Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
Motor turns but trimmer head not turning. Believe the shaft has disconnected from motor or from trimmer head.
5 Suggested Answers
  • 9 Answers
SOURCE: Black and Decker Grass Hog Model #GH1000
the drive cable probley kinked or bent and does not drive the head the cable goes from the motor to the head take the clamp bolt out and lift the head off the cutter check the cable
Posted on Jul 30, 2008
  • 32 Answers
SOURCE: Motor spins, shaft does not...
sounds like the cable has broke inside the tube or it popped out of place. loosen the bolt on the motor casing holding the tube and separate the two pieces and pull the cable out. Should be a square at each end of cable.. if not post again
Posted on Jul 23, 2009
SOURCE: Black & Decker gh1000 trimmer head not spinning
The same thing happened to me. You either have a ruined belt pulley, or, hopefully, the belt burned out. Belts are easy to find online, but the housing is tricky to remove - see other posts.
I finally got it the plastic housing apart on my trimmer (there is one screw hidden under the label), only to find a total meltdown. The plastic pulley is ruined, and the only way to get it replaced is to buy a new motor (the most expensive part).
If your trimmer is no longer under warranty, then you can get a refurbished gh1000 for the price a new motor unit.
Posted on Jul 26, 2009
  • 74 Answers
SOURCE: grasshog timer
If you have the model # NST2018 then the only thing wrong is that a .30 cent retainer clip at the upper end of the spindle shaft is missing. A local hardware store should have one that will work. There should be a thin washer that will go between the sleeve bearing and the retainer clip that will be inside the housing as well.
Posted on Sep 15, 2009
Fixing straight shaft attachment on Troy-Bilt string trimmer
Here is a link to sears parts direct. You can see prices for all parts and make a decision from that.
TROYBILT Trimmer Boom and trimmer Parts Model TB75SS
Aug 16, 2014 | Troy-Bilt Tb75ss
Trimmer head won't rotate
Usually this is a clutch problem, the clutch is under the drum and when it engages turns the drum which turns the drive shaft which turns the trimmer head. If the drum is not turning than it is the clutch, if the clutch is turning the drive shaft could be broke, if the drive shaft is not broke than the problem would be in the gears of the trimmer head.
Apr 11, 2014 | Stihl FS 85 Weed Eater
Stihl fs 55r head won't turn
Check drive shaft. Some models have a flexible cable drive shaft that is prone to breaking. also make sure the drive shaft is engaged in the clutch drum and in the gear head end.
Mar 25, 2013 | Stihl Garden
I have ryobi rlt 30 strimmer and the shaft seems to be turning but the head has not got enough power in the shaft to turn the head and it all so seems to be vibrating where the shaft can be joined together...
For starters, check the condition of the LOWER flex- shaft.Remove the LOWER from the upper shaft, and while turning the string head, see if the top end of the flex shaft turns also. I think your unit has a clutch which makes diagnosing the flex shaft in the UPPER shaft housing (the one attatched to motor) a lot more difficult. If the upper flex-shaft is clutched, it WILL NOT turn when turning over the engine (unless the clutch is bad or has malfunctioned; which is rare). To inspect the UPPER flex-shaft, you will have to do a dissassembly (partial) at the motor housing cover in the front to pull the upper shaft out to inspect it. To get it all the way out to look at it, you will have to remove the throttle cable from the arm on the carb and disconnect the STOP switch wires going to the coil (located UNDER the front motor housing cover). Post back with what you find. Wish I was there to help.
Jul 14, 2011 | Ryobi Garden
The trimmer head does not spin, when the shaft is disconnected from the power source it spins freely. The drive componant bolted to the motor is frozen, therefore the motor cannot spin the shaft to drive...
remove shaft from power head check to see if drive shaft end is square if ok grab drive cable with pliers and try to turn head while holding pliers to make sure other end of cable and gear box are ok if so may have broke spring in clutch. remove plastic cover from engine you will see clutch bell remove spark plug stick piece of rope in hole to stop piston from moving where cable would go in bell there is a screw that holds bell on either torx or allen remove screw and take bell off there will be 2 shoes ans 2 springs that hold shoes togeather end of springs usually break where they hook in to shoe hope this helps
Aug 08, 2010 | Homelite Garden
The trimmer head stopped turning What could be wrong
here is web site for parts
http://www.partstree.com/parts/?lc=husqvarna&mn=225+L+%281994-06%29
almost sounds like the driving drum engagement end has rounded off or the end of drive shaft broke off at either end , or the gear head end is broken / damaged
have a look at the splines on the output shaft on the gear head , check the plate that engages those splines too
physicaly take off the tube / shaft assy from power head and check drum and clutch rotating , check drive shaft end (s)
if ok refit tube / shaft assy ( make sure engaged properly)
tighten mount bolts - remove gear head from end of shaft, start motor and run see if shaft turns ok with some rev s if so
problem is in the gear head
check out website good site
cheers paul hope it helps
Aug 01, 2010 | Husqvarna Garden
My troy bilt tb70ss trimmer sounds like something is stripped the motor will wind out but the head wont move its only 1 1/2 years old
will need to check if any debris is wrapped around head jamming the head --or -flex shaft is jammed or damaged separate shaft from motor and will see in shaft the flex shaft that turns the head try turning head by hand and observe flex shaft if binding or broke need to lube or replace
Jun 28, 2010 | Troy Bilt Tb70ss Gas Trimmer
Motor runs, but spool does not turn - is this fixable?
there is a shaft that goes to the head of the unit. The engine/ motor is not connected completely through.. you need to take apart the shaft to find out if it is just dislocated from the motor of if the shaft is broken or if the gear in the head of it is dammaged... goood luck
Jun 13, 2009 | Black & Decker 14" Grass Hog Xp...
Ryobi TP30 straight shaft line trimmer convertible - drive shaft disconnected from motor
check both ends of shaft, they're usually a hex or torx head. sometimes the can strip or even snap off. if you find noticable damage replace the shaft
Jun 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
69 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
