Question about Linksys EtherFast EZXS55W 5x10/100 Mbps Networking Switch
Xbox and laptop cant connect at the same time
I have comcast 16 meg internet and i ran one ethernet cable to port one on the switch and plugged in my laptop and xbox, its either one works or the other but not both at the same time, i have reset about 50 times and still nothing good. I have switched ports and tried the uplink port of the linksys and still nothing. Its either the xbox works or the laptop but not both at the same time.
    Diehard:
    Visited the website for 60 consecutive days.
  • Linksys Master
  • 699 Answers
Your ethernet cable from comcast gets plugged into the wan port of the linksys switch. plug the xbox and laptop to one of the lan ports. the comcast box is a modem/router? without the router it won't assign dhcp addresses
Posted on Aug 19, 2017
4 Suggested Answers
SOURCE: Want to have wireless with my Limksys Sr2016 switch
Go to: www.speedtest.net with a laptop on your network.
Find your speed. now repeat on same laptop plugged directly into the cable madem.
Do the settingsa change much?
If so, your network is at fault. If not, Comcast is lying to you.
Posted on May 13, 2009
MrFixIt268
  • 52 Answers
SOURCE: linksys switch question
You certainly can. In a real network you have one router and x amount of switches or hubs. Because whats going to happen is your equipment will automatically will ask the switch which will bounce to the router and your router will issue the address to that device.
Posted on Jul 20, 2009
SOURCE: Linksys EZXS16W switch, ports 1,2,3,4,9,10,11,12
I can give you the full manual of that product bro but you should have to install a foxit reader in order to read the file or the manual. First intall this software: http://www.mediafire.com/?nyowk0a5yqm Linksys EZXS16W manual: http://www.mediafire.com/?tgkdwnkjz1g
Posted on May 14, 2010
Have a server that was connected to DSL router then a dell powerconnect 2216 switch and ran the LAN and internet through the switch. Cannot get the switch to connect to the internet with a cable modem and...
That is a good guess. Many of the switches available for home use are unmanaged, and will take any IP address given to them from the router and generate related IP addresses for the various devices on your network.
If your router has multiple Ethernet connections, you may not need the switch at all...just connect your Ethernet cables to the output plugs from the router.
Sep 15, 2017 | Dell PowerConnect 2216 16-Port Ethernet...
Tip
How do I Connect an Apple Mac Laptop to the Internet Via a Broadband Router on...
  1. Connect one end of an Ethernet cable to the Ethernet port located on the back of your Apple Mac laptop.
  2. Connect the other end of the Ethernet cable to the Ethernet port located on the back of your Comcast broadband router.
  3. Power on your Apple laptop and broadband router.dont forget to leave youe comment by saying how helpful this tip is to you
on Oct 08, 2010 | Computers & Internet
Ok, my router is way in the other room and I want to connect my Xbox 360 to the router for XBOX LIVE. The thing is, is that I can't find a way to get something to extend the wire that's connecting to both;...
There are several solutions to your problem .
1. Run Ethernet Cable from an attic & drop either end down in the walls of the two rooms . Hardwiring is always going to give you the fastest , most stable connection .
2. Purchase a set of Power Over Ethernet Modules , you then plug your ethernet cable into your Xbox 360 on one end & the Power Over Ethernet Adapter on the other end , then plug the " POE " Adapter into a standard electrical socket . You will do the exact same thing on the other end with the Router this time . It should connect just as if you ran a single ethernet cable between the 2 devices .
3. You can use a laptop or desktop pc with a Wifi connection & Ethernet port to Wifi Tether / Share your Internet Connection . Just do a google search on Wifi Tether Xbox 360 or check out some of the videos at
http://www.google.com/search?q=wifi+tether+xbox+360&hl=en&prmd=ivnsfd&source=univ&tbm=vid&tbo=u&sa=X&ei=l_SoTfyFI4-usAOT1PX5DA&ved=0CHQQqwQ
Apr 16, 2011 | Microsoft Xbox 360 Console
I have a linksys cable/dsl router with 4 port switch and also a linksys 16 port workgroup switch. I want to connect 10 computers to the internet with all automatically getting the dumby ip address. Can you...
When your 10 computers are connected to the switch, just make sure your ethernet cable is plugged into the ethernet port. The computers should then have a internet connection
Mar 03, 2018 | Linksys EtherFast 10/100 16-Port Workgroup...
I just got this dynex 4 port ethernet hub and i have comcast wired internet . and i want to hook it up to my xbox 360 and my computer but , it wont let me . when i try to get xbox live it says network...
You need a router not a hub or a switch. with the help of the router you can share the comcast cable internet on multiple devices. A hub or a switch can not do this.
Get it replaced with a router. You can buy Linksys or Netgear router.
Rashish
Aug 17, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
May 12, 2009 | Linksys SR2016 16x1000 Mbps Networking...
Cannot share my cable modem connection
You need to connect a router to the cable modem.  The router then gets an IP address from Comcast and provides a gateway between the computers connected to the router.
The modem expects to communicate with a single Ethernet device, and provides an IP address to the first device that provides a piece of data called a MAC address.  By placing a router in-between, the router gets the IP address that lets you communicate on the Internet.  It provides local IP addresses to the equipment connected to the local Ethernet and "routes" those to the Internet.  You can either hook your two devices into the router if it has enough ports, or hook you switch to the router and hook your PC and PS3 into the switch.
May 05, 2009 | Linksys EtherFast EZXS16W 16-Port Ethernet...
Gigafast ethernet won't let my Xbox connect to live
You might open this ports to the Gigafast Ethernet router :
TCP 80, 3074 and 53
UDP 88, 3074 and 53
Note: You'll needing to open these ports to the virtual server or port forwarding under advance settings of the router.
Mar 06, 2009 | GigaFast Ethernet Gigafast 10/100, 8-Port,...
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Jul 02, 2008 | Video Game Consoles & Games
Linksys EtherFast EZXS55W 5x10/100 Mbps Networking Switch Logo
205 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
