Question about DeLonghi Coffee Makers & Espresso Machines
Super Automatic Magnifica grinder does not grind
  • DeLonghi Master
  • 12,061 Answers
This is usually caused by a faulty motor or motor drive, they are very hard to service and really should be done by a professional, my advice is to get back to the agent, or place you purchased from, or even contact the manufacture, Delonghi r direct, and ask for a referral to an authorised service center, this way you can be assured of a good fix.
http://www.retrevo.com/support/Delonghi-EAM3200-Coffee-Makers-manual/id/3878ci575/t/2/
Posted on Jul 31, 2010
All lights blinking red simutaneously
grinder is very fine, turn the knob inside the coffee to a large chislo.Ako not fix it, there are probably some trash between the blades of the grinder.
Nov 26, 2013 | DeLonghi Magnifica 3300 Espresso Machine
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Stopped grinding beans, no action when I press the grinding button
Hi, your grinder needs to be replaced. Its a pretty easy job. The grinder comes as a full assembly, new cutters and all. dazza
Oct 13, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Can you grind hazelnuts with the coffee in our 3000 magnifica
I would not do this as hazelnuts are oily and will probably gum up the grinder.
What you could do is but a few ground hazelnuts in the pre-gound chute at same time coffee beans are grinding. These will go into brewer unit at same time as coffee.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Esclusivo Magnifica grinder cogs have stopped spinning while the hub turns, thus no grinding is done! Help
u need it all set back up///needs grinder tanken out . if lugs are broken u need to put new grinder in....
Jan 25, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The machine makes a very loud noise when grinding the coffee beans. * Magnifica Espresson Machine *
Even a properly operating super automatic DeLonghi espresso machine makes enough coffee grinder noise to scare your pets and wake you next door neighbors. It's LOUD, no doubt about it. Only if your grinder makes more noise than that do you have a problem.
Jun 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Jan 13, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Mazzer luigi super jolly
Easiest way to set the grind on the super jolly is to remove the beans, turn towards fine until you can barely move the middle stem in the grind chamber, then turn towards course about 12-14 notches on the grinding adjuster(not numbers but notches between numbers). If you still cannot get a fine grind and it is not a brand new grinder replace burrs.
Feb 28, 2009 | Mazzer Coffee-grinder SUPER JOLLY Electric
Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Aug 31, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Open Questions:
Coffee Makers & Espresso Machines Logo
79 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
