Question about GE Profile Harmony DPGT750EC Electric Dryer
Replace the belt
Need to replace the belt
    Problem Solver:
  • 6 Answers
You need to remove the front, usually a putty knife will release the top. Look at the joint between the front and top and move the P. knife back and forth across, then push those releases (two) in. You can now remove the front. The front has two bearing points for the drum to ride on and the belt needs to go past them. Then go around back and thread the belt on the motor pulley, it will look way too long but that is normal. That other spring loaded pulley is an idler pulley and takes up the slack.
Have a look here for more info.............http://www.applianceaid.com/images/ldrger-idler-pulley.jpg
Posted on Jul 31, 2010
Need diagram to replace belt on cub cadet mower
Hi there r photos on how to fit the belt. Type in Google. cub cadet mower photo of belt. There r also movies on YouTube how to fit belt. Type in how to change the PTO belt on ? cub cadet , good luck
Apr 20, 2016 | Cub Cadet Street Sign- tractor lawn riding...
How can you tell if a timing belt, A/T belt,P/S belt & A/C belt all need to be replaced?
The mileage is a good indication of age and need for replacement.
Mar 22, 2015 | 2011 Hyundai Accent
If I replace timing belt 97 quest van do I need to replace camshaft belt tensioner
any time a vehicle has a hydraulic tensioner it should be replaced. most parts stores have a timing belt replacement kit. some have the idler pullies and the tensioner and belt. you should replace the water pump while you are in their.
Sep 08, 2014 | Vehicle Parts & Accessories
I need to replace my serpentine belt
There is no belt tensioner. The serpentine belt in this vehicle is a what they call a stretchy type belt. There is a certain procedure you have to follow when installing the belt.. or you can damage the engine.
Nov 26, 2012 | 2011 Ford Fiesta
My serpentine belt went how do i change the belt do i need a special tool
Identify which belts need to be replaced. If you are replacing the air conditioner belt, you may need to remove the alternator belt because of the way the belts are shared on the crankshaft pulley. As a result, some mechanics recommend replacing both belts together.
  • Step 2 Loosen the lock bolt for the belt you are replacing using owner's documentation. The lock bolt will be near the belt tensioner component.
  • Step 3 Turn the adjustment bolt to change tension on the belt. When the belt is loose enough, slip it off.
  • Step 4 Use your memory or a belt routing diagram to install the new belt on all pulleys.
  • Step 5 Adjust the adjustment bolt to replace tension on the belt. Tighten the lock bolt.
  • Step 6 Make sure the belt is correctly seated on all pulleys and that the ribs fit into grooves on the pulleys.
  • Step 7 Run the engine and check for any flapping or looseness that could indicate incorrect installation.
  • This was copied from the service manual.
  • Jan 24, 2010 | 1995 Dodge Intrepid
    How often should you get engine belts replaced and what belts need to be replaced?
    Replace belts as needed, check for cracks on the sides of the belts or pieces missing from belt. A good belt should last 100,000 miles. and it is a good practice to replace at 100,000 even if it looks good. REPLACE ALL BELTS as needed.
    Jan 18, 2010 | 1996 Nissan Pickup
    How can i stop my AC belt from making noises when my AC is on
    The reason your belt is making a noise is either your belt is worn and needs replacing or the belt tension is out of adjustment and needs checking and adjusting.
    It is a good idea to replace it anyway specially if the belt has small cracks on the inside.
    Jan 13, 2010 | 2001 Nissan Maxima
    How do I tighten the A/C belt on my 2008 Mazda 5? The darn thing is squealing so loud but I can't seem to find a tensioner anywhere...
    If it is a serpentine belt is is self adjusting. So if it is squealing then it needs replacing as it is worn out. And also possibly the tensioner needs replacing as it may not be holding sufficient tension on the belt. If it is a drive belt it more than likely still needs replacing as it will have become glazed from slipping. On a drive belt it is adjusted by loosening the mounting bracket on the A/C and moving it in a direction that tightens the belt.
    Nov 07, 2009 | 2008 Mazda MAZDA5
    Need to replace vacuum belt
    how do i change belt on morphy richards ultralight cyclone cleaner?
    Jan 04, 2009 | Vacuums
    GE Profile Harmony DPGT750EC Electric Dryer Logo
    75 people viewed this question
    Top GE Dryers Experts
    Dave Harrison
    John Tripp
    John Tripp
    vince
    Are you a GE Dryer Expert? Answer questions, earn points and help others
