Question about Cycling
Does a gas motorcycle need to be charged? - Cycling
  • 999 Answers
There is a alternator just like in a car to keep the battery charged. If it is not staying charged have the electrical system checked and the faulty component serviced.
Eric
Posted on Jul 30, 2010
YAMAHA EFI LIGHT ON WON'T START SEEMS LIKE VAPOR LOCK. PLENTY OF GAS BATTERY FULLY CHARGED
Hi, Johnnie you need to find out what fault codes were generated for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha Fault Codes motorcycle manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 23, 2016 | Yamaha Motorcycles
How do you charge battery
A motorcycle battery should be charged with a small charger, 6 amps at most. Take the time to be sure your battery connections are clean, tight and in good shape. When charging any battery hydrogen gas is emitted, do it in a ventilated area with no open flame. Hook the negative clamp (black) of the charger to the negative (-) post of the battery, positive clamp (red) to the positive of the battery (+); plug charger in. Chargers may have a gauge that shows battery charged when needle is almost to 0. I prefer to spend a couple extra bucks and have a charger with automatic shut off to avoid over charging
Sep 28, 2014 | Motorcycles
G-16 GAS CART
u need to replace the soilnoied the contackts are not making if u cannot do this u will need to replace it
Jun 09, 2014 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
Fi light is on, last time i drove it i ran it out of gas n it has sat awhile but sprayed starting fluid in it an it tried to start.
Fill tank with 93 octane add injector cleaner, you may need to charge battery before your running. All gas has water the older the gas the more water, running out of gass draws the water into fuel lines and injectors. Good luck
Aug 15, 2011 | 2001 Suzuki GSX-R 1000
2005 Honda Silverwing 600 how to drain the old gas
Hi, Anne for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $27 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Draining fuel tank
EASY Empty Motorcycle Gas Tank
Honda 2002 2003 2004 2005 2006 Silverwing service manual Download Manuals... $27
https://www.partsfish.com/page/oem-parts-for-honda
Honda FJS600 Silver Wing Owner Manual
Apr 23, 2011 | 2005 Honda Silverwing 600
Bike is sputtering when give it gas. sat for 2
Make sure battery is full,not just charged. if the sputter is still there you may need to clean air filter,fuel fillter or carbs may need to have trash removed from inside at the fuel float valve-seat and jet.
Apr 29, 2010 | 2004 Honda VTX 1300
Cranks but wont turn over
Did you drain the gas out before you stored it.
If its carb model, then the carbs probablt need taken off and cleaned.
If it fuel injected, the screens are probably plugged up....dump the gas and try fresh gas
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Mar 31, 2010 | 2003 Suzuki VL 800 Volusia
Have a 2007 boulevard c90 motorcycle cruiser wont start been 3 months since used. my husband road every day keeped in great condition however he been in hospital and i can get it started as he requested i...
hello, usually battery is under the seat or bolted on the left side up above the back wheel, you may need to charge battery or purchase one, when motorcycles set the battery starts to break down, because there is know current going to battery to keep it charged, if that fails you might have to replace the starter cylnoid i would drain old gas, maybe change fuel filter also.
Feb 01, 2010 | 2007 Suzuki Boulevard
Motorcycle shuts off as I am riding, like if I am running out of fuel, but has plenty of fuel if I mess with the petcock it starts up
Check that the carb is getting plenty of gas. Check in-tank filter if needed. Same with external filter as well. Also make sure you have a good strong spark, if not, coil or charging unit may be faulty.
Sep 16, 2009 | 2003 Harley Davidson FLHT Electra Glide...
Cycling Logo
21 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
