Question about Sport & Outdoor - Others
I have a 1988 jayco dove pop up camper i was needing to know how to fix the lift system on it the front side will raise but the back side will not i know 1 cable is broke and something is wrong with one of the springs what can i do to fix this problem.
5 Suggested Answers
  • 68 Answers
SOURCE: replace left spring in pop up camper
http://www.customcylindersintinc.com/camper_trailer_roof_lift_system.htm
Search this site and you will find what you are looking for.
Thanks for using Fixya
Jerry
Posted on Mar 26, 2009
savindude
  • 175 Answers
SOURCE: I need a repair/owner's manual for 1999 Coleman
Tried googling Coleman? They might be able to help.
Posted on Jul 02, 2009
canbruce75
  • 1776 Answers
SOURCE: Jayco lift system cable replacement
Try this link and see if it will help you any with the info that you need. Sure hope this helps you find resolution to the problem. Best wishes.
http://www.ehow.com/how_4708883_repair-jayco-camper-cables.html
Posted on Jul 23, 2009
canbruce75
  • 1776 Answers
SOURCE: Broken Cable on Pop-up trailer need help
Posted on Sep 06, 2009
I bought a pop up. On the way home from buying it popped off hitch (apparently the coupler needs to be replaced)- how do I go about repairing (or does anyone know of a place in southe east WI area that...
Hitch: Verify the obvious. 1-7/8" or 2" ball and coupler. Some couplers can be and may need to be adjusted. Look for a screw on the rear side.
Sorry, not much help on the lift system. Although, I rigged a winch up to my coleman instead of replacing the whiffle tree. You may be able to do similar.
Apr 09, 2010 | Coleman Campers Grill
One corner of will not retract when lowered.
Hi, it sounds like one of the riser cables may have broken. Try visiting
for more info.
Sep 30, 2009 | Sport & Outdoor - Others
Sep 06, 2009 | Sport & Outdoor - Others
Jul 23, 2009 | Sport & Outdoor - Others
Have used 1981 Coleman pop-up camper and the mechanism that raises the camper up is stripped. Either need manual for 1981 Coleman pop-up or any idea where to get the part to fix problem. It's the screw...
My Coleman has the same problem. I can crank the top up but it will not hold in place.
I just leave the crank handle in place after raising the top and secure the handle to the bumper with a bungee cord. It's jury rigged but it works great.
Sep 21, 2017 | Coleman 10' X 10' Sundome Tent 9160K101
Pop up Camper will not raise up when cranked
The cable pulleys will be behind something in each corner of the camper , you will need to remove the wall somehow at the bottom corner , sometimes depending on the model it is easier to remove the outside panel and put the cable back on the pulley then put the outside panel back on , be prepared to damage it though as they can be very stubborn to remove but you can repair it later .
Jun 04, 2009 | Arc'Teryx Rock & Ice Climbing
Broken cable in older Coleman pop-up camper...how to replace it? Can't see in body of camper where the cable needs to go through to the posts that raise the top.
This camper uses the Coleman lift system which uses a threaded rod that connects to a tracked distribution block to which all four cables are connected and then routed by pulleys to all four corners of the popup.First raise the popup to it;s full height by using automotive jacks and poles once extended securely clamp the poles to the telescoping up rights This IS SUPER IMPORTANT FOR YOUR SAFETY. Next get under the camper find the broken cable unbolt it's routing pulley(s) pass the broken ends out the pulley(s).Next unbolt the end from the distribution block. followed but unbolting the cable from in side the telescoping column;carefully note the routing in side the column. Buy or make up an exact length cable of aircraft grade stainless steel twisted wire cable of the same gauge. Reverse steps to re install,take lowering strain on crank make sure crank handle is captured by anti free wheeling device on camper un clamp poles remove, lower and raise top by crank to ensure smooth working. You're finished.
Apr 19, 2009 | Coleman Sport & Outdoor - Others
Jayco pop up repair manual
I have the original schematic for the pop-up cable system on my Jayco. what year is your Jayco?
Oct 29, 2007 | Computers & Internet
Sport & Outdoor - Others Logo
115 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
