Question about Microwave Ovens
My westinghouse fridge model RJ532 Freestyle is leaking water on the floor
Internal water drain is blocked - get very thin copper wire and unblock -
Posted on Jan 16, 2011
Plumbing in water supply to fridge.
if this is for ice maker this is how its done. run the line through the floor in back of fridge to a cold water pipe. closest to where fridge sits.
  • Turn off the cold water supply to the pipes.
  • Attach a pipe clamp to the cold water pipe.
  • Screw a packing nut into the cold water pipe. Turn the packing nut until it punctures and taps into the pipe. Attach ΒΌ-inch copper tubing to the outlet valve on the packing nut using a compression nut. Make certain the valve is closed before you secure the packing nut.
  • Attach the copper tubing to the intake connection using a compression nut. to back of fridge,
  • Turn on the cold water supply.
  • Turn on the outlet valve on the packing nut.
  • the kit should have directions with it. good-day !
    Aug 20, 2011 | Microwave Ovens
    We have water leaking from the back of the frige, coming from under the area where the copper tubing connects from the wall to the actual refrigerator. I can't identify exactly what's leaking. I doesn't...
    This can be an auto defrost condition. If your fridge is auto defrost, what happens during the defrost mode, ice build up is heated (in the area immediately near the evaporator coils, not in the main area) . This ice becomes water and drains out via a small tube, typically at the back or bottom of the machine. This water normally goes into a pan under the fridge, and evaporates without the user being aware of it.
    If anything causes excessive ice build up (opening the door too much, door seal leak, etc.) then you get too much water and the pan overfills and spills out.
    I suggest that you remove the pan from under your fridge, clean it, and put it back, and test to see if yo actually have anything wrong, or not.
    This leak would NOT be refrigerant, as you would cease cooling if so. it is all condensation, which is physics and normal...
    Mar 20, 2011 | Microwave Ovens
    My refrigerator has a leak behind the drawers on the inside . I have since had to put a towel at the bottom of the drawers or it will start leaking down the front and onto the floor every couple of days....
    Moisture condenses out of the cold air inside the fridge. Many refrigerators have a drain tube in the bottom to allow the condensate to run into a drip tray under the refrigerator (behind the trim panel on the bottom) where it evaporates. Over time this tube can get clogged by food particles and the water backs up, eventually running over the bottom edge onto the floor. You can use a straightened out coat hanger or other stiff wire to clear it out. This should get the water back into the tray where it belongs.
    Jan 21, 2011 | Microwave Ovens
    I have a westinghouse oven freestyle 662 and i was wondering how to replace the light bulb inside the oven
    I had the same problem. I found the glass cover was just too tight to move by hand so after isolating the oven, I used an old cloth and adjustable pliers that could apply more pressure. This worked straight away.
    try not to screw it on too tight.
    cheers
    Jan 19, 2011 | Westinghouse Microwave Ovens
    Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
    Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
    2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
    Jan 15, 2011 | Microwave Ovens
    A small amount of water is accumulating on the floor just below fridge on right side. It does dry up but returns daily.
    That will be the condensation from the water vapour produced by food in the fridge. There is a drain hole at the bottom rear of the fridge.
    Jan 13, 2011 | Microwave Ovens
    My westinghouse refrigerator has stoped working but my freezer is working fine help. Model Bj513V Serial Number 72656346
    Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator Defrost Timer Problem
    Water Running in refrigerator from Freezer
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    Nov 18, 2010 | Westinghouse Microwave Ovens
    Not sure how to take the glass off the front of the oven for cleaning on my Westinghouse Freestyle 688...
    Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
    Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
    You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
    Sep 03, 2008 | Microwave Ovens
    Microwave Ovens Logo
    712 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Marvin
    Marvin
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
