Question about Miele DA5190W 36'' Wall Mount Chimney Hood with 625 CFM Internal Double Sided Blower 4 Speeds Dela
How long can the ducting be? - Miele DA5190W 36'' Wall Mount Chimney Hood with 625 CFM Internal Double Sided Blower 4 Speeds Dela
  • 8,197 Answers
The ducting can be up to 50 feet in length.
Good Luck
Posted on Jul 31, 2010
Have a problem with my carrier air conditioner smelling like mold--also when cleaning what i can reach in the back fan it is totally black then when i turn it on small particles of black come out with the...
Sounds like you need to have the duct work cleaned by a professional.
Is your duct work in the concrete floor? If so check for water in the duct work. You can go to one of your supply grilles in the floor, take the grille up and look into the ductwork. If you have water, you need to find out if you have a plumbing leak or if it is just runoff from a hard rain. Nevertheless, it needs to be fixed.
Is your duct work in the ceiling? If so, and you still have mold, just have a professional duct cleaning company clean your duct work and it should solve your problem.
One other thing, make sure the condensate drain from your heater is not stopped up and dripping water into the duct work if the duct work is in the floor.
May 28, 2011 | Carrier Heating & Cooling
Tip
Dryer Ducting Installation Advice
Here's some useful guidance for installing dryer ducting. Improperly installed ducting can cause the following:
GAS DRYERS - Rapid burn cycling and improper drying results.
ELECTRIC DRYERS - Premature Heating Element failures.
IMPORTANT! NEVER terminate ducting in a chimney, under an enclosed crawl space or attic, and never common a dryer duct with a kitchen exhaust.
The total length of ducting and number of turns should be kept to a minimum. Semi-rigid metal type ducting is strongly recommended as it is more durable and resists collapsing.
If connecting sections of ducting, all joints should be tight to avoid leaks. The male end of each section must point AWAY from the dryer to prevent lint from accumulating at each junction. Ductwork should NOT be assembled with screws or fasteners that extend INTO the duct as this also will create points where lint will become snagged and accumulate. Wrap overlapping sections of ducting with duct tape.
A screen should NEVER be installed over the exhaust duct termination. The preferred termination is a dampered wall cap having a 4 inch opening. It must be installed a minimum of 12 inches above the ground.
Maximum Length of Metal Duct:
# of 90 degree elbows:
4" Semi-Rigid 4" Flexible
0 - 58 ft 28 ft
1 - 48 ft 23 ft
2 - 38 ft 19 ft
3 - 29 ft 17 ft
4 - 21 ft 15 ft
NOTE: It is recommended that you inspect your dryer ducting periodically to ensure you have no lint build up. Excessive lint can present a fire hazard.
on Dec 04, 2009 | Dryers
Tip
Dryer Ducting Installation Tips
Here’s some useful guidance for installing dryer ducting. Improperly installed ducting can cause the following:
GAS DRYERS – Rapid burn cycling and improper drying results.
ELECTRIC DRYERS – Premature Heating Element failures.
# of 90 degree elbows 4” Semi-Rigid 4” Flexible
0 58 ft 28 ft
1 48 ft 23 ft
2 38 ft 19 ft
3 29 ft 17 ft
4 21 ft 15 ft
on Feb 10, 2008 | Whirlpool GEW9250 Electric Dryer
How to properly size a duct return in a house
To size that return duct you need to know the cfm of the unit, and size according to that...Ell's and distance also need to be factored in....
Here is a free duct calc. that you can use to help you size you ductwork...
Here is a website that will let you get a free trial duct calc.
http://efficientcomfort.net/Calculators.html
Here is another free duct clac...
http://duct-sizing.downloadsoftware4free.com/
Heatman101
Sep 21, 2010 | Coleman Heating & Cooling
Reinstall RANGE HOOD from non-ducted to ducted
You need to uas a 7 inch duct to duct it out. You can get all the info you need in the manual on the link below. Please give it some time to load. If you need parts you can call Sears at 1-800-4-MY-HOME.
http://www.managemylife.com/mmh/owner_manuals/2285/KENMORE-Range-Hood-L1002022?brand_name_search=233.55213.000+
Good Luck and please rate 4 thumbs up for the free answer
Aug 01, 2010 | Kenmore Kitchen Ranges
Centeral air conditioner
If cool air is moving through the duct work,(feels cool or cold) and the area outside the duct work is warmer/hot, then you will get condensation forming on the duct work. Wrapping the duct work with insulation should lessen, or eliminate that.
Jul 10, 2010 | Heating & Cooling
What is the difference between ducted roof air and non ducted.
Non-ducted units blow the cooled air out louvers on the unit. Ducted units discharge into a duct system like your home furnace. (Or RV Furnace (heater)).
Apr 10, 2010 | Dometic Rooftop RV Air Conditioner
No heat/// blower works
First, check the duct work! The most common "no heat" problems with dryers are caused by duct work blockage. If your duct is blocked, it will overheat the unit, causing it to shut down the heat source (gas or electric, it doesn't matter). Most units will continue to "blow" without the heat. Remove the duct work, remove all lint from the duct and "exit" port of the unit. Then, check the wall duct, both inside and outside the house.
Feb 14, 2010 | Dryers
Manual air duct damper installation
Go down to where the ducts come out of the furnace. Identify the line you want to install damper. Open duct and drill two holes directly across from each other. Take your damper and undo the nut and washer on the one end and install in the holes you just drilled. Reattach the washer and nut and now re connect the duct seal it with duct tape and you will be good to go.
If you have 6 inch ducts get a 6 inch damper. But be sure to do everything at the beginning on the duct as to divert air to other ducts.
I have to tell you that changing your air flow could develop problems if you do very many ducts. So be very aware of what you doing. All systems are put in with air flow in mind.
May 04, 2009 | Heating & Cooling
Miele DA5190W 36'' Wall Mount Chimney Hood with 625 CFM Internal Double Sided Blower 4 Speeds Dela Logo
129 people viewed this question
Top Miele Kitchen Ranges Experts
Marvin
Marvin
Jim Thurston
Steve
Are you a Miele Kitchen Range Expert? Answer questions, earn points and help others
