Picture stretched on CRT 32"
My picture on the TV is parallelagramed with the top stretched and I am loosing the top and left hand side of the picture. It has had a dry solder joint problem that I have cured but I am stumped at the picture problem.
  • Snowcrash
    Snowcrash Apr 28, 2008
    I can tell what is the power supply but I don't understand B+, where it is or what voltage it should be. The dry solder joints were on a choke(coil) near the HT transformer.
  • Snowcrash
    Snowcrash May 06, 2008
    I think the dry solder joints have caused the problem of the picture stretching. I have checked around but nothing else is amiss. At first the TV wouldn't switch on unless you banged it but the picture wasn't stretched. This went on for about 1 month before the picture started stretching. I then found the dry solder joints on a choke near the HT transformer (flyback?) and this cured the switching on problem but the picture stretching stayed. I think the problem is now a dead or dieing component but which one???
B+ means your secondary supply voltage it supply your horizontal tansistor and in the flayback transformer. it rated 80volts to 120 volts.the choke coil you have is maybe for the horizontal linearity, try to solder it.thats the reason why you picture is being streched out.
Posted on Apr 29, 2008
    Problem Solver:
  • 16 Answers
The problem is that your flyback and also your power supply circuit. check the B+ of your supply.
Posted on Apr 25, 2008
Model 32A40. Picture periodically reduces to one narrow horizontal line. Becoming more frequent. Does this mean picture tube is going. What might potential repair cost be? thanks in advance.
No it is not a tube problem .............hit your TV on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width, or rolls etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears normally for some time............so solution is .....TV main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer & just ask him to resolder joints .............iam from bangalore - computers, laptop, printers, etc ) ----- good TV service engineer will charge less .........
Aug 06, 2011 | Toshiba 32A40 32" TV
My son pressed some option on tv, made the screen zoomed in . It's kind of wavy and the people on picture are really stretched.
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again (2inch on top will also gets solved )................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer -------- IAM SURE PROBLEM IS NOT BECAUSE OF YOUR SON BUT DUE TO ITS AGE
Apr 18, 2011 | Daewoo Televison & Video
Picture is small box upper right hand side
when picture is getting smaller in size or goes away or moves towards one side ( like yours) then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some CRT computer monitors & CRT TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re- soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 17, 2011 | Daewoo DTQ-20U9SC TV
Hello! I have an Olevia 232 T12 LCD HDTV and I am having a problem with picture distortion. In the center of the screen, the picture is fine, but at the left and right hand sides, it looks as though the...
Hello.
It does not look like there is something wrong with electronics in your TV. Most likely settings for picture are got messed up. It could be TV settings or source (cable box, etc. settings).
Using remote control of your TV find picture settings in menu and make sure it set to "standard" instead of "zoom", "stretch", "wide" etc. You might need to do the same with cable/satellite box menu. Some devices have button "picture" or "format" on remote control for this purpose.
You can also connect DVD player first and see if picture is stretched as well to determine if it is TV settings are wrong or it is outside of TV set.
Regards.
Russ.
Dec 01, 2010 | Televison & Video
Good evening, I've gone through the manual and I can't get my TV to show 100hz (always 50hz), also on some channels I cannot get the picture to fit the screen (it's 32''). Any help would be greatly...
Well, first the 100Hz issue. Your TV will display a descriptor or the signal it is receiving, not a descriptor of the picture you are watching. Your TV panel has a native resolution and frequency. In your case, that frequency is 100Hz. Everything, like it or not, must be converted to 100Hz for the TV to work. In your manual, you are simply adjusting setting which smooth the picture and make it flow better than it would at 50Hz. This feature is slight of hand and is probably working just fine. As for the picture fitting the screen; HD programs fill the screen of HD channels.... SD (Standard Definition) programs use black bars on each side when on HD channels. You can use any available wide or picture size feature your TV may have to stretch the picture. You may be unable to stretch the picture, due to restrictions (some TVs will not resize HD formats).
Mar 15, 2010 | Televison & Video
I can't see the whole picture. the tops of everyone's heads are cut off. Normal, stretch, zoom format does not fix it
check to see if tv has a function call aspect ratio
that should take down the picture size not screen size
Aug 17, 2009 | RCA F32650 32" TV
My sony tv problem is that the picture is stretch horizontally..
If you have a DVR too, there is a pound (#) button on the beside the zero on the DVR remote that stretches my screen off and on. Try that.
Jan 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
32" rca picture stretched
Before you fool around with this, it may be under warranty. Check that first. Second, does the picture stretch in both directions or just vertically? If just vertically is it more pronounced at the top?
Thanks,
Dan
Apr 03, 2008 | RCA 32V420T 32" TV
Sony KV-32LS60U FD Trinitron 32
Your tv has Leak cap in POWER supply its either primary or secondary power. Need to replace it. Look for a Electronic Tech.
Jan 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Open Questions:
I have horizontal white lines across the display of my LCD Tv, I've included more info in the details section below I have an Insignia model# NS-46L780A12 LCD TV MFG date July, 2011 , recently the display has been acting very strangely because the issue comes and goes consistently dependent to whether or not there's caption writing on the screen - examples being programming information , channel , time etc.....these info blocks are each in their own particular areas on the display , where this gets odd is when your watching live TV ,these info blocks are always filled in with whichever program that's on, the best description of this issue is from these individual blocks of written captions on the screen example - from the top , there will be a continuous vertical row of horizontal lines starting directly underneath said caption all the way to the bottom , this will happen consistently wherever there happens to be writing on the screens display, so you get multiple rows of these horizontal lines from top to bottom of the display and they'll stay there for the entire time you watch your show , some shows have more ,some less ,depending on the writing for that show , this is all on cable TV / live TV I guess you can call it , and when I use my Fire TV stick with certain apps , I'll get no vertical rows horizontal white lines on the display with the exception that I push the mute button or change the level of the volume and the lines start to want to show up and do partially just for a little while ,but almost as soon as the info on the screen disappears as far as mute/ no mute or the volume level , the vertical rows of horizontal lines go away , I should also say that in either case Fire TV stick or cable , these vertical rows of horizontal lines take a little time to develope all the way from where the caption lettering begin and same process for when they go away , it's not instant in either case , it can take up a couple of minutes for either process to happen , one other oddity I guess you could say , in watching a cable tv program where you may get let's say 5 vertical rows of horizontal lines top to bottom at the beginning of the process , if you happen to try to watch that show ,those individual vertical rows of horizontal lines of varying widths will eventually connect with each other horizontally across the display
Feb 18, 2018 | Insignia Televison & Video
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
