Question about Sony KDF-E55A20 55 in. LCD Television
The image and the sound of my Sony turn off for about 45 seconds and turn on for 30 sec. repeatively and the cooling fan keeps running and the green light stay open and not flashing. Do you have an answer for me? thanks.
    Novelist:
  • 132 Answers
You have a bad lamp. That's how a lot of sony dlp's will do when the lamp is about shot. I've replaced many of them at our shop for the same problem. You'll probably get the best deal on one at ebay. They are very simple to change, especially if you buy one already in the housing. Just type in your model number and the word "lamp" in the ebay search bar, and they will come up.
Posted on Jul 30, 2010
  • 10,594 Answers
Yes, answer is your lamp is reaching to end of its working life span and need to be replaced.
Above symptom comes when lamp got weak in result but has not been broken because lamp light will lit on broken lamp.
Replace lamp in tv if it has not been replaced in last 2-3 years. Lamp replacement procedure is written in user manual. Let me know if you need more help.
Thanks.
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
PICTURE AND AUDIO TURN OFF FOR ABOUT 45 -60 SECONDS AND THEN COME BACK ON. THIS HAPPENS REPEATEDLY BUT DURING THAT TIM THE GREEN LIGHT STAYS ON ALONG WITH THE FAN.
Dust has colected inside and fan is ot cooling the lamp adequately so there is a safety sensor to prevent overheating. Carefully remove the back panel and vacuum the dust out of the back and the fan. The better you clean the longer the problem will be fixed!
Oct 22, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Turn on and screen goes blank after 45 seconds
I found the problem was related to the lamp. Your TV power up but then the lamp would overheat and automatically shut down (audio and video) resulting in a dark screen with no sound. Once the lamp cooled (30 - 60 secs) it would come back on. Then overheat, turn off - recycling "eternally". A new lamp will solve the problem
Bye
Dec 28, 2009 | Sony KV-35S45 35" TV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV comes on and then shuts off,and a small red l keeps flashing.
If its flashing red repeating groups of three then the lamp door is not detected .
If its flashing in groups of four then a fan is not starting.Look in the vent in the back and spray some canned air into then big fan on the left(looking at it from the back) .That fan may be failing and has gotten to a place where it can't quite start again and just moving it a little with some air will make it work for a while.
If its not one of those two things let me know.
Oct 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony kdfe50a10 blinking green light
did you find out the answer to this problem as we have the exact same issue? thanks
Sep 22, 2009 | Sony (XL-2400) Projector Lamp for...
Kdfwe42655 Sony Picture on approx 45 seconds;
http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=19 <try this and good luck! let me know if it helps...
Jun 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
INTERMITTENT PICTURE AND SOUND
You were told correctly, you have a bad lamp. When the lamp gets old, the reflector becomes cloudy and instead of reflecting the light, it converts it into heat. As the lamp heats, it draws more power, eventually too much power and the set "recycles" because the lamp is drawing too much power. Replace the lamp, use an original Sony lamp as the aftermarket replacements are known troublemakers. If the bulb fixes the problem (and I know it will because I fix these TV's everyday) be sure to rate this solution. Thanks!
Nov 22, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony KDF-E55A20 55 in. LCD Television Logo
704 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
