max psi of 100. However, even after 100psi the motor keeps running with no increase of psi. The seems to be no obvious leads anywhere...
    Brigadier General:
  • 4,090 Answers
When your compressor pressure reaches the cut out level, and the compressor doesn't stop, that means that electricity is still flowing to your electric motor, and it keeps running.
The compressor will then keep running until the pressure relief valve opens, and that should bleed the pressure in system down below a danger level even though, then, your compressor will keep running until something fails.
If the compressor won't shut off at the cut out pressure, it's 99% sure that your cut out pressure points in the switch are staying closed allowing power to flow to the compressor motor, and the simplest thing to do is to replace the pressure switch.
You could try this... but it will be for short duration and happen again.
IF contacts are stuck, these contacts are not real good with high voltage.Disconnect the power and manually pull the contacts apart if they go right back together then your air adjustment need to be readjusted, if they stay apart check the contacts for burned spots. You can sand them to clean them up but this will happen again over time. Bigger compressors use magnetic starters which use low voltage to the regulator and the Magnetic starter controls the high voltage.
Please rate my help++++Thanks for using FIXYA
Posted on Jul 30, 2010
  • lakegal76 Jul 31, 2010
    THank you for your response, however, I'm still a bit perplexed.
    If it is these contacts staying open, why does the psi not get any higher than 100 psi?
    A couple of times you said even if I make the effort to "fix" the problem, it will more than likely return. In each case, why do you think this?
    If you were me, tell me exactly what you would do...step by step so I may have the best chance of success.
    Thank You!
  • dennis bullard Jul 31, 2010
    The preset safety factor is set to 100PSI The maximum amount of pressure that the tank can reach as determined by the guage of the metal, weld and safety tests
    The safety release valve prevents it from escalating beyond this level of pressure recommendation, even though it continues to run. If it didn't "bleed off the pressure it would eventually split the tank or blow the safety valve to smithereens
    Despite fixing the points by cleaning them the metal has become weakend and will burn or stick easily again, locking the contacts again . The only true method of dealing with it is to CHANGE the contacts, cleaning them is only a temporary measure till new contacts can be fitted.
My D55141 heavy duty 2gal (7.6L) 150 psi max builds pressure up to around 150 releases pop off valve then keeps running, what causes this problem?
The pressure switch is either out of adjustment or has failed. The compressor should shut off at a much lower pressure than the safety valve (~100 psi)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 20, 2014 | Air Tools & Compressors
Husky 26 gallon air compressor parts
Worn piston/rings, or valving issue. Got a parts book?
Dec 16, 2013 | Air Tools & Compressors
Compressor relief valve opens 150lbs on my d55141
That is the compressor's holding capacity 150psi. Therefore, the cut-out pressure has been reached. The safety valve opens to relieve the excessive psi. Compressor should come on at 120 psi.
May 15, 2012 | Dewalt d55151 factory reconditioned emglo...
Max pressure 40 psi
i would say rings r gone on piston if u take out oil filler bung to see if it blowing air dat will tell the tale
Jul 28, 2010 | Campbell Hausfeld 26 Gallon Low Rider...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Does not auto turn off
Sounds like the pressure switch is shorted together. Unwire the switch and see if it shuts off.
Apr 08, 2010 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
I have a model FP209501 Air Compressor 2 Gallon,
2 gallons is small to begin with u need to buy an in line pressure adjuster/regulator their a few bucks and can be attached to the paint gun or line and will keep the pressure at ur adjustment the regulator on the tank sets the tank pressure at 50 so when u us it will let it drop down to about 45 than start up to build the pressure up to 50 than shuts off than repeats it self the inline keeps pressure steady even if tanks are at 200 psi
Jan 18, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
I have a 26 gallon campbell compressor elec. Problem is runs fine for a min. then shuts off and on every couple of min does not get to max psi
REPLACE THE PRESSURE SWITCH BUDDY THESE CAN BECOME FAULTY WHICH IS THE CASE OF THIS PROBLEM BUY THEM ON EBAY FOR CHEAP THE PRESSURE SWITCH CONTROLLES YOUR ON AND OFFF AND STOPING PRESSURE SO THAT HAS GOT TO BEE THE PROBLENM OR TRY AND TAP IT A BIT TO MAKE IT WORK
Oct 21, 2009 | Campbell Hausfeld 26 - Gallon Air...
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
85 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
